Re: Magnum force suspension wtf!
[Re: onig]
#1711411
12/19/14 11:38 AM
12/19/14 11:38 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
That is race ready in those pics. Just needs a motor.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: bigtimeauto]
#1711413
12/19/14 11:40 AM
12/19/14 11:40 AM
1967dartgt
Hilltown Pa
Andy you need to get your car at race ride height before you measure. I know you wanted to lower it, do that then measure.
[Re: bigtimeauto]
#1711417
12/19/14 12:51 PM
12/19/14 12:51 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1711418
12/19/14 01:45 PM
12/19/14 01:45 PM
Posts: 75,417 A gulag near you.
JohnRR
A gulag near you.
I've always wondered why everyone just bolts aftermarket K frames to the bottom of the rails instead of using it as a structural member?
Header clearance and weight off the nose ???
#1711421
12/19/14 05:56 PM
12/19/14 05:56 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
The tubular K is super nice. I've always wondered why everyone just bolts aftermarket K frames to the bottom of the rails instead of using it as a structural member?
I built my K frame with an inner leg and cross bolt to strengthen the frame rails.
Really like your turbo layout! Will the exhaust be dumped in the front wheel well, or going down/back? This also looks extremely clean and well thought of. Really enjoy seeing that the tubing is inside the inner fenders, I guess it will be strong enough with the stiffened K-frame.
#1711423
12/21/14 08:51 PM
12/21/14 08:51 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Power steering ? Hmmmmmmm.........an aristocrat. It looks very busy , but should stiffen things up considerably. Very clean build too.
[Re: Oyvind Mopar]
#1711424
12/22/14 10:34 AM
12/22/14 10:34 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks. Don't want to hijack the thread. I've got a build thread in the projects forum and will answer any questions. Again, thanks.
[Re: sunroofgtx]
#1711426
12/22/14 01:15 PM
12/22/14 01:15 PM
Posts: 60 Maryland
gofastboater
Maryland
I'm SOOOOOOO glad to see that I'm not the only one to have MAJOR problems with the MF stuff. Where do I start???? I got my kit early 2000's. My '70 Challenger has been a 15 yr. project. When it got time to install the kit it looked good. All powder coated. Never test fit. In hindsight that was my BIG mistake. When I did finally get it into the car, WOW !!! 1st. Car sat way too low. Headers were dragging the floor. Kit came with 14" shocks and they should have been 17". Springs had no compression. Too stiff. Called them. Got NO satisfaction. Made 2 1/2" spacers for the shock towers. Car sits fine but still has no suspension give. Weaker springs will help but ride height will be too low. 2nd. Oil filter didn't clear. Hemi motor on a ears. Called them. Again no satisfaction. Their fix, place washers between frame and K frame. They said that it wouldn't change the front end geometry. WTF?? Ended up notching the tube. 3rd. The tires were HITTING the fender lip. Center spacer weld Aluma-Lites with 205 tires. Couldn't turn them at all and that was with the tops of the tires 2" farther in that the bottoms. Either the lower control arms were too long or the upper ones were too short. Just to get the tires vertical had to adjust the upper heim joints so 90% of their threads were showing. Definitely NOT safe. Even after shortening the lowers. Called them again. Got no real answers. And NO, the car was never wrecked. I am the 2nd owner and have had it since 1973. 4th. The rack HIT the oil pump. Refer back to #2. 5th. The rack geometry will not LET the steering even work. I at least got the car to roll straight with out any problem. Toe, caster and camber are close. But as soon as I put any turn into it the tires want to turn in different arcs. I cant even push the car. Gave up even calling them. This setup is the biggest POS I have ever seen. It's worth nothing to sell. None of this mess will transfer to an Alterkation piece. I have talked to my fab guy and he is willing to cut it to pieces and start from scratch but my budget won't allow that. So now I have a 95% completed project that sits there. That's my rant.
[Re: sshemi]
#1711428
12/22/14 05:39 PM
12/22/14 05:39 PM
Posts: 1,019 Finland
mafo
Finland
with all the talent and knowledge on this site we should team up and design a working front suspension since most seems to have some issues at least it should generate a interesting discussion
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
