aluminum drum in 727 #1723549
01/06/15 11:07 PM
01/06/15 11:07 PM
ky, usa
littlejohn44 Offline OP
ky, usa
I have my 727 getting a overhaul new valve body, new kit .bolt in sprag, and aluminum drum. The kit has the band for the cast drum. Where do yall get the red lined band for the aluminum drum? Is there any brand recommended?
Re: aluminum drum in 727 [Re: littlejohn44] #1723550
01/06/15 11:17 PM
01/06/15 11:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: aluminum drum in 727 [Re: J_BODY] #1723551
01/06/15 11:56 PM
01/06/15 11:56 PM
ky, usa
ky, usa
wow 100 bucks and 25$ core! Is that a going rate?
Re: aluminum drum in 727 [Re: littlejohn44] #1723552
01/07/15 12:16 AM
01/07/15 12:16 AM
Those drums are cool but they will wear out faster than a Walmart Tire---Coan and some others are doing Hybrid drums with steel sheel over aluminum for Powerglides--not sure about Mopars but--if you use one for bracket racing you are tossing cash in the trash--Class cars it is a must have to get that fraction of a second but otherwise...
Re: aluminum drum in 727 [Re: ] #1723553
01/07/15 12:24 AM
01/07/15 12:24 AM
DragtimeDodge Offline
I used billet steel drums in my 727s. Strong as hell and they last much longer than aluminum. It's a bracket car so I don't care if it slows me down a bit.
Re: aluminum drum in 727 [Re: DragtimeDodge] #1723554
01/07/15 12:45 AM
01/07/15 12:45 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Same here. I wouldn't bother with an aluminum drum for a bracket car. Just not worth the hassle and extra cost.
Re: aluminum drum in 727 [Re: WILD BILL] #1723555
01/07/15 12:51 AM
01/07/15 12:51 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Re: aluminum drum in 727 [Re: littlejohn44] #1723556
01/07/15 12:52 AM
01/07/15 12:52 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
you bought an aluminum drum and your quibbling over a $100 band?
Re: aluminum drum in 727 [Re: J_BODY] #1723557
01/07/15 01:09 AM
01/07/15 01:09 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
They can last a long time, heck mine is at least 15 years old, I haven't raced a whole lot last 3 years, but made average 100 passes a year for at least 10 years. You do have to keep the filter and fluid changed often, that use to be cheap, but tranny fluid has gotten pretty high. Right after I bought mine I started seeing some steels for sale, they haven't been around as long as the aluminum, if I was buying today Id go with steel probably, but the aluminum drum doesn't wear that fast.
Re: aluminum drum in 727 [Re: ] #1723558
01/07/15 01:33 AM
01/07/15 01:33 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've found very little wear on mine so far 100 passes. It picked my car up .10 @ 1.5 mph in the 1/8. No 1/4 mile mph improvement but it carried .13-.14 through to the end. I should mention that I had many passes with the A&A steel drum and the A&A aluminum drum. These results were averages of well over 100 passes.
Doug
Re: aluminum drum in 727 [Re: dvw] #1723559
01/07/15 11:25 AM
01/07/15 11:25 AM
ky, usa
ky, usa
i didnt buy it so much for the improved time as for the safety. When i started this project a couple years ago, i got a good deal it. Seeing pics of a tranny explode got me wanting to be as safe as i could be on the trans build.
Re: aluminum drum in 727 [Re: littlejohn44] #1723560
01/07/15 12:04 PM
01/07/15 12:04 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We switched from Aluminum to Billet Steel a while back. Car didn't slow at all. Only thing that changed was my fluid and filter would last the entire season rather than 25 passes like with the Aluminum drum.
Re: aluminum drum in 727 [Re: cl440] #1723561
01/07/15 12:13 PM
01/07/15 12:13 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mine showed no wear after five+ years racing. I got trans used. Would change fluid twice a year. Rick Allision had it apart last summer said it looked great and no dirt was getting in it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: aluminum drum in 727 [Re: 1967dartgt] #1723562
01/07/15 11:53 PM
01/07/15 11:53 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Had an a&a aluminum drum in mine, no significant wear after five years of street/ race use. Rick at A&A said he had seen some wear in the sealing ring area of some of the trans' he had apart. He seemed to think it was a fluid related problem, because it was random. some had it, some didn't I always used redline synthetic trans fluid.
I also used this drum as a safety feature more so than for quick spin-up.
Re: aluminum drum in 727 [Re: littlejohn44] #1723563
01/08/15 01:11 PM
01/08/15 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bolt in sprag ? which one ? I'm going to ASSuME that since you were shocked at the price of the red lined band that you are going for the basic replacment ? If so and the outer race is not loose in the case or damaged it's a COMPLETE WASTE OF TIME AND MONEY. If you are putting in a super or ulitamte sprag with more rollers then continue on ...
Street car or race ? Alum drum I don't think is street friendly ...
