ProCharger F3? #1718903
01/01/15 03:10 AM
01/01/15 03:10 AM
Back home in PA
BulletBob Offline OP
Back home in PA
I'm going to be building a 478 & was thinking twin turbos until I went over to a buddy's shop & was talking about the CTD variable vane turbos & he says "we've went Whipple you want to buy three ProCharger F3s setup for Hemis"
I want a streetable low 9 1/4 ride he said they make 60 lbs boost right now & has multiple cog sets to change the boost
Any input will be greatly accepted Thanks ahead
Re: ProCharger F3? [Re: BulletBob] #1718904
01/01/15 12:59 PM
01/01/15 12:59 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
First thing you would need to know is what size F3 units they are. Making 60lbs I assume it would be a 139 or a newer 136. Are they geardrive or belt?
One day I will have something cool here.
Re: ProCharger F3? [Re: BulletBob] #1718905
01/01/15 01:15 PM
01/01/15 01:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I passed on a F1 a few years ago.. was very cheap
and I would have had to build the mounting plate..
I'm sorry I did.. but I didnt have the money
Re: ProCharger F3? [Re: MR_P_BODY] #1718906
01/01/15 01:24 PM
01/01/15 01:24 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
If you only want to run bottom 9's you sure won't have to spin it hard but will need a stout engine. 30lbs of boost on my f2 gets me bottom 7's @3300lbs.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: ProCharger F3? [Re: bigtimeauto] #1718907
01/01/15 01:28 PM
01/01/15 01:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
whats the total cost of an F2 setup for a small block?
Re: ProCharger F3? [Re: Quicktree] #1718908
01/01/15 02:35 PM
01/01/15 02:35 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
It depends on what model F3 you're looking at. For the goals you have in mind, I would recommend you stay away from the newer designs F3's (121, 130,136). They are very efficient, but in order for them to work correctly you will have to spin them hard. If not, the supercharger will be very lazy down low and become extremely temperamental to tune. One minute no boost and the next second 20lbs.
Re: ProCharger F3? [Re: bigtimeauto] #1718909
01/01/15 02:40 PM
01/01/15 02:40 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Bottom 7's that's what i'm talking bout.
Re: ProCharger F3? [Re: racerx] #1718910
01/01/15 07:27 PM
01/01/15 07:27 PM
Back home in PA
Back home in PA
The engines they came off of made over 1800 horse each & were run fat never leaned out far enough to find out what they really made
Re: ProCharger F3? [Re: BulletBob] #1718911
01/01/15 07:29 PM
01/01/15 07:29 PM
Back home in PA
Back home in PA
I'll get the #'s off them when I go back down
Re: ProCharger F3? [Re: BulletBob] #1718912
01/01/15 10:57 PM
01/01/15 10:57 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
The F3 is a serious unit and only a small part of the overall build , its like buying a propeller for a airplane .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: ProCharger F3? [Re: Quicktree] #1718913
01/02/15 11:47 PM
01/02/15 11:47 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
A lot
Re: ProCharger F3? [Re: 80arrow] #1718914
01/03/15 05:32 AM
01/03/15 05:32 AM
Q
Quicktree Offline
Quicktree  Offline
Q
A lot
send me a pm since no one else knows that thing still running?
Re: ProCharger F3? [Re: Quicktree] #1718915
01/03/15 06:19 AM
01/03/15 06:19 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I like the way you thinking
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: ProCharger F3? [Re: slammedR/T] #1718916
01/03/15 03:23 PM
01/03/15 03:23 PM
go green Offline
go green  Offline
Steve Morris has a SBC kit for $6000 you might get him to modify it but that will cost $$&$ also . Charge tube and v-bands can start at $500 and go to $2000 depending on how many clamps and if you have a inter cooler ( air - water will set you back $2000 for the box , water tank ,pump and hose ) If you go with a carburetor is a minimum of $1300 for car and hat for a good one is way over $2000 working . If you want to go EFI look at around $3500- $10,000 .
Your are looking at a minimum of $9000 and for the good stuff, around $17,000 to $20,000 .
For a carb fuel delivery you will need some sort of data logging system so add a extra $1000 -$2000+ for that .
Along with a good converter $1200-$2800
You have to make sure your transmition is good so throw away your 727 and put a t-400 or glide in $$$$ . Rear end and drive shaft $$$ . And so on .
There are some thrifty MF's out there that will barnyard their builds and say it will cost 1/2 but they are easy to spot a mile away . If you want to put on a power adder just to cruise around a act cool then so be it ,there are plenty of shops that will sell shiney parts .
Re: ProCharger F3? [Re: go green] #1718917
01/03/15 08:00 PM
01/03/15 08:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: ProCharger F3? [Re: Quicktree] #1718918
01/05/15 11:29 PM
01/05/15 11:29 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
well said!
Re: ProCharger F3? [Re: upnover] #1718919
01/07/15 12:26 AM
01/07/15 12:26 AM
Back home in PA
Back home in PA
I'm getting all of the plumbing hats EFI all of it
Re: ProCharger F3? [Re: BulletBob] #1718920
01/12/15 09:57 PM
01/12/15 09:57 PM
Back home in PA
Back home in PA
Update there are two 135's & a 139
The 139 needs a bearing in it but not one of the two big ones
I get the pumps, blocks & injectors all of it
Re: ProCharger F3? [Re: BulletBob] #1718921
01/13/15 12:23 PM
01/13/15 12:23 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
I would call and make sure they can still be rebuilt ans still have parts avaible. Those blowers were replaced by the 136 a couple yrs ago.
