Re: aluminum drum in 727
[Re: littlejohn44]
#1723552
01/07/15 12:16 AM
01/07/15 12:16 AM
Those drums are cool but they will wear out faster than a Walmart Tire---Coan and some others are doing Hybrid drums with steel sheel over aluminum for Powerglides--not sure about Mopars but--if you use one for bracket racing you are tossing cash in the trash--Class cars it is a must have to get that fraction of a second but otherwise...
[Re: DragtimeDodge]
#1723554
01/07/15 12:45 AM
01/07/15 12:45 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used billet steel drums in my 727s. Strong as hell and they last much longer than aluminum. It's a bracket car so I don't care if it slows me down a bit.
Same here. I wouldn't bother with an aluminum drum for a bracket car. Just not worth the hassle and extra cost.
[Re: littlejohn44]
#1723556
01/07/15 12:52 AM
01/07/15 12:52 AM
Posts: 13,194 aZLiViN
J_BODY
aZLiViN
wow 100 bucks and 25$ core! Is that a going rate?
you bought an aluminum drum and your quibbling over a $100 band?
[Re: J_BODY]
#1723557
01/07/15 01:09 AM
01/07/15 01:09 AM
Posts: 2,152 Fancy Farm Ky
wyoming
Fancy Farm Ky
They can last a long time, heck mine is at least 15 years old, I haven't raced a whole lot last 3 years, but made average 100 passes a year for at least 10 years. You do have to keep the filter and fluid changed often, that use to be cheap, but tranny fluid has gotten pretty high. Right after I bought mine I started seeing some steels for sale, they haven't been around as long as the aluminum, if I was buying today Id go with steel probably, but the aluminum drum doesn't wear that fast.
[Re: cl440]
#1723561
01/07/15 12:13 PM
01/07/15 12:13 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Mine showed no wear after five+ years racing. I got trans used. Would change fluid twice a year. Rick Allision had it apart last summer said it looked great and no dirt was getting in it.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1723562
01/07/15 11:53 PM
01/07/15 11:53 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Had an a&a aluminum drum in mine, no significant wear after five years of street/ race use. Rick at A&A said he had seen some wear in the sealing ring area of some of the trans' he had apart. He seemed to think it was a fluid related problem, because it was random. some had it, some didn't I always used redline synthetic trans fluid. I also used this drum as a safety feature more so than for quick spin-up.
[Re: littlejohn44]
#1723563
01/08/15 01:11 PM
01/08/15 01:11 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I have my 727 getting a overhaul new valve body, new kit .bolt in sprag, and aluminum drum. The kit has the band for the cast drum. Where do yall get the red lined band for the aluminum drum? Is there any brand recommended?
Bolt in sprag ? which one ? I'm going to ASSuME that since you were shocked at the price of the red lined band that you are going for the basic replacment ? If so and the outer race is not loose in the case or damaged it's a COMPLETE WASTE OF TIME AND MONEY. If you are putting in a super or ulitamte sprag with more rollers then continue on ...
Street car or race ? Alum drum I don't think is street friendly ...
