Where to get vacuum on a tunnel ram..... #1729372
01/13/15 09:03 PM
01/13/15 09:03 PM
West Virginia
N
NewbombTurkk Offline OP
N
West Virginia
I have power disc brakes, pcv line, distributer and modulator lines which all need vacuum. I have a WIEAND dual four tunnel ram with brand new 450 holley carbs, manual secondary.
I was wondering if I should tap a fitting into the rear for the brake booster, or would the carb vacuum fittings provide enough vacuum for all accessories? I don't want to put the spacers under them with vacuum fittings, or get an electric pump.......anybody else dealt with this before?
FYI, it is a 72 Camino, bone stock 402, highway gears, no stall, just want to have the 'look'.......I figured vacuum is vacuum, either GM or Mopar! Thanks for any help.
1969 Buick Sportwagon 455 Stage 1 Ram Air SOLD
Nationwise Auto Parts Alumni 1982-1984
Now 1972 El Camino, original 402
Re: Where to get vacuum on a tunnel ram..... [Re: NewbombTurkk] #1729373
01/13/15 09:14 PM
01/13/15 09:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When I ran a tunnel ram I drilled and tapped into the back of the plenum. That's fine for the power brakes and PCV but I'm not sure that's where you want the vacuum for the vacuum advance - I believe that has to be "ported" vacuum.
450 carbs - good choice. Manual secondaries ... maybe not so good !!!
Re: Where to get vacuum on a tunnel ram..... [Re: NewbombTurkk] #1729374
01/13/15 11:03 PM
01/13/15 11:03 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Manifold vacuum.
Rear carb feeds brakes& heater controls.
Front carb feeds pcv.
Re: Where to get vacuum on a tunnel ram..... [Re: Stanton] #1729375
01/14/15 12:57 AM
01/14/15 12:57 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Where to get vacuum on a tunnel ram..... [Re: TJP] #1729376
01/14/15 05:37 AM
01/14/15 05:37 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Mine has a fitting in the top portion of the plenum in between the carbs. BTW, I had those same carbs and they didn`t work out well for me. I ended up going with vacuum secondaries.
