8 3/4 gear tag #1717199
12/28/14 10:53 PM
12/28/14 10:53 PM
North Carolina
469runner Offline OP
North Carolina
I am getting ready to reassemble my carrier to the housing. I failed to photograph or take note of where this axle ratio tag was located. Under which nut is the tag attached? A picture would be great if available.
Re: 8 3/4 gear tag [Re: 469runner] #1717200
12/29/14 12:46 AM
12/29/14 12:46 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Gear tag location on my 1970 Duster 340.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 8 3/4 gear tag [Re: FJR doc] #1717201
12/29/14 01:34 PM
12/29/14 01:34 PM
Waterford, MI
JAK Offline
JAK  Offline
Waterford, MI
Could the location of the tag be random as my 71 challenger has tha tag in the 10 o'clock position when facing the pinion nut? The center section appears to be originally installed.
