Wheelwell undercoating/Sound deadener #1724181
01/07/15 08:31 PM
01/07/15 08:31 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I plan to do some wheelwell mods and want to recreate the factory appearance. The stuff used in most of the cars I've seen looks like it went on quite thick. Is this stuff the same as used on the backsides of the quarter panels visible inside the trunk? I've owned several 67-76 A body cars that had the textured treatment on the sides of the trunk, presumably to resist outward dents when objects in the trunk shifted during driving.
I'd guess that the original stuff was loaded with Asbestos and anything modern had to be EPA compliant.
Anyone care to spill the details on what to buy and where? I do need both the wheelwell type stuff as well as what was used in the trunk area. Thanks, Greg
Re: Wheelwell undercoating/Sound deadener [Re: Kern Dog] #1724182
01/07/15 09:17 PM
01/07/15 09:17 PM
NY
clemul Offline
clemul  Offline
NY
Re: Wheelwell undercoating/Sound deadener [Re: clemul] #1724183
01/07/15 09:25 PM
01/07/15 09:25 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Heck yeah! That might just be what I need.
Re: Wheelwell undercoating/Sound deadener [Re: Kern Dog] #1724184
01/08/15 02:10 AM
01/08/15 02:10 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
I have also used sprayable seam sealer with great results.
Re: Wheelwell undercoating/Sound deadener [Re: 340cpe] #1724185
01/08/15 02:16 AM
01/08/15 02:16 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
X2 for Resto Ricks stuff!
Re: Wheelwell undercoating/Sound deadener [Re: NV69B7RR] #1724186
01/08/15 09:35 PM
01/08/15 09:35 PM
MO
cdp Offline
cdp  Offline
MO
X3. Very very close to original.
Re: Wheelwell undercoating/Sound deadener [Re: cdp] #1724187
01/09/15 03:24 AM
01/09/15 03:24 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
The air pressure, distance from wheel well and spray technique will all affect the final appearance. If you're not getting the desired texture, try altering your application.
That said - x4 on Ricks undercoating, it's good stuff.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Wheelwell undercoating/Sound deadener [Re: 5wndwcpe] #1724188
01/09/15 04:56 AM
01/09/15 04:56 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Probably fair to say that a close spraying distance will allow it to build up like sheetrock spackle compound?
Re: Wheelwell undercoating/Sound deadener [Re: Kern Dog] #1724189
01/10/15 10:01 PM
01/10/15 10:01 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I include application instructions that gives tricks & techniques with undercoating purchase.
I'm close to offering an undercoating gun that has better control and will make it easier to get great results.
