Page 3 of 3 1 2 3
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725950
01/13/15 03:20 PM
01/13/15 03:20 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Shawn, I bought locally in stock at the Severna Park store. Still a few miles from you, but maybe worth checking.
Shawn it is this gauge from Autozone
Sunpro/Custom line electrical voltmeter
Product Search
Not Vehicle Specific
Part Number: CP7985
Alternate Part Number: CP7985
Pick Up In Store:
Out of Stock
Features & Benefits
Sunpro Custom Line gauges feature a clean, easy-to-read look with blue line styling against the black 2 In. dial face. Monitor alternator performance and output from 8 to 18 V with the Custom Line 2 In. black dial face electric voltmeter.
Features black bezel and removable black mounting panel
Includes gauge and mounting hardware, requires hook-up wire
Designed for 12 Volt negative ground systems, and includes 12 Volt internal lighting
8 to 18 Volt, 60° sweep
Product Details
Part Number: CP7985
Weight: 0.45 lbs
Type: Voltmeter
Face: 2 in.
Bezel Color: Black
Depth (in): 3
Face Color: Black
Function: Analog
Height (in): 7
Liquid Filled: No
Measures: Volts
OEM Replacement: Yes
Pointer Color: Red
Range: 8 To 18 Volts
Sensor Type: Electric
Sweep Degree: 60
Width (in): 4.25
Writing Color: White
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Vert] #1725951
01/13/15 03:34 PM
01/13/15 03:34 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Thanks man! I will look. It is cheap ($13.99)
I have a few things to get to this year on the car....
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: wally426ci] #2854223
12/02/20 11:06 AM
12/02/20 11:06 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I just finished mine yesterday, started with a rusty oil pressure gauge, removed the faceplate, cleaned it up with muratic acid. I then drilled to match the new autometer volt meter faceplate with some trimming, painted, installed the decal and screwed it together. The hardest part was aligning the 2 faceplates to get it to drill on center and vertical. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Page 3 of 3 1 2 3
