Page 2 of 3 1 2 3
Re: re release 6.1 blocks??????? [Re: MattW] #1709491
12/12/14 11:18 AM
12/12/14 11:18 AM
Canada
onig Offline
onig  Offline
Canada
Good info.
THANKS
Onig
69 Dart
Re: re release 6.1 blocks??????? [Re: MattW] #1709492
12/12/14 11:21 AM
12/12/14 11:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I just picked up a Jeep with a 6.1. Who has a cliff notes versions of what's different between the 5.7 and the 6.1? Where does the bigger 6.4 fit in?
5.7 3.92 bore x 3.58 stroke
6.1 4.055 bore x 3.58 stroke
both can use the same cam
6.4 has a new block design 4.09 bore x 3.92 stroke.
6.4 block is stronger design.
all cranks interchange.
not the cams.
the 5.7 to 08 has a three bolt reluctor wheel.
all 6.1 and 6.4 and 5.7 09 and up have 4 bolts reluctor wheels. plus the 09 and up use more teeth on the reluctor wheel.
Heads
03 to 08 5.7. ported will go 330
09 and up 5.7 "Eagle" will go 330 out of the box and 360+ ported
6.1 heads are supposed to be the heads to get. Just read that somewhere. but apparently don't flow as well as the eagle in stock form.
6.4 "Apache" IIRC was 2011+ will go 340 OOTB and 400 ported
All heads interchange. Always use gaskets for your block that your using.
Matt
So Matt... your saying the 6.1 does not use the VVT
cam... is there any odd ball stuff that has to be
done to the 6.1 during a build
Re: re release 6.1 blocks??????? [Re: MR_P_BODY] #1709493
12/12/14 02:56 PM
12/12/14 02:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... this is what I got for info... by the way the
Kevin I talked to over at Orchard Dodge ISNT Kevin
Moore... but Kevin Moore buys his parts through Orchard
Dodge..... as of now there is no block being produced
(P5153816ab).. right now there is still just the 12
that are on back order... as far as I can see there
is no plans on casting any.. unless they get some magic
number of units on back order(no one knows how many
units that number is, whether it be 50 or 100 )..
I have a call into Kevin right now and am awaiting
his call back..... by the way.. Chrysler employees
or retirees get 25% off.... I'll update any info
when I get the call back from Kevin.... for you
guys that would like his phone #.. 248-439-0261....
so basically guys...... DONT HOLD YOUR BREATH
Re: re release 6.1 blocks??????? [Re: MR_P_BODY] #1709494
12/12/14 04:10 PM
12/12/14 04:10 PM
gregsdart Offline
gregsdart  Offline
Thanks for the update Mike. I am one of the twelve back orders. I do have a 5.7 so it isn't the end of the world, but those extra cubes would have been nice, plus a brand new block ready for cam bearings and drop the pistons in.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: re release 6.1 blocks??????? [Re: gregsdart] #1709495
12/12/14 04:18 PM
12/12/14 04:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I hear ya Greg... I was thinking of one.. hell $1000
for a new block would have been great... (was $1030
today) but since there is none who knows what the price
will be IF they produce the block... I was asking
about other sizes also.. looks like they dont make
anything for aftermarket
Re: re release 6.1 blocks??????? [Re: MR_P_BODY] #1709496
12/12/14 04:27 PM
12/12/14 04:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I bet they will be double since they are no longer a production line thing, but it will not be a bad price even at that. Of course I have an 03 dated 5.7 block stashed in the corner for when I get rich so no worry here
Re: re release 6.1 blocks??????? [Re: HotRodDave] #1709497
12/12/14 09:45 PM
12/12/14 09:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just got my return call from Kevin... he said that
the new date for release on these blocks is SUPPOSE
to be 1-21-15... some how he said there is 20 on back
order.... so as usual... dont hold your breath
Re: re release 6.1 blocks??????? [Re: gremlinsteve] #1709498
12/12/14 09:52 PM
12/12/14 09:52 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
I have one I'm trying to get rid of.
Any one needing a 6.1?
I sent you an email and I am interested in your 6.1 block. Please email me: mike@ostdyno.com
Thanks!
Re: re release 6.1 blocks??????? [Re: MattW] #1709499
12/12/14 10:57 PM
12/12/14 10:57 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
not the cams.
Heads
Matt
Thank you for the info!
Re: re release 6.1 blocks??????? [Re: MR_P_BODY] #1709500
12/12/14 11:55 PM
12/12/14 11:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Like I said earlier...... take a gamble and put your order in! If they show backorder there is hope. Maybe not much....but some. You try and order ANY R3 block and it spits back NS1 at you.... no longer made, and won't even show demand.
BTW for those RB guys looking at this post the mega block is in the same state of limbo. I think it showed five on back order. Believe we talked to one dealer in MI that had four on order for like two years now.
Re: re release 6.1 blocks??????? [Re: MattW] #1709501
12/13/14 10:23 AM
12/13/14 10:23 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
not the cams.
Heads
Matt
cranks will interchange journal wise but a crank from a VVT engine in a non VVT engine would require machining to allow the crank sprocket to line up with the cam sprocket. The snout of the VVT cranks are longer too. Everything on the front of a VVT engine is spaced away from the block further to accommodate the VVT. Timing covers don't interchange either.
Mopar to the bone!!!
Re: re release 6.1 blocks??????? [Re: 72Swinger] #1709502
12/13/14 11:42 AM
12/13/14 11:42 AM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
Thanks for the info Mr P. Does anyone know if a bare 6.4 block can be obtained yet? That would seem to be the hot ticket for a set of apaches on a big cube SB.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: re release 6.1 blocks??????? [Re: onebaddakota] #1709503
12/13/14 12:33 PM
12/13/14 12:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
There were no blocks available of any kind from the
dealerships.. if it isnt for production then they
arent making any..... at this time... dont hold your breath
Re: re release 6.1 blocks??????? [Re: 1badx] #1709504
12/13/14 01:34 PM
12/13/14 01:34 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Ebay item #261697456913 is a 6.1 shortblock.
Not mine, just saw it on there,,not smart enough to 'link' it
Looked at ad again,,it's from Sharadon .
If you like drag racing, support your local track.
Re: re release 6.1 blocks??????? [Re: MR_P_BODY] #1709505
12/13/14 09:38 PM
12/13/14 09:38 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
not the cams.
Heads
Matt
Sorry Mike. Just saw this.
No the 6.1 does not use the VVT.
Other than the bigger bore the only other thing is the oil squirter s.
Matt
Re: re release 6.1 blocks??????? [Re: 72Swinger] #1709506
12/13/14 09:41 PM
12/13/14 09:41 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
not the cams.
Heads
Matt
Forgot about that
Re: re release 6.1 blocks??????? [Re: 72Swinger] #1709507
12/14/14 05:53 PM
12/14/14 05:53 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
not the cams.
Heads
Matt
I have a 2012 5.7 block and I want to run all aftermarket forged bottom end. Can the non VVT aftermarket cranks be used in the 12 block with the appropriate timing cover? Is there any machine work that needs to be done to the block to make it work for non VVT application or will this even work at all? I know the plastic block plugs are needed to eliminate the MDS and planning custom lifters converted to full solid and aftermarket rocker gear.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: re release 6.1 blocks??????? [Re: Quickrunner] #1709508
12/14/14 05:59 PM
12/14/14 05:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes the aftermarket cranks work fine but need a spacer to line up the timing gears. With the VVT block you're kind of stuck with a mediocre timing chain and an expensive custom cam. Look at what Steff did to make his 392 block work, he MADE a belt drive setup, this should give you a good indication of the situation. You can lock out the cam gear to nullify the VVT also.
Re: re release 6.1 blocks??????? [Re: 72Swinger] #1709509
12/14/14 06:13 PM
12/14/14 06:13 PM
Quickrunner Offline
Quickrunner  Offline
OK, I need this broken down for me...
First: "Expensive custom cam". I seriously doubt I would run a off the shelf cam for this build anyway, a supercharged 5.7 will need a custom ground cam based on my intended power level and head flow and such so is there something I am not understanding/asking on this?
Second: "Mediocre timing chain" Please explain this... What combo has a good aftermarket timing setup currently available? Pre VVT motors?
I am in the research parts acquisition phase so if I need to look for a better setup I am interested to know what would be the hot ticket. I got the 5.7 block cheap so I'm not locked into it. I do already have a very nice set of Arrington CNC ported set of Eagle heads that I would like to use.
Re: re release 6.1 blocks??????? [Re: Quickrunner] #1709510
12/14/14 06:23 PM
12/14/14 06:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would ditch the VVT block for an earlier one. Yes you can make one work but there is no advantage to them. A stock 6.1 timing set is good to 1000+hp and is proven reliable. Melling 10342 pump. There are cams used all over for 5.7/6.1 engines. You can go solid lifter and $2000 rockers if you want but the need for them IMO only comes from wanting to RPM over 8K rpm. There are 100's of guys that have supercharged their Gen III's and many proven combo's to steal info from. LXForums and Modern Mopar forum have a ton of info and used parts to save you time and money.
Page 2 of 3 1 2 3
