Re: gauges and tech for race car
[Re: dvw]
#1729288
01/13/15 09:44 PM
01/13/15 09:44 PM
Posts: 9,882 MI, usa
dvw
MI, usa
[Re: earthmover]
#1729289
01/13/15 09:55 PM
01/13/15 09:55 PM
Quicktree
[Re: dvw]
#1729290
01/13/15 09:59 PM
01/13/15 09:59 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
Volt gauge
I like that idea...Im gonna steel it Thanx
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: earthmover]
#1729291
01/13/15 10:08 PM
01/13/15 10:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Forget the tach.. just use a shift light.. then the gauges.. I run oil pressure, water temp, trans temp, volts, engine vac(not intake vac)... the water and trans temps are 1 gauge with a switch to toggle between them ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Quicktree]
#1729294
01/18/15 03:30 AM
01/18/15 03:30 AM
Posts: 2,449 nc
earthmover
nc
take a look at one of these
http://www.racepak.com/Drag_Racing/LDX.php
can any of you guys using 1 answer a few questions for me.....
does it come with everything needed to be used.. what makes it so much better then the normal tech oil water volt temp set up.. just looking at both sides and figuring out whats needed to make it work and cost at the end for what we will be doing ...
not trying to be cheap here at all just trying to see if something like that is a must for the car...if it works out to be better then no problem .. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: earthmover]
#1729295
01/18/15 03:54 AM
01/18/15 03:54 AM
MR_P_BODY
Some sensors would come with it but expect to buy some.. the race pac sensors are pricey ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1729296
01/18/15 04:35 PM
01/18/15 04:35 PM
Posts: 1,559 Michigan
Kiddart
Sorry guys I cant find a price for the Dash version, how much is it
Its awesome
Thank you Kiddart
