Crankshaft Clearance Problem #1710427
12/14/14 02:20 PM
12/14/14 02:20 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
This is a first for me and want the correct fix to the problem. Mocking up the hemi motor with a 4.15 stroke Ohio Crankshaft and the large diameter throw on the back of the #2 and #6 rod journal is hitting the block at the cam webbing. What the problem is the throw of the crank has no radius on the OD which is causing the rubbing on #2 and actual hitting on #6. What is best to fix for the problem? Grind block for clearance which would be a pain, hand grind a radius on the crank throw, or take it to a shop and have lathe cut the radius for clearance? The assembly has not been balanced yet. The hemi block is an original casting.
Re: Crankshaft Clearance Problem [Re: maximus] #1710428
12/14/14 02:28 PM
12/14/14 02:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my R-3 block the crank hit webbing near one of the
mains... I ground the block for clearance... I just
used a 1/4 die grinder... doing it this way I could
put any crank in it without having to rework each crank
Re: Crankshaft Clearance Problem [Re: maximus] #1710429
12/14/14 02:28 PM
12/14/14 02:28 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
tough to say without seeing how close. Having not balanced yet, you could grind down crank for clearance, but there are a lot of variables. If your piston/rods are heavy, you won't want to cut crank. If you have lightweight parts you'll need to lighten crank anyway. I would strongly suggest you mock up entire rotating assembly, and add cam and timing chain then check for clearance before balancing. Mallory metal is not cheap
Re: Crankshaft Clearance Problem [Re: maximus] #1710430
12/14/14 02:33 PM
12/14/14 02:33 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
First off what is the bob weight of the rotating assembly ? If the bobweight is 2450 or above grind the block. If it's less you can cut the counter weights. I usually cut those .150 and still have enough to drill for balancing. I think most of the target bob weight is 2500. Give Scott at Ohio Crank a call and ask very nice people and balance a lot of their on cranks. Hope this helps.
Re: Crankshaft Clearance Problem [Re: DAYTONA540] #1710431
12/14/14 04:09 PM
12/14/14 04:09 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Whatever is minimum clearance required in this area? The #2 just touches and #6 his by about .010-.015. So minimum grinding or chamfering would be required.
Re: Crankshaft Clearance Problem [Re: maximus] #1710432
12/14/14 04:14 PM
12/14/14 04:14 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I had the same clearance problem as MrP. I clearance it at .100 to be safe.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Crankshaft Clearance Problem [Re: maximus] #1710433
12/14/14 04:15 PM
12/14/14 04:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I gave mine .040 clearance
Re: Crankshaft Clearance Problem [Re: MR_P_BODY] #1710434
12/14/14 05:29 PM
12/14/14 05:29 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
ohio offers that service on their cranks for 50 bucks i believe,they cut them down for 400 blocks to clear the block....
SFI 25.5 depends,no leak,even at 213 mph....
Re: Crankshaft Clearance Problem [Re: maximus] #1710435
12/14/14 06:03 PM
12/14/14 06:03 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Not 100% sure I understand the problem, is it the counter weight or the cheek of the rod pin hitting the block?
As Daytona540 said, Ohio Crankshaft are good people and will take care of you, especially if the crank is abnormal. My preference would be cut the crank if its the counter weight.
Can you post a photo?
Re: Crankshaft Clearance Problem [Re: Jerry Kathe] #1710436
12/16/14 08:33 PM
12/16/14 08:33 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Yes it is the counter weight that is hitting the camshaft web.
Re: Crankshaft Clearance Problem [Re: maximus] #1710437
12/16/14 09:25 PM
12/16/14 09:25 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Contact Ohio and explain. It will be necessary to send it back and have the crankshaft counterweights machined to the proper diameter. If your bob-weight will allow, have the counterweights machined down to the minor diameter.
Did you buy the full rotating assembly from them, if not, do you have the balance sheet?
Re: Crankshaft Clearance Problem [Re: Jerry Kathe] #1710438
12/17/14 11:07 PM
12/17/14 11:07 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Not balanced yet but it will have K1 rods and Diamond 11 to 1 pistons.
Re: Crankshaft Clearance Problem [Re: maximus] #1710439
12/17/14 11:46 PM
12/17/14 11:46 PM
NC
440Jim Offline
440Jim  Offline
NC
It sounds like you could do this. Put a large bevel on those counterweights, rather than reduce the entire diameter. Similar to low deck issue with large 440 crank counterweights.
Re: Crankshaft Clearance Problem [Re: 440Jim] #1710440
12/18/14 09:09 AM
12/18/14 09:09 AM
Jerry Kathe Offline
Jerry Kathe  Offline
Yes you could....my preference is to reduce the overall diameter. You shouldn't need that much counter for a performance bob weight any way.
"Light" is the answer - lol
Re: Crankshaft Clearance Problem [Re: Jerry Kathe] #1710441
12/18/14 04:53 PM
12/18/14 04:53 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
I looked at another brand crank today and it had a large chamfer cut the in counter-weights as in the picture above.
Re: Crankshaft Clearance Problem [Re: maximus] #1710442
12/18/14 05:18 PM
12/18/14 05:18 PM
Jerry Kathe Offline
Jerry Kathe  Offline
Probably...most raw forging are minimally machined until final application.
Possibly someone will want to use a six pack rod, thick wall pin and heavy slug....then you need all of that counter.
Large counters are not HP productive......look at one where a light bob was used....it will have the piss drilled out of it...also not a speed tip -
