Numbers matching question? 1968 Dodge Dart GTS #1711135
12/15/14 07:51 PM
12/15/14 07:51 PM
Third Stone from the Sun
Scotts72Rallye Offline OP
A friend is seriously looking at a '68 Dart GTS 383 4spd car. Two things that concerned him was that the six numbers on the lower right corner of the fender tag don't match the last 6 numbers of the vin tag. Should these always match? And second, the numbers stamped on the 4spd matched up until the last number, it should be a 6 but it's a 9. The ownwer told him that he thinks "the production employee accidently held the stamp upside down". I've never been a numbers correct kind of guy so any help would be appreciated.
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Scotts72Rallye] #1711136
12/15/14 08:03 PM
12/15/14 08:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1968 383 Dart:
Engine & trans should match last 8 digits of VIN on dash
Core support & trunk lip should match the last 6 bottom row of fender tag (S.O.#)
S.O.# (Shipping Order number) on fender tag & VIN don't match in '68
The SPD (Scheduled Production Date) on fender tag has to be appropriate for the VIN
Post or PM those 2 & I can verify that they are at least "appropriate" for that plant & date
A single digit error is possible.
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: 6bblgt] #1711137
12/15/14 09:20 PM
12/15/14 09:20 PM
Here's a pic of the fender tag. Dan check your messages.
UNDER CONSTRUCTION
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Scotts72Rallye] #1711138
12/15/14 09:40 PM
12/15/14 09:40 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
as said the numbers on the tag are the number stamped on the body which doesn't match the VIN on a 68. The Broadcast sheet is the only way to tie them together , though there may be something of some original dealership docs ?
As far as that last digit being off, totally possible, but the number stamps were held all together in one tool , they were not held separately. I assume the original block is not present? If the trans is wrong, then the engine would/should be also as they were stamped at the same time, with the same tool, by the same person.
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: JohnRR] #1711139
12/15/14 09:55 PM
12/15/14 09:55 PM
Thanks for the response John! The present owner claims all numbers match so I'll pass the word on to my buddy about number stamp tooling.
UNDER CONSTRUCTION
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Scotts72Rallye] #1711140
12/15/14 10:37 PM
12/15/14 10:37 PM
U.S.S.A.
U.S.S.A.
There are a few things to look for , the engine number will be stamped on the bell housing flange behind the drivers side head , and check the assembly date of the engine , it should be close to the SPD on the tag.
Also it may not be an 383 HP in 68 ??? I think they were rated at 330Hp for 68 ?
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: JohnRR] #1711141
12/16/14 02:06 PM
12/16/14 02:06 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
there are body production line numbers stamped on mopars----on some the front 6 digit number is on the radiator support in plain view and the matching rear number is hidden under the rubber gasket of the back window--near the package tray---these numbers match the data plate and the broadcast sheet----in some years the front number is moved to the area of cowl near windshield wiper motor----these numbers have nothing to do with the vin number....
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: savoy64] #1711142
12/16/14 08:00 PM
12/16/14 08:00 PM
U.S.S.A.
U.S.S.A.
Package tray was on earlier cars ... like a 64 Savoy ... 68 A/B body it was on the trunk rail under the weatherstrip, in 69 they changed it from the SO number to the partial VIN.
On cars that had it on the cowl it would have been the partial of the VIN as that started in 70 with the E body.
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: JohnRR] #1711143
12/19/14 12:09 PM
12/19/14 12:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Nice car according to the fender tag!
JB Rhinehart, Realist
A-Body's RULE!
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Rhinodart] #1711144
12/19/14 09:13 PM
12/19/14 09:13 PM
My buddy put some money down. When the deal goes through I'll post up a picture. Just came out of a long sleep, last driven in '93. 50K original miles.
Scott
UNDER CONSTRUCTION
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Scotts72Rallye] #1711145
12/19/14 09:49 PM
12/19/14 09:49 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
Lot of owners will make that claim. If the stampings on the engine , tranny, radiator support don't match the vin forget number matching. My two cents
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: 6bblgt] #1711146
12/21/14 07:20 PM
12/21/14 07:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
1968 383 Dart:
Where are the rear S.O. Numbers on a Fastback 68 barracuda? Still the trunk? If so, what side?
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: 70 buzz] #1711147
12/21/14 09:02 PM
12/21/14 09:02 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
As already mentioned, the radiator support stamping will not match the vin on a '68 model year car, that started with the '69 models.
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: JohnRR] #1711148
12/28/14 12:09 AM
12/28/14 12:09 AM
Stuart, FL
Grassosgarage Offline
Stuart, FL
I know on a '67 Charger the rear stamp was down by the holes for the bumper bracket. I have '67 Dart I can't find a rear stamping in the trunk jamb or rear bumper area. Any idea where it is on '67 A body?
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Grassosgarage] #1711149
12/31/14 02:24 PM
12/31/14 02:24 PM
Thanks for the info guys! It was delivered yesterday. 1968 Dodge Dart GTS, 383, 4spd car. Been off the road since '93. 50K original miles with just a little bit of paint work done in the early 80's.
UNDER CONSTRUCTION
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Scotts72Rallye] #1711150
12/31/14 02:27 PM
12/31/14 02:27 PM
Featured in Muscle Car Review back in 1987.
UNDER CONSTRUCTION
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Grassosgarage] #1711151
12/31/14 03:20 PM
12/31/14 03:20 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You have to remove the weatherstrip and usually sand down to the metal to find the SO number on drivers side trunk rail. You can see where the area was spot welded in around where the hole is for the trunk light and to where the rail turns down. It WILL be there, but can't be seen with the weatherstrip adhesive and paint in the way.
A-Body's RULE!
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Rhinodart] #1711152
01/02/15 09:32 PM
01/02/15 09:32 PM
Woodbridge
Tommy The Chryco Offline
Woodbridge
i understand the block and auto tranny would be stamped together, would that also apply to a 4sp bell housing? never saw numbers on one?
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Tommy The Chryco] #1711153
01/02/15 10:22 PM
01/02/15 10:22 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You know what, neither have I! I have had several 68 GTS 4-speeds and never looked!
A-Body's RULE!
Re: Numbers matching question? 1968 Dodge Dart GTS [Re: Rhinodart] #1711154
01/02/15 10:49 PM
01/02/15 10:49 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
4 speed was stamped on the trans in 68
