90 degree oil filter adaptor question #1711499
12/16/14 01:26 PM
12/16/14 01:26 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
On a small block does it matter how it is "clocked"?
Re: 90 degree oil filter adaptor question [Re: dan9] #1711500
12/16/14 01:42 PM
12/16/14 01:42 PM
No, just clock it where you have the most filter clearance & hold it in that position as you draw it up into place (50 lbs) cuz you dont want to be turning it once the adapter is close to being bolted to the block (it's hard on the circular gasket). Glue the gasket to the recess first (Permatex MA99 high tack, the red gasket cenent/glue in the spray can is excellent). FYI be sure to clean the block recess squeaky clean & thin washer goes under bolt head on the outside (use sealer) and the thick cork washer on the bolt inside the concave cup. Felpro sells the large circular gasket seperately which is a bit thicker than the one that comes in the 3 piece MP kit & it seals better but with good prep you will be fine with either one
Re: 90 degree oil filter adaptor question [Re: RapidRobert] #1711501
12/16/14 01:53 PM
12/16/14 01:53 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thanks for the info. I'm not sure if I put that cork gasket in. I'm looking for anything that would have caused main and rod bearing failure during the cam break-in process. Everything was new, oil pressure was 60 for about 10 minutes then started falling. I had 60 lbs. while priming. Crank is out now getting turned. Trying to figure out what the failure was.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711502
12/16/14 02:19 PM
12/16/14 02:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
do you really need it? i got rid of mine and just used a shorter filter. one less thing to worry about.
Re: 90 degree oil filter adaptor question [Re: mopars4ever] #1711503
12/16/14 04:10 PM
12/16/14 04:10 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Yes that is what I'm thinking. Did you use the cork gasket between the screw-in adaptor and the block and a thin gasket between the plate and the block? It sounds dumb but I didn't take it apart. Just trying to get it right.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711504
12/16/14 06:38 PM
12/16/14 06:38 PM
I'm looking for anything that would have caused main and rod bearing failure during the cam break-in process. , oil pressure was 60 for about 10 minutes then started falling. Crank is out now getting turned. Trying to figure out what the failure was.
it fell to what? more info on the bearings & what abnormality did you see/hear during the break that made you abort & tear it down (other than the lowering psi). EDIT were the bearings scratched (debris) or metal to metal contact or blued, more info please. you had plenty of psi, we're missing sumpin. not installing the cork inner gasket (& I doubt if he forgot it) would let the oil bypass the filter but this sounds like a different problem as opposed to unfiltered oil during the brief breakin. Did the psi go to zero or near zero?
Re: 90 degree oil filter adaptor question [Re: RapidRobert] #1711505
12/17/14 07:50 AM
12/17/14 07:50 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If there was oil pressure the mains should have been getting plenty of oil. Even 10 lbs would have been oiling the mains with plenty oil when at idle. The filter is not likely your problem
Re: 90 degree oil filter adaptor question [Re: MoparforLife] #1711506
12/17/14 11:32 AM
12/17/14 11:32 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Unless it was leaking externally the problem isn't the adapter. If anything the oil would be bypassing the filter. Your drop in pressure seems either coincidental to the engine warming up or a symptom of the bearing failure, depending on the failure.
I think the pressure drop is a symptom not a cause of the problem.
Don't be the exception.
Re: 90 degree oil filter adaptor question [Re: RapidRobert] #1711507
12/17/14 12:24 PM
12/17/14 12:24 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Pressure fell steadily from 60psi to 10psi and I shut it off. Lifters didn't pump up. Pulled it to see what the problem was. Bearings were scratched, thrust bearing down to copper on both sides. I found a piece of rtv lodged in the pick-up tube. Crank is at the machine shop now. I just wanted to do a follow-up, all should be good to go now after a good cleaning and new lifters. Thanks guys for the help.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711508
12/17/14 06:27 PM
12/17/14 06:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Now you know why I almost never use RTV. Had a leaky aftermarket chrome thermostat housing I "fixed" by gooping RTV on it. Wiped off the extra that oozed out when I tightened it down. Never thought once about what might have oozed in. A chunk broke off and kept the thermostat from opening. Ended up blowing out a freeze plug on I15 in San Diego. I was in the left lane and by the time I could get to a safe stopping area (had my daughter with me) the engine was toast.
Re: 90 degree oil filter adaptor question [Re: Supercuda] #1711509
12/17/14 06:54 PM
12/17/14 06:54 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
I agree with you about the rtv. It used to say on the instructions that I once read 30 plus years ago to snug it down a little after applying it. After 24 hrs. you could crank it down. Sometimes we tend to use it as a gasket sealer instead of it's intended purpose. That really sucks how that stuff can ruin your day when it gets in the wrong places.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711510
12/17/14 07:06 PM
12/17/14 07:06 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
On the small block oil pressure,
Are you sure that the oil plug was installed at the end of the lifter valley inside the block near the distributor .
Also there is an oil cap inside near the filter inside the oil passage
Re: 90 degree oil filter adaptor question [Re: moparts] #1711511
12/17/14 07:25 PM
12/17/14 07:25 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Yes we checked the plug inside the plug. With the blockage I think I was getting temporary decent oil pressure but a severe lack of volume. Thanks for the tip though, I can see how that plug can get overlooked.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711512
12/18/14 02:53 PM
12/18/14 02:53 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If you get rid of the 90 degree adapter you just need the gasket on the block, the filter plate and the threaded piece the filter screws on. That`s it.
Re: 90 degree oil filter adaptor question [Re: mopars4ever] #1711513
12/18/14 07:06 PM
12/18/14 07:06 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Not to highjack, but what is the original cast iron 70 340 bolt length
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 90 degree oil filter adaptor question [Re: VCODE] #1711514
12/22/14 02:19 PM
12/22/14 02:19 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
If you are asking about the bolt that attaches the adaptor to the block it is 2 7/8 in. measured from under the head.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711515
12/22/14 02:27 PM
12/22/14 02:27 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Cut the filter open and see what sort of junk is in it. Bearing material would be obvious but it sounds like either the clearances were off or else there was junk in the oil galleys. Also pull apart the oil pump and see what the rotors look like. Who assembled the motor? They are responsible for the final cleanliness of all of the parts. Any oiling modifications on the motor? I knew a guy who put the copper tube in a small blocks oil galley for roller lifters and forgot to drill out the feed for the mains, wiped the crank out. Look for missing screw in and press in plugs in the galleys as well.
Re: 90 degree oil filter adaptor question [Re: Sixpak] #1711516
12/27/14 03:12 PM
12/27/14 03:12 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Thanks for all the replies. Pulled motor, took it back apart, found the problem. Crank and rods at the machine shop now. I'll assume the blame and pay for repairs, just double checking what critical areas I should look at. I think I'll be fine, parts will be done in 2 weeks.
Re: 90 degree oil filter adaptor question [Re: dan9] #1711517
12/27/14 03:20 PM
12/27/14 03:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
We are all curious? What was the problem? Did I miss it in one of your previous posts?
Re: 90 degree oil filter adaptor question [Re: dan9] #1711518
12/27/14 08:32 PM
12/27/14 08:32 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
The mains and rod bearings gone was not the problem, that's the result of the problem . Did you find a problem ? if you didn't, you still have a problem . Don't mind asking questions , there's more talent and experience here then at Chrysler Engineering Facility .
