Page 3 of 3 1 2 3
Re: Installing an Engine and Trans from Underneath [Re: jt4406] #1708091
12/11/14 04:23 AM
12/11/14 04:23 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Guys thank you for the great pictures and advice. Dave P, thank you for the advice on removing the bumper assembly. It looks like 6 bolts will get It and I see that you left the valance in.
Nobody came up with a photo of lifting the car by the two holes in the frame rails. In this photo I am pointing to the location. Seems like I could just stick a hook in each hole and the inward pull of the chain would keep the hooks planted.
I really appreciate all the tips. I'm going to get the wiper motor and AC unit under the dash and get started.
Lindy
I’m listening.
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708092
12/11/14 08:48 AM
12/11/14 08:48 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I wouldn't lift it by that and as mentioned not a good idea to have a V inthe chain. Get you a some angle iron and bolt it to the outside of the frame rails at the bumper bracket holes extending well in front of the car and then use another peice across the 2 as a cross bar.
Careful, your character's showing!
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708093
12/11/14 10:41 AM
12/11/14 10:41 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Lindy
Those two holes are what I used with my Daytona lifting.
Troy
Houston Mopar Connection Club
Re: Installing an Engine and Trans from Underneath [Re: hemi68charger] #1708094
12/11/14 12:27 PM
12/11/14 12:27 PM
Spokane Valley, WA
Spokane Valley, WA
Lindy
Troy, how did you attach to them?
I’m listening.
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708095
12/11/14 12:33 PM
12/11/14 12:33 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I included this photo previously. I used the 2x2 tubing with the bolt stuck up thru the hole to control anything from moving. I just put a small piece of rubber around the bolt and ended up with no damage or scratches whatsoever. This was on an A body, I'm not sure the bottom of the B Body frame is typical. It would definitely be wider.
The second set of bolts you see at the inside of the rail was originally for the chain but I didn't attach it there.
...FAFO...
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708096
12/11/14 12:48 PM
12/11/14 12:48 PM
Houston, Tx
Houston, Tx
I used the tie-down straps that have the hooks on the end, fit right into the holes and the other ends went up to the lift.. I used two of these...
Troy
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708097
12/11/14 01:28 PM
12/11/14 01:28 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1) Mopar frame holes are easily damaged so be careful; DAMHIK
2) Do not allow the chain to pull towards the center: use a spreader or something that avoids that scenario (see #1)
3) No offence to anyone else, but I would stick with chain and would avoid trusting my freshly painted car to a set of ratchet straps....even good ones.
The method I used worked perfectly and I would do it the exact same way again BUT I would put an angle or even a 2x4 between the angles to keep them in-line. I ended up distorting the area of the bumper mounting bolts due to the V in the chain....a bit of a PITA to fix.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Installing an Engine and Trans from Underneath [Re: DPelletier] #1708098
12/11/14 06:01 PM
12/11/14 06:01 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Sorry! Sorry. I couldn't resist!
Nylon straps used here:
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Installing an Engine and Trans from Underneath [Re: WyleECoyote] #1708099
12/15/14 02:23 PM
12/15/14 02:23 PM
DPelletier Offline
DPelletier  Offline
3
.....pretty sure those aren't ratchet straps and PROBABLY didn't come from Wallmart!
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708100
12/15/14 03:51 PM
12/15/14 03:51 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
To OP,
If you notice in many of the pics, where the installer has his rear jack stands located heavily influences how much weigh the hoist (and front chassis) has to support. Mine were placed just at the rear spring front perch bulkhead. Some have placed theirs at the axle tubes, which adds to the weight that must be lifted at the front. The rear jack stand location is the "balance point" of the teetering assembly, if you will. ('72 RR, btw).
With jack stands at the front spring perch bulkhead, I put about 700-800 lbs of concrete landscaping blocks in the trunk to minimize the weight at the front to be lifted. In fact, there was enough weight in the trunk to allow me to lift the front of the car with one hand. To prevent over-rotating the car onto the rear bumper, I placed another jack stand under one of the rear arches of one of the leaf springs.
The hood stayed on. The front bumper stayed on. Even had the front control arms on also, though I can't remember if the front discs were also, as I was working on the brakes before I got the engine back from the builder.
With car rotated up, engine and trans went under easy as you please. Lowered car onto dolly/engine/trans. Minimal weight on front allowed rejiggering of dolly to align frame rail/K-frame holes. Fortunately, K-frame angle on dolly (just slightly nose-down) plus flex in motor mounts allowed all four bolts to go in without trouble.
11' ceilings at that garage, but front was under garage door at 8'. Still had enough room (with hood closed) to get front high enough to roll engine under.
Re: Installing an Engine and Trans from Underneath [Re: MoparMarq] #1708101
12/15/14 03:53 PM
12/15/14 03:53 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Engine on dolly.
Re: Installing an Engine and Trans from Underneath [Re: Big Bad Bee] #1708102
12/31/14 04:45 PM
12/31/14 04:45 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Would it be a good idea to replace the 40 year old K frame bolts with brand new ones?
Or just reuse the old ones?
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Installing an Engine and Trans from Underneath [Re: RylisPro] #1708103
12/31/14 04:50 PM
12/31/14 04:50 PM
RSNOMO Online rolleyes
Moparts Torchbearer
RSNOMO  Online Rolleyes
Moparts Torchbearer
They're pretty stout...
I've never seen 'em deteriorated to the point of not being usable...
Not to say it isn't possible...
Clean and inspect...
Page 3 of 3 1 2 3
