Freeze plug problems???????????????? #1727438
01/11/15 10:25 PM
01/11/15 10:25 PM
TN
65racer Offline OP
2009 IHRA World Champion
65racer  Offline OP
TN
Hey guy's what kind of sealer do you use
on a freeze plug instalation,,,,,,,I have always
used the #1 brown sealer on mine,,,,,, but I have a
'68 hp block and have had issues with the plugs
for the last 3 seasons,,,,,,just had it out to
freshen it up,,,,,,and went back with the brass
again,,,,,,,fired it up yesterday and already
have 2 leaking,,,,,,,I have ran it since I put
it in the car with the rubber expansion plugs
cause I had problems with it from the get go,,,
and was wondering if it is a problem with the block
other than my installation technique,,,guess it's
rubber biscuit time again,,,,,,really po'ed about
this block,,,,,but It's still usable so it will
get used up.........
Re: Freeze plug problems???????????????? [Re: 65racer] #1727439
01/11/15 10:38 PM
01/11/15 10:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Get it real hot and use a sealer in the cooling system, it'll seal it up. There's several, I have used Barrs leak quite a few times with success every time.
For a crack or a bad leak, K & R Block seal will work...forever. I have used both and K & R is forever and the best there is.
So will Barrs leak, last forever, on like your new freeze plugs.
I have always used reg clear silicone II right of the caulking gun tube that I got at the hardware store on core plugs on cast iron blocks and have never had a leak. It has never failed me, better than say blue silicone, imo.
several times I have installed fresh rebuilt motors for friends/customers that I didn't build or work on to find a core plug leaking on fire up. I used Barrs leak and it stops it easy.
Re: Freeze plug problems???????????????? [Re: 65racer] #1727440
01/11/15 11:25 PM
01/11/15 11:25 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
I have used the wider lip chevy 1 5/8" plugs along with the black permatex sealer on many motors without any leaks ,hope this helps.
Re: Freeze plug problems???????????????? [Re: hankcrank] #1727441
01/11/15 11:42 PM
01/11/15 11:42 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
If your having multiple leaks , it may be your installation technique. After the old plug is removed , really clean up the lip edge on the block and look for pits. I always use plumbers pipe dope. It's real gooey and doesn't get super hard and brittle . Start the new frost plug into the hole with socket that fits snugly into the frost plug. When you have the plug started, use a little larger socket or any flat face piping so it fits the lip of the plug and hammer in place . I use a piece of brass that I have cut to fit the plug. It's a lot easier with the engine out but I have installed plugs using the brass and air impact hammer while engine was in car .
Re: Freeze plug problems???????????????? [Re: mopar_man] #1727442
01/11/15 11:46 PM
01/11/15 11:46 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
You know those are not really freeze plugs but are there to clean the sand out after the block is cast. I use brass plugs and JB Weld. Never had one leak or blow out. Brass does not corrode/rust like steel plugs do. Re placing them could be a job but I ain't never replaced one so I don't know.
Re: Freeze plug problems???????????????? [Re: 65racer] #1727443
01/11/15 11:49 PM
01/11/15 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is what I use... put some Permetex around it
and put it in and tighten it up
Re: Freeze plug problems???????????????? [Re: MR_P_BODY] #1727444
01/11/15 11:51 PM
01/11/15 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Another view
Re: Freeze plug problems???????????????? [Re: MR_P_BODY] #1727445
01/12/15 12:44 AM
01/12/15 12:44 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
i have seen those before,where do you get those and who makes them?
SFI 25.5 depends,no leak,even at 213 mph....
Re: Freeze plug problems???????????????? [Re: dakotawilly] #1727446
01/12/15 12:57 AM
01/12/15 12:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I get them from my local parts store..
its a common brand name but I forget.. but the parts
store should know... its a very common company in
the freeze plug business
Re: Freeze plug problems???????????????? [Re: MR_P_BODY] #1727447
01/12/15 01:02 AM
01/12/15 01:02 AM
dakotawilly Offline
dakotawilly  Offline
mccord?
Re: Freeze plug problems???????????????? [Re: 65racer] #1727448
01/12/15 01:05 AM
01/12/15 01:05 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would go the sealer route first, you have new plugs in there.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Freeze plug problems???????????????? [Re: dakotawilly] #1727449
01/12/15 01:09 AM
01/12/15 01:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
mccord?
I dont think it was that... I have a box of them either
in the shop or the trailer... I'll check tomorrow
Re: Freeze plug problems???????????????? [Re: MR_P_BODY] #1727450
01/12/15 01:14 AM
01/12/15 01:14 AM
dakotawilly Offline
dakotawilly  Offline
or prob dorman,i like the looks of those over std freeze plugs.let me know what you find out,thx.....
Re: Freeze plug problems???????????????? [Re: dakotawilly] #1727451
01/12/15 01:19 AM
01/12/15 01:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats it... dorman... they can look up the sizes
in their book
Re: Freeze plug problems???????????????? [Re: MR_P_BODY] #1727452
01/12/15 11:30 PM
01/12/15 11:30 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Mr P that was the ones I was going to recommend.I did have rubbers in my 440 and they lasted years.Now all brass.But the solid screw type you posted we used at work a lot.Never had one leak or come out and they saw tens on thousands of miles.Rocky
Chrysler Firepower
Re: Freeze plug problems???????????????? [Re: therocks] #1727453
01/13/15 12:13 AM
01/13/15 12:13 AM
I always use the deep steel plugs and JB weld never had an issue ever--I feel like the steel fits tighter for sure--it is also very important to check each hole and smooth out those digs and gouges made when removing old ones--I use the tootsie roll and then even JB the streak or gouge--then plenty of JB weld---I also have a driver made from diesel wrist pin that fits the 1 5/8ths units perfect so not to distort--I ALWAYS use the deeper ones figuring they have more sealing surface and will not distort--brass is a fad from the past--They are too soft these days cheaper alloy I bet. And..I agree that a dose of stopleak is smart no matter what you are working on--
Re: Freeze plug problems???????????????? [Re: Cudajon] #1727454
01/13/15 12:47 AM
01/13/15 12:47 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Same here, after almost wrecking my 69 Dart when a freeze plug flew out on the track I started using JB-Weld on all my freeze plugs.
Re: Freeze plug problems???????????????? [Re: ProSport] #1727455
01/13/15 12:58 AM
01/13/15 12:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a freeze plug blow out on me twice in 2 weeks..
same hole..on the track... I thought I was flexing
the block..then I changed over to the ones I showed
and never had another issue and those plugs are still
in that engine.. but now that engine is in the land
down under.. sold it to a guy in Australia
