Re: Converting an AMP gauge to a VOLT gauge at home?
[Re: GLR]
#1725950
01/13/15 03:20 PM
01/13/15 03:20 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
Shawn, I bought locally in stock at the Severna Park store. Still a few miles from you, but maybe worth checking. Quote:
Shawn it is this gauge from Autozone
Sunpro/Custom line electrical voltmeter Product Search
Sunpro/Custom line electrical voltmeter Not Vehicle Specific Part Number: CP7985
Alternate Part Number: CP7985 Pick Up In Store: Out of Stock
Features & Benefits
Sunpro Custom Line gauges feature a clean, easy-to-read look with blue line styling against the black 2 In. dial face. Monitor alternator performance and output from 8 to 18 V with the Custom Line 2 In. black dial face electric voltmeter.
Features black bezel and removable black mounting panel Includes gauge and mounting hardware, requires hook-up wire Designed for 12 Volt negative ground systems, and includes 12 Volt internal lighting 8 to 18 Volt, 60° sweep
Product Details Part Number: CP7985 Weight: 0.45 lbs Type: Voltmeter Face: 2 in. Size: Black Face Bezel Color: Black Depth (in): 3 Face Color: Black Function: Analog Height (in): 7 Liquid Filled: No Measures: Volts OEM Replacement: Yes Pointer Color: Red Range: 8 To 18 Volts Sensor Type: Electric Sweep Degree: 60 Width (in): 4.25 Writing Color: White
[Re: wally426ci]
#2854223
12/02/20 11:06 AM
12/02/20 11:06 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I just finished mine yesterday, started with a rusty oil pressure gauge, removed the faceplate, cleaned it up with muratic acid. I then drilled to match the new autometer volt meter faceplate with some trimming, painted, installed the decal and screwed it together. The hardest part was aligning the 2 faceplates to get it to drill on center and vertical. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
