Re: A-body passenger side mirror same as driver side?
[Re: OA5599]
#1710336
12/15/14 06:00 PM
12/15/14 06:00 PM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
i guess nobody knows. i figured there would be someone out there that knew everything!
[Re: TONY_DAGOSTINO]
#1710339
12/16/14 07:05 PM
12/16/14 07:05 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Hi
I have an original here the outer edge is just over an inch deep while the inner edge (near the door glass) is about 1/2" deep
looks correct to me
Wouldn't surprise me that it was like that considering it's being viewd from the drivers seat , the angle is most likely because depending on how it's adjusted the edge of the mirror would be outside the edge of the mirror housing ?
It's been a long time since I've had a pass side one of those mirrors.
[Re: JohnRR]
#1710340
12/17/14 02:16 AM
12/17/14 02:16 AM
Posts: 27,478 So Cal
autoxcuda
So Cal
Yes they are angled for the driver.
When you get them on, tell us if you can actually see out of it and use it in normal driving.
My original coded for passenger mirror still does not angle inward enough for me to see anything useful out of it. Even though it has that angle in it like posted above. I know many other A-body owners that say the same.
[Re: autoxcuda]
#1710344
12/18/14 09:16 AM
12/18/14 09:16 AM
Posts: 441 Frederick , MD
GibW340
Frederick , MD
Yes they are angled for the driver. MY EXPERIENCE WAS THAT THEY WERE POSITIONED FOR PASSENGER USE- NOT DRIVER USE- HAD ON 2 DIFFERENT A BODIES- 68 BARRACUDA AND 69 DART- ORIGINAL EQUIPMENT
[Re: Rhinodart]
#1710347
12/19/14 12:51 AM
12/19/14 12:51 AM
autoxcuda
So Cal
The problem is that if you put the mirror where it is more useful the wing window may not open all the way, been there, done that.
AND the wing window post is in your line of sight!
