Few questions about '69 GTX's... #172555
12/21/08 07:28 PM
12/21/08 07:28 PM
AZ
Harlow383 Offline OP
AZ
I found a '69 GTX today. I've been doing a little research. I was hoping that the color of the bulge hood insert could tell you if the car had an air grabber or not. From what I understand the color depends if the car had the performance hood treatment or not. Is that correct? Does anyone know if steel wheels were just an option or did steel wheels come with only certain options/one of the two engine options? The center caps (is that the correct term?) on this car aren't the typical dog dishes they look kind of like an upside down bucket and have the Plymouth emblem in the center. Thats about as good as I can describe them. Unfortunately the pictures I have won't show much detail.
Re: Few questions about '69 GTX's... [Re: Harlow383] #172556
12/21/08 07:38 PM
12/21/08 07:38 PM
owt west
Thread Ender1 Offline
owt west
Yes, If it were to have a Air grabber hood it would have orangish wire mesh in the hood vents, it not black block offs with fins. I dont think what hood treament color would matter.? I believe it could have dog dishes but not sure on the insignia.
Re: Few questions about '69 GTX's... [Re: Harlow383] #172557
12/21/08 08:06 PM
12/21/08 08:06 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The Hemi cars had the Air Grabber and 15" steel wheels/caps as standard, wheel covers were optional. These are the caps.
The 440 cars had the Air Grabber optional, N96 on the fender tag , 14" steel wheels/caps standard. Optional wheels were 14" Rallye and 15" steel. Both 14" and 15" wheels had optional wheel covers available.
Most Air Grabber screens were red, a few may have been black, hood stripes, V21 on fender tag, had little or nothing to do with screen color.
Re: Few questions about '69 GTX's... [Re: Harlow383] #172558
12/21/08 08:09 PM
12/21/08 08:09 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The caps you describe sound like '68 caps.
Re: Few questions about '69 GTX's... [Re: B5 Bee] #172559
12/21/08 08:17 PM
12/21/08 08:17 PM
AZ
AZ
B5 Bee - Thanks for all the info. I did a search for '68 GTX steel wheels after you mentioned they sounded like '68 caps. I think your right. The caps on this car definitely had the plymouth emblem right in the center. Someone must have changed wheels at some point because the car is definitely a '69. Or maybe the front clip was swapped at some point? All I can see is the front clip and the roof line. Is it possible for a early production '69 to get '68 caps?
Re: Few questions about '69 GTX's... [Re: Harlow383] #172560
12/21/08 09:07 PM
12/21/08 09:07 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
Scott, this X is not the Burgundy color one is it?
71 GTX 4sp Dana GY9 HD Road King
Re: Few questions about '69 GTX's... [Re: AZ-Nick] #172561
12/21/08 09:12 PM
12/21/08 09:12 PM
AZ
AZ
Hey Nick. From what I can see I think its black. Might be a weathered burgundy though?
Re: Few questions about '69 GTX's... [Re: Harlow383] #172562
12/21/08 09:16 PM
12/21/08 09:16 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
eastside or south side?
Re: Few questions about '69 GTX's... [Re: AZ-Nick] #172563
12/21/08 09:20 PM
12/21/08 09:20 PM
AZ
AZ
Is definitely on the south side of town but I'd consider it to be more south/east than south/central.
Re: Few questions about '69 GTX's... [Re: Harlow383] #172564
12/21/08 09:23 PM
12/21/08 09:23 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
hold on and I will post a picture
Re: Few questions about '69 GTX's... [Re: AZ-Nick] #172565
12/21/08 09:30 PM
12/21/08 09:30 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
I was told there were 2 X's in that area and I thought I found them both.
I found a 68 near Valencia and when I passed on it my buddy bought it, that is one that was in that area.
Then there was a 69, but it was Burgundy and I passed on that one also, it needed to much for a NOM X. Here is the picture of the Burgundy behind a fence, I took a picture from inside the yard, next to the car and you can see the street through the fence...... Is it the same fence?
Re: Few questions about '69 GTX's... [Re: AZ-Nick] #172566
12/21/08 09:35 PM
12/21/08 09:35 PM
AZ
AZ
hmmm no thats not the same car. I'm hesitant to post a picture of it. I'll send it to you in PM.
Re: Few questions about '69 GTX's... [Re: AZ-Nick] #172567
12/21/08 09:35 PM
12/21/08 09:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
'68 & '69 standard wheels & caps are interchangeable as far as the size of the hubcap goes. '67-'68 cap protrudes out from a recess just inside the outer perimeter of the cap, with the center area painted a satin black and the Plymouth emblem stamped into the center. In other words, the car could have its original steelies but with the wrong caps.
Re: Few questions about '69 GTX's... [Re: Harlow383] #172568
12/21/08 09:36 PM
12/21/08 09:36 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
go ahead
