Testing circuit board out of car? #1720188
01/02/15 12:35 PM
01/02/15 12:35 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
Is there a way to test these circuit boards out of the car? I would like to know they all work before removing the dash. One of my blinker light contacts on the old board is toast. Thank you
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Testing circuit board out of car? [Re: 340wedge] #1720189
01/02/15 01:12 PM
01/02/15 01:12 PM
dogdays Offline
dogdays  Offline
Basically what I am seeing is a circuit board that looks like an assembly of really flat wires.
You could use an ohmmeter to check continuity between the two ends of each conductor, otherwise I think I'd be doing a visual check and then go on with the show.
R.
Re: Testing circuit board out of car? [Re: dogdays] #1720190
01/02/15 01:30 PM
01/02/15 01:30 PM
Andrewh Offline
Andrewh  Offline
I would put a bulb in each holder and wire 12 volts and a ground.
some run through 2 pins, the others appear to ground at screw holes.
shouldn't be too tough to verify they light up and light up well.
continuity doesn't prove they can support the load, just that there is a connection.
Re: Testing circuit board out of car? [Re: Andrewh] #1720191
01/02/15 02:06 PM
01/02/15 02:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
An ohmmeter is your best bet HOWEVER, if the circuit board isn't cracked and none of the copper strips are scored, its highly unlikely there will be any problems with it. From what I see in the photo I'd trust it to be good.
Before you put it in the car, lightly clean the contacts with a fine scotchbright pad to remove any oxidation.
Re: Testing circuit board out of car? [Re: Stanton] #1720192
01/02/15 03:55 PM
01/02/15 03:55 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
And of course your FSM...Factory Service Manual...will guide you through testing. You do have one yes????
Re: Testing circuit board out of car? [Re: 340wedge] #1720193
01/02/15 09:46 PM
01/02/15 09:46 PM
340wedge Offline OP
340wedge  Offline OP
Thank you all, I will use the Ohm meter, and yes I do have the factory manual, albeit on CD..
Re: Testing circuit board out of car? [Re: 340wedge] #1720194
01/05/15 04:52 PM
01/05/15 04:52 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I have had to solder the connector pins to the copper to get a reliable connection on one of mine. Other than that you can look at the board and see everything.
Re: Testing circuit board out of car? [Re: dynorad] #1720195
01/05/15 05:09 PM
01/05/15 05:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
An ohmmeter is good for gross faults, but a load (running lights in this case) will be better.
I have also soldered the pins, be a smart move to do it anyway since it's out. Clean up the bare copper where things connect, slip in a bulb and holder then light it up. If you are feeling real picky you can use a hair drier to heat things up and see if it fails then.
Don't be the exception.
