A-body passenger side mirror same as driver side? #1710334
12/14/14 12:26 PM
12/14/14 12:26 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
I just bought a passenger side mirror for my '69 Cuda. The driver's side mirror that is currently on it is symmetrical all the way around. The passenger side one that I have is supposed to be for a '69 Cuda, but is not symmetrical all the way around. It is narrow on the side towards the car, and fatter on the outside. Before I install the passenger side on it, is this correct for the car?
Re: A-body passenger side mirror same as driver side? [Re: OA5599] #1710335
12/14/14 12:27 PM
12/14/14 12:27 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
New one.
Re: A-body passenger side mirror same as driver side? [Re: OA5599] #1710336
12/15/14 06:00 PM
12/15/14 06:00 PM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
i guess nobody knows. i figured there would be someone out there that knew everything!
Re: A-body passenger side mirror same as driver side? [Re: Lew] #1710337
12/16/14 06:24 PM
12/16/14 06:24 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
Hi
I have an original here
the outer edge is just over an inch deep
while the inner edge (near the door glass) is about 1/2" deep
looks correct to me
Re: A-body passenger side mirror same as driver side? [Re: TONY_DAGOSTINO] #1710338
12/16/14 06:27 PM
12/16/14 06:27 PM
DELAWARE
DELAWARE
but the sharpness of the edges doesn't look as sharp as my original
Re: A-body passenger side mirror same as driver side? [Re: TONY_DAGOSTINO] #1710339
12/16/14 07:05 PM
12/16/14 07:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hi
looks correct to me
Wouldn't surprise me that it was like that considering it's being viewd from the drivers seat , the angle is most likely because depending on how it's adjusted the edge of the mirror would be outside the edge of the mirror housing ?
It's been a long time since I've had a pass side one of those mirrors.
Re: A-body passenger side mirror same as driver side? [Re: JohnRR] #1710340
12/17/14 02:16 AM
12/17/14 02:16 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes they are angled for the driver.
When you get them on, tell us if you can actually see out of it and use it in normal driving.
My original coded for passenger mirror still does not angle inward enough for me to see anything useful out of it. Even though it has that angle in it like posted above. I know many other A-body owners that say the same.
Re: A-body passenger side mirror same as driver side? [Re: autoxcuda] #1710341
12/17/14 12:27 PM
12/17/14 12:27 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My Challenger only came with a DS mirror. I feel a little uncomfortable driving it without a PS mirror. My 68 Dart was the same way, that's why I'm adding a PS mirror during the build. I guess I need to put the drivers seat in place and mock up the mirror to see if it's usable in the factory location. I could always move it forward or back since no holes are drilled yet. If it doesn't match the location of the DS, that might look funny though.
Re: A-body passenger side mirror same as driver side? [Re: TONY_DAGOSTINO] #1710342
12/17/14 03:58 PM
12/17/14 03:58 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
A big thanks to Tony and to Mike Ross for filling me in on the correctness. The mirror is installed and looks great. I'm a big fan of symmetry. As far as function, in the factory location, it's not that useful. But I didn't want to alter the location, as we did a mock-up and it was very noticibly incorrect and that would have driven me more crazy than not being able to see very well. This is one of the first times I have chosen form over function.
Re: A-body passenger side mirror same as driver side? [Re: OA5599] #1710343
12/17/14 08:47 PM
12/17/14 08:47 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
30 years ago I bought an NOS mirror like that for my 67 Barracuda. It came with a paper template to layout the holes for installation on different models. I remember that when we tried to lay out the holes with the template, the mirror was in a different position than the drivers mirror was. So we just measured the position for the drivers mirror , and installed the passenger mirror in the same relative position. The mirror will not move far enough in adjustment to be very useful. I have always wondered if maybe the factory intended it to mount a little different than the drivers mirror so it would work better, or if we had missed using the template properly ?
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: A-body passenger side mirror same as driver side? [Re: autoxcuda] #1710344
12/18/14 09:16 AM
12/18/14 09:16 AM
Frederick , MD
GibW340 Offline
GibW340  Offline
Frederick , MD
Yes they are angled for the driver. MY EXPERIENCE WAS THAT THEY WERE POSITIONED FOR PASSENGER USE- NOT DRIVER USE- HAD ON 2 DIFFERENT A BODIES- 68 BARRACUDA AND 69 DART- ORIGINAL EQUIPMENT
Re: A-body passenger side mirror same as driver side? [Re: GibW340] #1710345
12/18/14 09:51 PM
12/18/14 09:51 PM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
I did the same symmetry thing. Bought a used right mirror and mounted it just like the driver's mirror. It's worthless there. But sure does look good!
1970 Duster 340 clone
Re: A-body passenger side mirror same as driver side? [Re: GibW340] #1710346
12/18/14 09:52 PM
12/18/14 09:52 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
The problem is that if you put the mirror where it is more useful the wing window may not open all the way, been there, done that.
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body passenger side mirror same as driver side? [Re: Rhinodart] #1710347
12/19/14 12:51 AM
12/19/14 12:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
AND the wing window post is in your line of sight!
Re: A-body passenger side mirror same as driver side? [Re: autoxcuda] #1710348
12/19/14 01:57 AM
12/19/14 01:57 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And how often do you really look at a passenger side mirror ?
Re: A-body passenger side mirror same as driver side? [Re: 62maxwgn] #1710349
12/19/14 12:31 PM
12/19/14 12:31 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Every time I pass someone...
