Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717314
12/31/14 02:55 PM
12/31/14 02:55 PM
Yes the mechanical timing is highly likely OK (& if the #6 pushrods/rocker arms are at the same height (both open) that would for sure confirm this). I'm assuming firing order (CW) is correct/reluctor gap is correct. right now is the tooth near dead even with the magnet? Is the coil/ECU getting fire in ign2 (crank)? (pull the yellow wire off of the starter relay & have a helper turn the key to start & you check with your VOM or if you have a spare dist (from any cube eng) plug it in & spin it by hand & see if it makes the coil wire held 1/4" from ground spark with key in "run" and in "start"
Re: 360 ENGINE REBUILD WILL NOT START [Re: Mr.Yuck] #1717315
12/31/14 02:56 PM
12/31/14 02:56 PM
SO ILL
K
KISSFANN1 Offline OP
K
SO ILL
I am getting fuel to the cylinders.
As for the vacuum lines, I have not completely plugged them off.
The brake booster is open.
The EGR valve is connected to the carb.
Any others that I need to be concerned about?
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717316
12/31/14 03:15 PM
12/31/14 03:15 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
This is how the gears were set.
Some has posted that the dots should be @ 12 o-clock on both gears.
I'm a little confused.
Don't be confused , the engine can be timed in either position :
12 o'clock on crank .....12 on cam
6 on crank .......6 on cam
12 on crank .......6 on cam
6 crank .........12 on cam .The factory timed it so #1 is in front facing a little to the pass side . .
The crank , con rods or the piston at TDC don't know or don't care what stroke the engine is on. It's either the compression stroke or the exhaust stroke and its the cam that determines that. The cam turns at half speed of the crank and that's why you can have the marks 12/12 12/6, 6/12, 6/6 etc etc etc .. The problem arises when you have to get the electrical timing to match the mechanical timing , That's why you have to put the dist in one way and if its not in time you have to move it 180 degs . the dist in 1/1 ratio and turns the same speed as the cam.
So get #1 on the compression stroke at TDC , align the dist so the rotor is pointing at number one in the cap and if everything is else is ok ie: fuel , spark etc . the engine should fire. There are other things I can tell you but would only make it look difficult , do as I say and the engine will start .
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717317
12/31/14 03:41 PM
12/31/14 03:41 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That #6 intake valve looks pretty far into it's lift for piston being at top dead center. Normally when piston (#1 and #6 same time) is at top, the two valves should be overlapping, meaning exhaust is still closing and intake is beginning to open. That's what's happening at #6 when #1 valves are completely closed and ready to fire.
Re: 360 ENGINE REBUILD WILL NOT START [Re: buildanother] #1717318
12/31/14 04:12 PM
12/31/14 04:12 PM
SO ILL
K
K
SO ILL
So, if that is the case, do you have a suggestion on what I need to do to fix that?
Thanks,
SLD
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717319
12/31/14 08:04 PM
12/31/14 08:04 PM
With the dampener slit on zero (TDC) are the #6 rocker arms even (both open the same amt). This is a stock (symmmetrical) cam I'm assuming. If so the cam timing is Ok & we can move on to dist timing/fuel
Re: 360 ENGINE REBUILD WILL NOT START [Re: RapidRobert] #1717320
12/31/14 09:38 PM
12/31/14 09:38 PM
SO ILL
K
K
SO ILL
Let me start by saying, thanks to everyone's help.
I decided to get back into the gear set to verify the dot lineup.
Guess what, I did not have the rotation set correctly.
There were so many marks on the crank gear, I used the wrong one.
I set everything to the way it was supposed to be.
Cranked it and had plenty of backfire.
Rotated the distributor 180 and it fired off immediately.
It sounded great!!!
Tomorrow it will button up the fluids and break in the cam.
I will keep you all updated on the build.
SLD
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717321
12/31/14 09:49 PM
12/31/14 09:49 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Don't know if it was said, but dot to dot is not TDC.
Re: 360 ENGINE REBUILD WILL NOT START [Re: JonC] #1717322
12/31/14 11:12 PM
12/31/14 11:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
dot to dot is tdc for #6 & #1. TDC just means the piston is all the way up.
Re: 360 ENGINE REBUILD WILL NOT START [Re: stumpy] #1717323
01/02/15 01:37 AM
01/02/15 01:37 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Crank dot at 12:00 and cam dot at 12:00 is top dead center on the intake stroke. That is where you want to position the distributor at #1.
Aligning the two dots as indicated in the book is top dead center on the exhaust stroke which is 180* out with the distributor.
...FAFO...
Re: 360 ENGINE REBUILD WILL NOT START [Re: skicker] #1717324
01/02/15 01:53 AM
01/02/15 01:53 AM
chicagoland,usa
chicagoland,usa
Good thing he's got it running, because nobody lines up anything with crank dot at 6:00.
Re: 360 ENGINE REBUILD WILL NOT START [Re: skicker] #1717325
01/02/15 01:55 AM
01/02/15 01:55 AM
When crank dot is at 6 o'clock the #4 & #7 pistons are at TDC (maybe not exact enough TDC for cam degreeing but close enough for our dist timing we have in mind (but back on #1 or #6 tho). getting dot to dot at 6/12 is far easier than getting dot to dot at 12/12 cuz then (12/12) the crank snout is in the way of your steel scale. I get 6/12 & leave it there & time the intergear/dist to have #6 to the rear & slightly to the DR side. Want minimal cam turning
Re: 360 ENGINE REBUILD WILL NOT START [Re: buildanother] #1717326
01/02/15 02:52 AM
01/02/15 02:52 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Fixed it...
Maybe residual effects from last night...
...FAFO...
Re: 360 ENGINE REBUILD WILL NOT START [Re: skicker] #1717327
01/02/15 12:08 PM
01/02/15 12:08 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Fixed it...
If your referring to my post , of course they don't why make it difficult . I just tried to (unconfuse)lol him by showing how mechanical timing works.
At least he got it running , and that's a good thing .
Happy New year BTW
