Page 1 of 3 1 2 3
Converting an AMP gauge to a VOLT gauge at home? #1725910
01/09/15 04:45 PM
01/09/15 04:45 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
With the help of Moparts members ,I tested all my gauges and they all work!...Thank you!
My next question is; I know I can send my AMP gauge out to have it converted to a VOLT Gauge, but wanted to know if anyone has done this at home? If so.. can someone walk me through the process?
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725911
01/09/15 05:02 PM
01/09/15 05:02 PM
Andrewh Offline
Andrewh  Offline
not exactly convert but swap.
https://board.moparts.org/ubbthreads/show...amp;Search=true
they make various ones that point up or down.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Andrewh] #1725912
01/09/15 06:23 PM
01/09/15 06:23 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I've been wanting to do the same thing, I just wish someone would make those vinyl sticker kits w/ one to convert a sunpro volt meter in place of the ampmeter but have the same colors & font's as the OEM gauges...that way it would look truly OEM.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: shanker] #1725913
01/09/15 06:42 PM
01/09/15 06:42 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: CSK] #1725914
01/09/15 07:49 PM
01/09/15 07:49 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Stand by... I am working on my volt gauge conversion for 71-74 B-body..I will take a picture when completed if anyone is interested..message me or e-mail me; glr7069@ptd.net
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: CSK] #1725915
01/10/15 01:17 PM
01/10/15 01:17 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
web page
I'm trying to do it to a 74 Ramcharger I'm doing an OEM restoration of the dash on....so those are no go for me
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: shanker] #1725916
01/10/15 05:51 PM
01/10/15 05:51 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
As I showed in the article you can probably use the original face plate. It will not be reading amps but volts. You want be able to tell how much voltage though.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Cudajon] #1725917
01/10/15 07:43 PM
01/10/15 07:43 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I worked on my conversion from my original AMP gauge to an aftermarket VOLT gauge. I am posting pictures of the gauge installed into the original housing <-that I had to modify.
I removed the "aftermarket gauge Face" and drilled the "original gauge Face" so that I could use the original screws that held on the aftermarket face to the aftermarket volt gauge.
Tested after I installed and works great!... It took me about 10 hours to do this conversion.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725918
01/10/15 07:43 PM
01/10/15 07:43 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
2ND PIC
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725919
01/10/15 07:44 PM
01/10/15 07:44 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
3RD PIC
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725920
01/10/15 07:45 PM
01/10/15 07:45 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
4th picture
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725921
01/10/15 08:54 PM
01/10/15 08:54 PM
Looks good to me & in fact I'd speculate that to the untrained (non Mopar) eye they would not even suspect that it ain't OE
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: RapidRobert] #1725922
01/10/15 09:11 PM
01/10/15 09:11 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks Robert!...
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725923
01/10/15 10:02 PM
01/10/15 10:02 PM
Europe
rory73 Offline
rory73  Offline
Europe
That's quite cool, thanks for sharing!
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725924
01/10/15 11:16 PM
01/10/15 11:16 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Well done! Looks really good & you'll be at ease with not having to worry about a faulty or corroded ammeter. I've done the voltmeter conversion twice & glad I did.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Triggerfish] #1725925
01/10/15 11:26 PM
01/10/15 11:26 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you Tim and Buzz...
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725926
01/11/15 10:00 AM
01/11/15 10:00 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Very nice work, Gary. What brand gauge did you use?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: I_bleed_MOPAR] #1725927
01/11/15 10:18 AM
01/11/15 10:18 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Tim, I used a Sunpro gauge part number CP7985
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725928
01/11/15 03:11 PM
01/11/15 03:11 PM
Buford, GA
Buford, GA
'71 Charger 383/727
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: I_bleed_MOPAR] #1725929
01/11/15 03:42 PM
01/11/15 03:42 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you!...
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725930
01/11/15 05:47 PM
01/11/15 05:47 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Did you also change the needle? usually the sunpro is red.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Mr340] #1725931
01/11/15 05:55 PM
01/11/15 05:55 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
No I cut the needle to the same size as the originals and painted the needle the correct/matching orange.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725932
01/11/15 06:24 PM
01/11/15 06:24 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Yea I guess that's what I should've done. i may pull mine out and redo it.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Mr340] #1725933
01/11/15 07:05 PM
01/11/15 07:05 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Just an FYI... The number size is 1/4" Helvetia style. for the 71-74 B-body anyway... Not sure about the E-body, I haven't done one in awhile.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725934
01/11/15 07:09 PM
01/11/15 07:09 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Thanks, I might try painting the needle the proper color and changing the blue stripe to white, and leave the numbers as is.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Mr340] #1725935
01/11/15 08:07 PM
01/11/15 08:07 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
I like this idea. I bought this SunPro voltmeter because its the only one I could find for this purpose. The other closest voltmeter I could find is a vintage Smith volmeter from an MGB. And they varied by year.
Smiths voltmeter
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Vert] #1725936
01/11/15 08:15 PM
01/11/15 08:15 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yea..Finding one with the correct undersweep is not common. The Sunpro gauge is a lot cheaper but the Smith gauge may be a better quality gauge..I am not sure.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725937
01/11/15 10:26 PM
01/11/15 10:26 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
MGB and most British sports cars used Lucas electrical components. Lucas ak The Prince of Darkness. I always carried gun *GUM* with foil wrappers to replace the popped fuses I had regularly. It would get you home, and doubled for setting timing in a pinch.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Vert] #1725938
01/12/15 08:05 AM
01/12/15 08:05 AM
Buford, GA
Buford, GA
... I always carried gun ...
Tim
'71 Charger 383/727
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: I_bleed_MOPAR] #1725939
01/12/15 01:17 PM
01/12/15 01:17 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
How about the Dodge pickup guys. My amp gage fried years ago before I bought the truck. The previous owner cut the wires and put in an after market gage. Works OK, but I really don't like the look. Here's a pic to let you see what I mean (you can see the after market gage lower right of the Tuff wheel spoke).
URL=http://s51.photobucket.com/user/duster416/media/myampgage0012_zps6a9bd5b0.jpg.html][/URL]
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: bigblock340power] #1725940
01/12/15 01:21 PM
01/12/15 01:21 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I haven't converted a Dodge Truck recently. The last two that I did , I customizes the complete gauge clusters. I think yours could be done with out too much problem.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725941
01/12/15 06:57 PM
01/12/15 06:57 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Easy one. Just go get a gage and do it. Do try and use a good gage. Also while your in there check the 5volt limiter. The newer trucks used a electronic unit, it will be mounted on the pc board. I'll bet you can find everything you need at a salvage yard. Pick up a spare Instrument panel if you can and experiment away.
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Cudajon] #1725942
01/13/15 04:18 AM
01/13/15 04:18 AM
Elk Grove, Calif.
Elk Grove, Calif.
I do have an extra Instrument panel.
Any ideas as to what gage to look for (and 5 volt limiter)? Out of what year trucks (would help me to narrow down the search)?
Thanks,
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Mr340] #1725943
01/13/15 09:06 AM
01/13/15 09:06 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
What Sunpro gauge is this? I need to do the rallye dash in my 71 Challenger...
Looks nice!
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: bigblock340power] #1725944
01/13/15 09:10 AM
01/13/15 09:10 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
To the truck guys. I run this in my Sweptline and it is working out pretty well:
http://www.ebay.com/itm/Summit-Electrica...=item5b07cc5d0c
Here is my How-To text from the Sweptline site:
Ok, I struck out twice trying to locate a volt gauge that I could install in place of my AMP gauge. I normally like everything to be factory but I started wondering after my electrical melt down that took place at the end of the summer.
First I ordered an NOS gauge from an early Chevette (i know :joker ) but USPS lost it. Then I ordered a 95 Jeep piece but when it came I couldn't figure out how in the heck to hook it up or mount it.
I found this little Gem from Summit:
Here you can see where I have removed the metal face ring. AFter that I went around the glass seal (thin black metal) and pried it back with a flat screw driver (along the seam). Once I had those 2 pieces off, I un-bolted the mounting nuts from the back of the canister and slid it out. What I was left with was a bare gauge with 2 studs similar to the AMP gauge.
The face is made of thin plastic. The bulb that comes with the gauge is a push in style filament. I grabbed some green LED bulbs to use in my gauges and radio.
You will see that I test fitted it with a 68 style gauge face and then an earlier round gauge face but using the 68 housing. You could mount it lower in the housing in order to show the numbers better. At the moment I don't know if I will just cover the Summit logo or if I will use the gauge overlay to make it appear like an AMP gauge. The one small problem is going to be that it is round and the stock gauge is sqaured off. The problem will result in some of the sticker overhaning with nothing to stick to. Leaving it alone will result in a bit of air space between the outside of the gauge and the faceplate.
At the moment (untested) I have it mounted in the housing with the 2 studs. 1 will receive ground simply by being directly bolted to the housing which grounds with mounting and via a white wire that runs to the fuse block mounting screw(s). I isolated the positive side with a firewall grommet found at NAPA. Outer diameter of that grommet is 7/16" with roughly a 1/4" opening. I drilled out one of the factory AMP gauge holes and left it centered where the original gauge was.
Here is a link to the white gauge overlays (you can get any color or go black for an extra $30 ale a little pricey for "stickers"
I could get really creative and remove the plastic gauge face and replace it with the AMP gauge face but the mounting holes are slightly off so I would have to have an adapter. I thought about cutting up another gauge for the thin aluminum to use as an adapter but not thinking that I'll go that way.
I need to add pictures if anyone here is interested...
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: wally426ci] #1725945
01/13/15 09:12 AM
01/13/15 09:12 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Nudder
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: wally426ci] #1725946
01/13/15 09:14 AM
01/13/15 09:14 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
The summit gauge next to an original AMP gauge (68 dodge truck)
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: wally426ci] #1725947
01/13/15 09:26 AM
01/13/15 09:26 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Shawn it is this gauge from Autozone
Sunpro/Custom line electrical voltmeter
Product Search
Not Vehicle Specific
Part Number: CP7985
Alternate Part Number: CP7985
Pick Up In Store:
Out of Stock
Features & Benefits
Sunpro Custom Line gauges feature a clean, easy-to-read look with blue line styling against the black 2 In. dial face. Monitor alternator performance and output from 8 to 18 V with the Custom Line 2 In. black dial face electric voltmeter.
Features black bezel and removable black mounting panel
Includes gauge and mounting hardware, requires hook-up wire
Designed for 12 Volt negative ground systems, and includes 12 Volt internal lighting
8 to 18 Volt, 60° sweep
Product Details
Part Number: CP7985
Weight: 0.45 lbs
Type: Voltmeter
Face: 2 in.
Bezel Color: Black
Depth (in): 3
Face Color: Black
Function: Analog
Height (in): 7
Liquid Filled: No
Measures: Volts
OEM Replacement: Yes
Pointer Color: Red
Range: 8 To 18 Volts
Sensor Type: Electric
Sweep Degree: 60
Width (in): 4.25
Writing Color: White
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725948
01/13/15 10:09 AM
01/13/15 10:09 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Thanks!!
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: wally426ci] #1725949
01/13/15 10:45 AM
01/13/15 10:45 AM
Elk Grove, Calif.
Elk Grove, Calif.
OK, but what about '72 up?
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: GLR] #1725950
01/13/15 02:20 PM
01/13/15 02:20 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Shawn, I bought locally in stock at the Severna Park store. Still a few miles from you, but maybe worth checking.
Product Search
Part Number: CP7985
Pick Up In Store:
Out of Stock
Features & Benefits
Product Details
Part Number: CP7985
Weight: 0.45 lbs
Type: Voltmeter
Face: 2 in.
Bezel Color: Black
Depth (in): 3
Face Color: Black
Function: Analog
Height (in): 7
Liquid Filled: No
Measures: Volts
Pointer Color: Red
Sweep Degree: 60
Width (in): 4.25
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: Vert] #1725951
01/13/15 02:34 PM
01/13/15 02:34 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Thanks man! I will look. It is cheap ($13.99)
I have a few things to get to this year on the car....
Re: Converting an AMP gauge to a VOLT gauge at home? [Re: wally426ci] #2854223
12/02/20 10:06 AM
12/02/20 10:06 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I just finished mine yesterday, started with a rusty oil pressure gauge, removed the faceplate, cleaned it up with muratic acid. I then drilled to match the new autometer volt meter faceplate with some trimming, painted, installed the decal and screwed it together. The hardest part was aligning the 2 faceplates to get it to drill on center and vertical. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Page 1 of 3 1 2 3
