Re: Crankshaft Clearance Problem
[Re: maximus]
#1710428
12/14/14 02:28 PM
12/14/14 02:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On my R-3 block the crank hit webbing near one of the mains... I ground the block for clearance... I just used a 1/4 die grinder... doing it this way I could put any crank in it without having to rework each crank
[Re: maximus]
#1710433
12/14/14 04:15 PM
12/14/14 04:15 PM
MR_P_BODY
Whatever is minimum clearance required in this area? The #2 just touches and #6 his by about .010-.015. So minimum grinding or chamfering would be required.
I gave mine .040 clearance
[Re: MR_P_BODY]
#1710434
12/14/14 05:29 PM
12/14/14 05:29 PM
Posts: 515 geezer acres rest home
dakotawilly
ohio offers that service on their cranks for 50 bucks i believe,they cut them down for 400 blocks to clear the block....
SFI 25.5 depends,no leak,even at 213 mph....
[Re: maximus]
#1710439
12/17/14 11:46 PM
12/17/14 11:46 PM
Posts: 16,928 NC
440Jim
NC
Yes it is the counter weight that is hitting the camshaft web.
It sounds like you could do this. Put a large bevel on those counterweights, rather than reduce the entire diameter. Similar to low deck issue with large 440 crank counterweights.
[Re: maximus]
#1710442
12/18/14 05:18 PM
12/18/14 05:18 PM
Jerry Kathe
Probably...most raw forging are minimally machined until final application. Possibly someone will want to use a six pack rod, thick wall pin and heavy slug....then you need all of that counter. Large counters are not HP productive......look at one where a light bob was used....it will have the piss drilled out of it...also not a speed tip -
