Valve weight tech, stainless to titanium difference #1728195
01/12/15 06:36 PM
01/12/15 06:36 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Just posting some info that I was always curious about and finally tested today. I am in the process of porting one of the sets of B1 heads I have for this years build and did a weigh test on a 2.300 stainless valve and 2.300 titanium valve.
Stainless valve 150 grams
titanium valve 105 grams
45 gram difference which at 7500 RPM equals more than I figured but it comes with a pretty high cost difference. Durability would be a big factor on valve spring and rocker life. I weighted a few things to give you an idea of how much 45 grams equals. This is one of my 1/4 inch shank double-cut carbide head porting burrs and it weights 40 grams.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728196
01/12/15 07:51 PM
01/12/15 07:51 PM
gregsdart Offline
gregsdart  Offline
I've read Ti valves are typically worth 800 rpm in valve train stability, and I would think a horsepower increase of some sort below that? I wish they were in my budget,,,,,,,,
Re: Valve weight tech, stainless to titanium difference [Re: gregsdart] #1728197
01/12/15 08:07 PM
01/12/15 08:07 PM
PA.
"Little"John
"Little"John
PA.
Exhaust valves are 115 grams and 85 grams
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728198
01/12/15 08:20 PM
01/12/15 08:20 PM
gregsdart Offline
gregsdart  Offline
John, I have no data to back this up, but wonder if the TI intake valves would offer a horsepower increase, while the exhaust might not do much other than increase rpm range and parts life? What got me thinking is the intake closing is critical, more so than the exhaust closing.
Re: Valve weight tech, stainless to titanium difference [Re: gregsdart] #1728199
01/12/15 08:39 PM
01/12/15 08:39 PM
PA.
"Little"John
"Little"John
PA.
Not sure on that one Greg and the only reason I even have them is they came with a set of heads I bought years ago. Thinking I may start out with the older set of heads and stainless valves as this will be a learning year with nitrous
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728200
01/12/15 09:28 PM
01/12/15 09:28 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
So if you add that carbide to the titanium valve it equals the weight of a stainless valve? Thats huge
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728201
01/12/15 09:29 PM
01/12/15 09:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My set of B1 M/C had 2.4 ti valves... $130 each for
the intakes
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728202
01/12/15 09:40 PM
01/12/15 09:40 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
2/3 the weight.......2/3 the spring pressure required?
Instead of 300# on the seat, now only 210# ?
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728203
01/13/15 12:23 PM
01/13/15 12:23 PM
PA
Z
zooom Offline
zooom  Offline
Z
PA
Not to mention the potential head flow increases from the reduced valve stem & guide size: typically 7 mm or less for Ti while equivalent size [head] SS valve will be >9 mm....
Re: Valve weight tech, stainless to titanium difference [Re: zooom] #1728204
01/13/15 02:59 PM
01/13/15 02:59 PM
PA.
"Little"John
"Little"John
PA.
true but in my case the stem sizes are both the same. I still will probably flow them both just for the heck of it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728205
01/13/15 03:26 PM
01/13/15 03:26 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Isn't the weight of the valve only a part of the reciprocating mass that the spring has to control??
i.e. lifters, pushrods, rockers, retainers and locks.
Joe
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728206
01/13/15 03:56 PM
01/13/15 03:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
So you would take 12.7oz off the intake (1.6oz ea.) side and 8.5oz off the exhaust (1.06oz ea.) side, just over 1lb 5oz that the valve springs don't have to move. Add light weight retainers and it would be a significant amount taken off.
Re: Valve weight tech, stainless to titanium difference [Re: pittsburghracer] #1728207
01/13/15 04:30 PM
01/13/15 04:30 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Look at it this way, would you add that much weight to all your valves if someone paid you a couple hundred bucks?
Re: Valve weight tech, stainless to titanium difference [Re: HotRodDave] #1728208
01/13/15 04:46 PM
01/13/15 04:46 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I don't think looking at the total weight is a clear picture, each spring has only one valve among all the other parts to control.
I'll give you that at a certain performance level it becomes a no-brainer but under, say 7500 RPMs I don't know if you will see either performance or longevity issues.
Of course if money is no object......
BUT, if someone were to make the cost a little easier on the wallet, they'd be standard issue on my eng.
Joe
Re: Valve weight tech, stainless to titanium difference [Re: jlatessa] #1728209
01/13/15 04:53 PM
01/13/15 04:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Even at 7500 there should be a longevity benefit as you can run a lot lighter tension spring.
Re: Valve weight tech, stainless to titanium difference [Re: HotRodDave] #1728210
01/13/15 05:02 PM
01/13/15 05:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I agree, the lightest springs to control a given RPM are what we should all have.
I would like to hear what Hughes or Barton and the like have actually seen in practice because of a change in valve weight alone.
Good topic...Joe
Re: Valve weight tech, stainless to titanium difference [Re: jlatessa] #1728211
01/13/15 05:14 PM
01/13/15 05:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good topic...Joe
A lot of times the guy puts the ti valve in to lighten
the over all weight BUT normally they plan on turning
up the revs.. I went that way to turn 9000 plus rpm
Re: Valve weight tech, stainless to titanium difference [Re: MR_P_BODY] #1728212
01/13/15 08:53 PM
01/13/15 08:53 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
the intakes
I was just thinking the same thing, when they quoted titanium valves for the hemi they were about that price each. To rich for what I needed.
Re: Valve weight tech, stainless to titanium difference [Re: jlatessa] #1728213
01/13/15 10:53 PM
01/13/15 10:53 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
Joe
We can get really into this if you like, but let's start with the basics. What's the purpose of the spring?
1. bring the valve back up via the retainer after opening.
2. Yes, permit the roller wheel or flat tappet to stay in contact with the backside of the cam lobe.
Also, think of it this way, during the opening and closing process of the valves, there isn't any lash or separation between the components of the cam and valve train (at least there isn't suppose to be).
We can get into fulcrum lengths and pivot lengths too if you want. It's all mechanics and levers that dictate the pressure required.
Re: Valve weight tech, stainless to titanium difference [Re: R5P7 Bantam] #1728214
01/13/15 11:20 PM
01/13/15 11:20 PM
In a house near you
Street Monkies Offline
In a house near you
The best way to figure out what you need is to put a engine on a spintron. Very expensive and some engine builders have access to them. With this you can find out what valve springs pressures you can run, lifter bounce, how stable the valve train is at high rpm, ect.
