727 Trans pan #1729494
01/14/15 12:08 AM
01/14/15 12:08 AM
CA.
RAY1969CARS Offline OP
CA.
Who's transmissions pans are you running and why do you like them
Re: 727 Trans pan [Re: RAY1969CARS] #1729495
01/14/15 12:33 AM
01/14/15 12:33 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Mopar Performance pan
Nautilus Racing-
Re: 727 Trans pan [Re: RAY1969CARS] #1729496
01/14/15 12:35 AM
01/14/15 12:35 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I have the B&M pan, it is nice but to deep and I had to raise my truck up some to clear speed bumps and driveways
I want to get another cast aluminum pan but one not so deep for more ground clearance.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 727 Trans pan [Re: slammedR/T] #1729497
01/14/15 01:04 AM
01/14/15 01:04 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Hughes. It's huge! The only draw back is tightening the straps for the transmission blanket.
Re: 727 Trans pan [Re: RAY1969CARS] #1729498
01/14/15 02:54 AM
01/14/15 02:54 AM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I just run stock overdrive pans. Same as on my 97 2500. I just add a drain plug and filter extension on a 727. http://www.ebay.com/itm/351218654172
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: 727 Trans pan [Re: MoParFish] #1729499
01/14/15 05:33 AM
01/14/15 05:33 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
TCS on the Dart & a Trickflow/Summit with 1/8 machined off the flange. i had a B&M but it sits too low, the Summit one is overkill on the flange so it was easy to mill 0.120 off it to aid clearence for a street strip car.
Re: 727 Trans pan [Re: MoParFish] #1729500
01/14/15 09:20 AM
01/14/15 09:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run these as well. They are 1" deeper than the normal deep pan. Had to fab an additional filter spacer. Been buying them for about $35.
Doug
Re: 727 Trans pan [Re: dvw] #1729501
01/14/15 01:34 PM
01/14/15 01:34 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
B&M aluminum.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 727 Trans pan [Re: hemi-itis] #1729502
01/14/15 01:57 PM
01/14/15 01:57 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run the B&M finned aluminum pan as well. Good quality aluminum pan at a decent price. I noticed a 10-degree difference in fluid temp with it, from a stock pan.
Re: 727 Trans pan [Re: StealthWedge67] #1729503
01/14/15 05:19 PM
01/14/15 05:19 PM
an8sec70cuda Offline
Much less prone to leaking like a steel pan.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 Trans pan [Re: an8sec70cuda] #1729504
01/14/15 08:19 PM
01/14/15 08:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the B&M on my street car. Nice pan but it is heavy. Neither pan leaks a drop.
Doug
Re: 727 Trans pan [Re: dvw] #1729505
01/15/15 07:35 PM
01/15/15 07:35 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
We have supported moparts since 2005
