Re: re release 6.1 blocks???????
[Re: MattW]
#1709492
12/12/14 11:21 AM
12/12/14 11:21 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I just picked up a Jeep with a 6.1. Who has a cliff notes versions of what's different between the 5.7 and the 6.1? Where does the bigger 6.4 fit in?
5.7 3.92 bore x 3.58 stroke 6.1 4.055 bore x 3.58 stroke both can use the same cam
6.4 has a new block design 4.09 bore x 3.92 stroke. 6.4 block is stronger design. all cranks interchange. not the cams. the 5.7 to 08 has a three bolt reluctor wheel. all 6.1 and 6.4 and 5.7 09 and up have 4 bolts reluctor wheels. plus the 09 and up use more teeth on the reluctor wheel.
Heads 03 to 08 5.7. ported will go 330 09 and up 5.7 "Eagle" will go 330 out of the box and 360+ ported 6.1 heads are supposed to be the heads to get. Just read that somewhere. but apparently don't flow as well as the eagle in stock form. 6.4 "Apache" IIRC was 2011+ will go 340 OOTB and 400 ported All heads interchange. Always use gaskets for your block that your using. Matt
So Matt... your saying the 6.1 does not use the VVT cam... is there any odd ball stuff that has to be done to the 6.1 during a build
[Re: MR_P_BODY]
#1709493
12/12/14 02:56 PM
12/12/14 02:56 PM
MR_P_BODY
Ok... this is what I got for info... by the way the Kevin I talked to over at Orchard Dodge ISNT Kevin Moore... but Kevin Moore buys his parts through Orchard Dodge..... as of now there is no block being produced (P5153816ab).. right now there is still just the 12 that are on back order... as far as I can see there is no plans on casting any.. unless they get some magic number of units on back order(no one knows how many units that number is, whether it be 50 or 100 ).. I have a call into Kevin right now and am awaiting his call back..... by the way.. Chrysler employees or retirees get 25% off.... I'll update any info when I get the call back from Kevin.... for you guys that would like his phone #.. 248-439-0261.... so basically guys...... DONT HOLD YOUR BREATH
[Re: MR_P_BODY]
#1709494
12/12/14 04:10 PM
12/12/14 04:10 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thanks for the update Mike. I am one of the twelve back orders. I do have a 5.7 so it isn't the end of the world, but those extra cubes would have been nice, plus a brand new block ready for cam bearings and drop the pistons in.
[Re: gregsdart]
#1709495
12/12/14 04:18 PM
12/12/14 04:18 PM
MR_P_BODY
I hear ya Greg... I was thinking of one.. hell $1000 for a new block would have been great... (was $1030 today) but since there is none who knows what the price will be IF they produce the block... I was asking about other sizes also.. looks like they dont make anything for aftermarket
[Re: HotRodDave]
#1709497
12/12/14 09:45 PM
12/12/14 09:45 PM
MR_P_BODY
I just got my return call from Kevin... he said that the new date for release on these blocks is SUPPOSE to be 1-21-15... some how he said there is 20 on back order.... so as usual... dont hold your breath
[Re: MattW]
#1709499
12/12/14 10:57 PM
12/12/14 10:57 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Thank you for the info!
[Re: 72Swinger]
#1709502
12/13/14 11:42 AM
12/13/14 11:42 AM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
Thanks for the info Mr P. Does anyone know if a bare 6.4 block can be obtained yet? That would seem to be the hot ticket for a set of apaches on a big cube SB.
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: onebaddakota]
#1709503
12/13/14 12:33 PM
12/13/14 12:33 PM
MR_P_BODY
There were no blocks available of any kind from the dealerships.. if it isnt for production then they arent making any..... at this time... dont hold your breath
[Re: 1badx]
#1709504
12/13/14 01:34 PM
12/13/14 01:34 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Ebay item #261697456913 is a 6.1 shortblock. Not mine, just saw it on there,,not smart enough to 'link' it Looked at ad again,,it's from Sharadon .
If you like drag racing, support your local track.
[Re: MR_P_BODY]
#1709505
12/13/14 09:38 PM
12/13/14 09:38 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Sorry Mike. Just saw this. No the 6.1 does not use the VVT.
Other than the bigger bore the only other thing is the oil squirter s. Matt .
[Re: 72Swinger]
#1709506
12/13/14 09:41 PM
12/13/14 09:41 PM
MattW
Ontario Canada
cranks will interchange journal wise but a crank from a VVT engine in a non VVT engine would require machining to allow the crank sprocket to line up with the cam sprocket. The snout of the VVT cranks are longer too. Everything on the front of a VVT engine is spaced away from the block further to accommodate the VVT. Timing covers don't interchange either.
Forgot about that
[Re: Quickrunner]
#1709508
12/14/14 05:59 PM
12/14/14 05:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Yes the aftermarket cranks work fine but need a spacer to line up the timing gears. With the VVT block you're kind of stuck with a mediocre timing chain and an expensive custom cam. Look at what Steff did to make his 392 block work, he MADE a belt drive setup, this should give you a good indication of the situation. You can lock out the cam gear to nullify the VVT also.
Mopar to the bone!!!
[Re: Quickrunner]
#1709510
12/14/14 06:23 PM
12/14/14 06:23 PM
72Swinger
Nebraska
I would ditch the VVT block for an earlier one. Yes you can make one work but there is no advantage to them. A stock 6.1 timing set is good to 1000+hp and is proven reliable. Melling 10342 pump. There are cams used all over for 5.7/6.1 engines. You can go solid lifter and $2000 rockers if you want but the need for them IMO only comes from wanting to RPM over 8K rpm. There are 100's of guys that have supercharged their Gen III's and many proven combo's to steal info from. LXForums and Modern Mopar forum have a ton of info and used parts to save you time and money.
