360 ENGINE REBUILD WILL NOT START #1717294
12/29/14 12:12 PM
12/29/14 12:12 PM
SO ILL
K
KISSFANN1 Offline OP
K
SO ILL
Let me start by stating that I’m a good mechanic, but this is my first V-8 engine build.
Following the instructions from my Chilton’s manual, I have rebuilt a 360 engine in my 78 Power Wagon.
It will not start. It spit, sputters, and backfires.
I’m 99% sure I assemble the timing chain to the cam and crank with the #1 piston @ TDC.
The coil and ignition resistor checks out as OK.
I stuffed some tissue in the #1 spark plug hole. Once it popped out, the distributor rotor is pointing to the #1 spark plug wire on the cap.
I’m picking up today a compression gauge to check each cylinder.
What am I missing?
I would appreciate any suggestions that will help me through this struggle.
Thanks,
SLD
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717295
12/29/14 12:21 PM
12/29/14 12:21 PM
pa.
dan9 Offline
dan9  Offline
pa.
Maybe you need to turn the distributor 180 degrees. With the number one piston up it could be on the exhaust stroke instead of the compression stroke.
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717296
12/29/14 12:22 PM
12/29/14 12:22 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
How did you install the timming chain? How did you install the oil pump drive gear?
Re: 360 ENGINE REBUILD WILL NOT START [Re: gtsdude] #1717297
12/29/14 12:41 PM
12/29/14 12:41 PM
SO ILL
K
K
SO ILL
I have tried the 180 rotation of the distributor.
It did not help.
As for the chain installation, I can remember that the dots were lined up while the #1 cylinder was flush. The keyways on the cam and crank allowed the gears to go on. I did have a problem with lining up the oil pump shaft with the cam originally. I removed the intake and re-installed it to the manuals instructions. With the rotor pointing to the #1 plug wire, I assume that I have that shaft in the right location.
Make any sense?
SLD
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717298
12/29/14 12:53 PM
12/29/14 12:53 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Dot to dot on gears at 6 and 12 o'clock wih #1 on TDC puts #1 on intake stroke and #6 on compression stroke. So the oil pump drive gets pointed at #6 unless you rotate engine to get #1 up on compression stroke and then line it up to #1.
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717299
12/29/14 01:44 PM
12/29/14 01:44 PM
turn the crank to the (2) sweet spots (I'll see if I can find em) & preoil each head at each sweet spot. Then set the dampener timing marks on 15 BTDC. remove a valve cover & see if #1 or #6 valves (depending on which VC you pull) are open or closed. if you pull the dr cover & #1's rocker arms are closed then clock the intergear/dist so the rotor is forward & slightly to the pass side & plug in the #1 plug wire at that point. If the #1 cyls' rocker arms are open then clock the intergear/install dist so the rotor is pointing to the rear & slightly to the dr side & plug in the #6 plug wire at that point. have the vac can on the pass side with room to be turned either way and turn the housing till the magnet is dead even with the tooth and the rotor should be pointing at or close to the specific cap terminal & note that the can will shift the rotor (rotor phasing) CCW (on a SB) from the at rest/no vac/springs retracted position. Check the plug wire firing order (CW). No opinion on where there has been enough cranking to whether the intake should be removed & the cam regooped (cam failures are epidemic). read "breakin secrets" at www.mototuneusa.com make a mark on the dampener 2&1/4" CW from the TDC slit & have your helper set it to that when it fires (can plugged. Gun the eng repeatedly during the breakin. Any issues (leaks etc) shut it off immediately/fix it/restart/continue on. EDIT Do not do a compression test as that will further wipe the cam & there is no need for that test right now. MORE EDIT 90 deg BTDC #1 compression to oil pass head (your dampener may have 90 deg partial slits or cut a strip of paper 5.694" with your calipers to use as a ruler). 20 ATDC #6 compression (use the timing tab as a ruler to get the extra 5 deg) for drivers side oiling
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717300
12/29/14 02:07 PM
12/29/14 02:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sounds like your distrib is off or your t-chain is off. Have you turned the distrib while somebody cranks it yet?
Coming soon!!!!
Re: 360 ENGINE REBUILD WILL NOT START [Re: Mr.Yuck] #1717301
12/29/14 02:23 PM
12/29/14 02:23 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Or the ignition wires order is backwards on the cap.
Re: 360 ENGINE REBUILD WILL NOT START [Re: Mr.Yuck] #1717302
12/29/14 02:40 PM
12/29/14 02:40 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Lots of good info here, but start from the basic stuff first. It may sound stupid but stupid stuff do happen .
Confirm you have fuel in the carb and its spraying.
If you only put #1 piston on TDC and then put the chain on(as you say you done) without aligning the marks, the cam could be anywhere. maybe you did align the marks but you never said . You have to confirm that your mechanical timing is correct before moving on to electrical timing.
If you confirm the cam/crank timing is ok, move on to the electrical timing by pulling #1 plug and bring to TDC on compression stroke , if dist is in correct , the rotor button should be pointing at #1 wire in the cap or there about. If not , you will have to mess with the dist till you get that fixed either by pulling the dist and moving the gear or changing the wires in the cap (not the right way).
If you can confirm that you have the dist fixed , then confirm that you have spark by grounding a plug on the engine and turn the engine over and see if the plug fires.
If the plug fires, you got compression, you got fuel , your cam/crank timing is correct , you electrical timing is right . the engine should start
please reply with your findings , it should take no longer than a 1/2 hr to check the above .
Re: 360 ENGINE REBUILD WILL NOT START [Re: TC@HP2] #1717303
12/29/14 03:17 PM
12/29/14 03:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Yes you NEVER use the #1 on the cap as "true".
Re: 360 ENGINE REBUILD WILL NOT START [Re: Mr.Yuck] #1717304
12/29/14 05:08 PM
12/29/14 05:08 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Is the distributor turning? I had a nightmare when I built my stroker and it turns out I used a bolt that was too long in the water pump and it broke the cam gear.....
Re: 360 ENGINE REBUILD WILL NOT START [Re: wally426ci] #1717305
12/29/14 06:19 PM
12/29/14 06:19 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I would double check that you have juice when the engine is cranking. I had one that had juice in the run position but none in the crank position. Just about drove me nuts... If you think everything is correct turn the key on and cross the starter relay and see what happens...
...FAFO...
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717306
12/29/14 10:03 PM
12/29/14 10:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
First thing I would do is put in brand new plugs, first. I know they were new, put new ones in again and try again.
Re: 360 ENGINE REBUILD WILL NOT START [Re: Challenger 1] #1717307
12/30/14 11:08 AM
12/30/14 11:08 AM
SO ILL
K
K
SO ILL
Thanks you everyone for your responses.
This is all good quality input.
I will be able to try some of these suggestions tomorrow.
I will update everyone on my findings.
Thanks,
SLD
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717308
12/30/14 11:58 AM
12/30/14 11:58 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
get right u dont want to wipe the cam .
Re: 360 ENGINE REBUILD WILL NOT START [Re: mopar_man] #1717309
12/31/14 02:39 PM
12/31/14 02:39 PM
SO ILL
K
K
SO ILL
Hey All, here is an update:
When the balancer mark is on “0”, the valves on #1 cylinder are relaxed (closed).
The rotor is pointing to the #1 spark plug wire.
The #6 cylinder intake valve is open.
I believe the mechanical timing is set. Right????
I’m sending pics of my evaluation.
Any further input will be appreciated.
Thanks,
SLD
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717310
12/31/14 02:41 PM
12/31/14 02:41 PM
SO ILL
K
K
SO ILL
Next pic
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717311
12/31/14 02:42 PM
12/31/14 02:42 PM
SO ILL
K
K
SO ILL
#6 cylinder
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717312
12/31/14 02:44 PM
12/31/14 02:44 PM
SO ILL
K
K
SO ILL
This is how the gears were set.
Some has posted that the dots should be @ 12 o-clock on both gears.
I'm a little confused.
Re: 360 ENGINE REBUILD WILL NOT START [Re: KISSFANN1] #1717313
12/31/14 02:52 PM
12/31/14 02:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
dot to dot like in the pix not both at 12 o'clock. Check all your vacuum lines. Make sure the intake is sealed. Can you pull a plug and see if you are getting fuel into the cylinders?
