gauges and tech for race car #1729286
01/13/15 08:52 PM
01/13/15 08:52 PM
nc
E
earthmover Offline OP
E
nc
ok guys what gauges beside oil water volts and shift light tech you guys running ..full race car any pics would help...chassis shop is making a dash for the car so they can do bout whatever needed
Re: gauges and tech for race car [Re: earthmover] #1729287
01/13/15 09:42 PM
01/13/15 09:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run a temp gauge with 2 senders. One for the trans temp. One for engine oil temp. I use a switch to change back and forth. I also have fuel pressure , brake pressure(I foot brake) and a vacuum gauge (I run a pump). Ran out of room so the vacuum gauge is in the glove box. I don't need it every pas. I open the door if I need to check it. The volt gauge is a smaller 2" model mounted where the nitrous switch's were in the switch box. I also have a second voltmeter in the trunk by the battery.
Doug
Re: gauges and tech for race car [Re: dvw] #1729288
01/13/15 09:44 PM
01/13/15 09:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Volt gauge
Re: gauges and tech for race car [Re: earthmover] #1729289
01/13/15 09:55 PM
01/13/15 09:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
take a look at one of these
http://www.racepak.com/Drag_Racing/LDX.php
Re: gauges and tech for race car [Re: dvw] #1729290
01/13/15 09:59 PM
01/13/15 09:59 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Volt gauge
I like that idea...Im gonna steel it Thanx
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: gauges and tech for race car [Re: earthmover] #1729291
01/13/15 10:08 PM
01/13/15 10:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Forget the tach.. just use a shift light.. then the
gauges.. I run oil pressure, water temp, trans temp,
volts, engine vac(not intake vac)... the water and
trans temps are 1 gauge with a switch to toggle between
them
Re: gauges and tech for race car [Re: earthmover] #1729292
01/13/15 11:33 PM
01/13/15 11:33 PM
Az
Crizila Offline
Crizila  Offline
Az
I run an oil temp gauge because my block is 3/4 filled - and a boost and AF gauge.
Fastest 300
Re: gauges and tech for race car [Re: Crizila] #1729293
01/14/15 12:49 AM
01/14/15 12:49 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Some kind of AFR gauge is on my list to add this year...Other than that, Tach, water temp, and oil pressure...And a Fuel pressure gauge or an idiot light is also really good to have..
Re: gauges and tech for race car [Re: Quicktree] #1729294
01/18/15 03:30 AM
01/18/15 03:30 AM
nc
E
E
nc
can any of you guys using 1 answer a few questions for me.....
does it come with everything needed to be used..
what makes it so much better then the normal tech oil water volt temp set up..
just looking at both sides and figuring out whats needed to make it work and cost at the end for what we will be doing ...
not trying to be cheap here at all just trying to see if something like that is a must for the car...if it works out to be better then no problem ..
Re: gauges and tech for race car [Re: earthmover] #1729295
01/18/15 03:54 AM
01/18/15 03:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Some sensors would come with it but expect to buy
some.. the race pac sensors are pricey
Re: gauges and tech for race car [Re: MR_P_BODY] #1729296
01/18/15 04:35 PM
01/18/15 04:35 PM
K
Kiddart Offline
Kiddart  Offline
K
Sorry guys I cant find a price for the Dash version, how much is it
Its awesome
Thank you
Kiddart
Re: gauges and tech for race car [Re: MR_P_BODY] #1729297
01/18/15 04:36 PM
01/18/15 04:36 PM
nc
E
E
nc
not a lot of info out there on this...thought more would be using them ...kinda pricey also compared to the old set up
