Gen 3 Hemi valve spring tool #1720727
01/03/15 02:34 PM
01/03/15 02:34 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Looking to see if anyone has a part number for a tool to remove valve springs from A Gen 3 with the heads ON the block. I use an OTC #4572 when the heads are off, but looking for a good head ON tool. Any recomendations of a known good tool??
If you like drag racing, support your local track.
Re: Gen 3 Hemi valve spring tool [Re: CHAPPER] #1720728
01/03/15 02:42 PM
01/03/15 02:42 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Mancini racing has a nice one. Expensive. But I bet you could make one for a fraction of the price. Matt. Part# MM57VSRT
Re: Gen 3 Hemi valve spring tool [Re: MattW] #1720729
01/03/15 07:33 PM
01/03/15 07:33 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I made one that uses the stock rocker shafts.
Mopar to the bone!!!
Re: Gen 3 Hemi valve spring tool [Re: 72Swinger] #1720730
01/04/15 12:31 PM
01/04/15 12:31 PM
Canada
onig Offline
onig  Offline
Canada
Any pics or links?
69 Dart
Re: Gen 3 Hemi valve spring tool [Re: onig] #1720731
01/04/15 04:01 PM
01/04/15 04:01 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Crane 99476-1
Did all 16 springs in the car with this - worked flawlessly...but make sure you keep the screw down lubed....
http://www.summitracing.com/int/parts/crn-99476-1.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen 3 Hemi valve spring tool [Re: Moparmal] #1720732
01/19/15 06:02 PM
01/19/15 06:02 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Gen 3 Hemi valve spring tool [Re: Moparmal] #1720733
01/19/15 07:23 PM
01/19/15 07:23 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Crane 99476-1
This is what I was thinking of. I built the shaft piece like in the picture and then a pull-down lever the first trial. That is when I found out that I only had 2 arms/hands and my first design required at least 3!! This one gives me some more ideas to try. Thanks.
