Re: 90 degree oil filter adaptor question
[Re: dan9]
#1711500
12/16/14 01:42 PM
12/16/14 01:42 PM
RapidRobert
No, just clock it where you have the most filter clearance & hold it in that position as you draw it up into place (50 lbs) cuz you dont want to be turning it once the adapter is close to being bolted to the block (it's hard on the circular gasket). Glue the gasket to the recess first (Permatex MA99 high tack, the red gasket cenent/glue in the spray can is excellent). FYI be sure to clean the block recess squeaky clean & thin washer goes under bolt head on the outside (use sealer) and the thick cork washer on the bolt inside the concave cup. Felpro sells the large circular gasket seperately which is a bit thicker than the one that comes in the 3 piece MP kit & it seals better but with good prep you will be fine with either one
[Re: MoparforLife]
#1711506
12/17/14 11:32 AM
12/17/14 11:32 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Unless it was leaking externally the problem isn't the adapter. If anything the oil would be bypassing the filter. Your drop in pressure seems either coincidental to the engine warming up or a symptom of the bearing failure, depending on the failure.
I think the pressure drop is a symptom not a cause of the problem.
[Re: dan9]
#1711512
12/18/14 02:53 PM
12/18/14 02:53 PM
Posts: 13,615 md
mopars4ever
md
Yes that is what I'm thinking. Did you use the cork gasket between the screw-in adaptor and the block and a thin gasket between the plate and the block? It sounds dumb but I didn't take it apart. Just trying to get it right.
If you get rid of the 90 degree adapter you just need the gasket on the block, the filter plate and the threaded piece the filter screws on. That`s it.
[Re: mopars4ever]
#1711513
12/18/14 07:06 PM
12/18/14 07:06 PM
Posts: 2,386 White Plains, NY
VCODE
White Plains, NY
Not to highjack, but what is the original cast iron 70 340 bolt length ![](/ubbthreads/images/graemlins/thumbs.gif) Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: dan9]
#1711517
12/27/14 03:20 PM
12/27/14 03:20 PM
Challenger 1
Cincinnati, Ohio
Thanks for all the replies. Pulled motor, took it back apart, found the problem. Crank and rods at the machine shop now. I'll assume the blame and pay for repairs, just double checking what critical areas I should look at. I think I'll be fine, parts will be done in 2 weeks.
We are all curious? What was the problem? Did I miss it in one of your previous posts?
[Re: dan9]
#1711518
12/27/14 08:32 PM
12/27/14 08:32 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
The mains and rod bearings gone was not the problem, that's the result of the problem . Did you find a problem ? if you didn't, you still have a problem . Don't mind asking questions , there's more talent and experience here then at Chrysler Engineering Facility . ![](/ubbthreads/images/graemlins/beer.gif)
