Joss Engines 468ci. SB All Aluminum Ritter XR Engine #1712622
12/19/14 02:37 AM
12/19/14 02:37 AM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
Hey everyone, as I stated a little while back in another thread, I would do a build thread on this engine when we were seeing the light at the end of the tunnel. There were many challenges in making this thing come together to what you see now. Many are wondering what issues we ran into using the Ritter Racing XR Aluminum block. I think I might do a seperate thread for that. I would first like to talk with Kent about this block. IT IS THE PROTOTYPE ALUMINUM BLOCK.
1050 dominator
Indy rect. Port intake.
Indy 360-1 245cc CNC heads
Ritter Racing Aluminum XR 48 degree block.
12.2:1 compression
4.185" bore Ross custom forged piston. -16cc inverted dome
GRP 6.300" Rod
BPE 4.250" stroke crank
Comp solid roller
277/284 @ .050"
.724"/.693" lift.
110LSA
1-7/8" primaries 3-1/2" collector
This info is subject to change as I am at home sitting on my couch and this is off the top of my head.
Video of the engine warming up.
Joss Engines Aluminum Small block Mopar: http://youtu.be/0rzf3r21Q4g
-Kenny
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712623
12/19/14 09:59 AM
12/19/14 09:59 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Looks good, what did it make on the dyno. Must be a torque monster with all those cubes.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712624
12/19/14 10:17 AM
12/19/14 10:17 AM
Guitar Jones Offline
Looks good Kenny. Have you thought about a larger tube header, maybe 2" primary with a 4" collector?
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: Guitar Jones] #1712625
12/19/14 02:13 PM
12/19/14 02:13 PM
Alberta Canada
Alberta Canada
We haven't done a whole lot of pulling on it yet. It will be being disassembled to address the one last problem we are having with this block. The oil drain back is not enough. The holes provided aren't enough, and the small amount of crank case pressure is keeping the oil from draining back well.
We have made a pull to 6500, and we were seeing 100 points (This works out to 650hp) We are of course expecting much more than that out of this thing, as it is very similar to the engine in my car.
These headers are our dyno headers and not the headers which will be in the car. I could see benefit from a 2" primary, how much, I am not sure. Maybe the best bet on this would be a step because of the port size. 4" exhaust for sure wouldn't hurt. My car at the same cubes is huffing through 3" street exhaust still and the fastest it has run is with the pipes on.
-Kenny
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712626
12/19/14 03:35 PM
12/19/14 03:35 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I would sure like to hear some good results from these blocks in the near future. I would LOVE to have one sitting on my engine stand.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: pittsburghracer] #1712627
12/19/14 04:02 PM
12/19/14 04:02 PM
Alberta Canada
Alberta Canada
I agree John. I want to see these things succeed. With the shortage/discontinued R3, we have no other options as small block guys at the moment, and I want to see these Ritter blocks become not just the only option, but a GOOD option. The potential is there.
I made a deal on a 6.4L hemi that was a take out of one of the new 2014 2500 Ram's at our dealership, and I will be digging more into these things as higher HP options to pursue.
-Kenny
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712628
12/19/14 04:12 PM
12/19/14 04:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
-Kenny
Can I ask why they pulled the engine?
Matt
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: MattW] #1712629
12/19/14 04:21 PM
12/19/14 04:21 PM
Alberta Canada
Alberta Canada
Yeah Matt, the engine took in water, hydraulic'd and busted one rod and bent another. Ill be checking the block out before going ahead with it.
-Kenny
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712630
12/19/14 09:12 PM
12/19/14 09:12 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Looks good, sounds cool too. Can't wait to see how it runs.... and how things go with the block
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712631
12/19/14 10:27 PM
12/19/14 10:27 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
-Kenny
Man I hope it was because the driver when through a lake or something.
Not a design flaw.
Thanks for the info looking forward your XR results
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: MattW] #1712632
12/20/14 02:54 PM
12/20/14 02:54 PM
Alberta Canada
Alberta Canada
Not a design flaw.
Yeah, I believe someone sunk their work truck.
I phoned Kent yesterday, he was a bit busy and so I briefly chatted with him a bit, and let him know the engine was now running. He wants to chat more on Monday about the engine, so we will see how things go.
-Kenny
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1712633
12/20/14 03:25 PM
12/20/14 03:25 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Not a design flaw.
-Kenny
I've dealt with Ken in the past. Have no trouble buying stuff from him.
Hope you and him can iron out the problems.
There is nowhere else to go with the La small block.
Btw is your ali block sleeved, or sprayed with the hardening stuff.
Can't think of the name. Lol
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: MattW] #1712634
12/20/14 04:12 PM
12/20/14 04:12 PM
Canada
onig Offline
onig  Offline
Canada
Nickelsil, I believe.
69 Dart
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: onig] #1712635
12/21/14 04:18 AM
12/21/14 04:18 AM
Outside
thedriver Offline
thedriver  Offline
Outside
1973 challenger
Dana. 4 speed. Low deck.
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1837972
05/31/15 01:51 PM
05/31/15 01:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Any news on this deal???
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: J_BODY] #1838008
05/31/15 02:33 PM
05/31/15 02:33 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I asked you a long time ago what head gasket you were running. there was no gasket on the planet that would seal up my block Kent is an idiot P7 water jacket is different than a LA Block I spent a ton of cash having gaskets made I have a part number you probably need sorry you munched your motor
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: J_BODY] #1842447
06/05/15 09:59 PM
06/05/15 09:59 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
nope I guess no news is still bad news
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: WHITEDART] #1842598
06/05/15 11:57 PM
06/05/15 11:57 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
These block castings were really designed with the P7 in mind, the wedge stuff seems to be an after thought.
Alan Jones
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: WHITEDART] #1885847
08/05/15 08:38 PM
08/05/15 08:38 PM
Alberta Canada
Alberta Canada
Hey WHITEDART, we are using a Cometic gasket. It wasn't one of the issues for us on this block.
As stated in another thread today, I have been away from moparts for quite a while, starting my own business. I will have more info on this deal shortly! Thanks.
-Kenny
Re: Joss Engines 468ci. SB All Aluminum Ritter XR Engine [Re: StrokerAspen] #1886069
08/06/15 01:35 AM
08/06/15 01:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Still watching...... not expecting much, but watching.
