New rods for my 572? #1707668
12/07/14 01:25 PM
12/07/14 01:25 PM
Penna
70satelliteguy Offline OP
Penna
I've had this combination together since 09 and it is time!
My Mega block needs 30 over and the BME 396 Aluminum rods have 339 passes on them. This includes some Nitrous passes with 300 HP hits.
70 B body 3600 lbs.,727 w/brake,Dana 4:10,14 in. Goodyears. mid 9's high 8's on juice.
Can someone recommend a replacement rod? I would like to put another aluminum one in there but I am retired now and am looking for something that will last longer.
Thanks Mike
Re: New rods for my 572? [Re: 70satelliteguy] #1707669
12/07/14 01:51 PM
12/07/14 01:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
GRP.. quality material used in them
Re: New rods for my 572? [Re: 70satelliteguy] #1707670
12/07/14 01:56 PM
12/07/14 01:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Thanks Mike
That's good to hear. My 572 has BME 426 forgings. 203 passes in 2 years. I'm going to run them one more season.
Doug
Re: New rods for my 572? [Re: 70satelliteguy] #1707671
12/07/14 02:00 PM
12/07/14 02:00 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
R&R aluminum rods
Re: New rods for my 572? [Re: GTS340] #1707672
12/07/14 02:18 PM
12/07/14 02:18 PM
Penna
Penna
If I could get a good price on Aluminum I would go with them again but as I said I would like to maybe go with something less expensive in STEEL . In realize if I subtract the difference I would not be saving much but I am looking at down the road in a few more years and having to replace them AGAIN!!
Thanks Mike
Re: New rods for my 572? [Re: 70satelliteguy] #1707673
12/07/14 03:03 PM
12/07/14 03:03 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Callies Compstars are decent, bang for the buck. Oliver, Crower, Manly,Carrilo are all good rods, but are in the price range, or higher, than BME Aluminum, but will likely last as long as 5 sets of Aluminum rods. Remember switching from alum. to steel you will be putting Mallory metal, [$$$$], to balance the crank, because the steel rods will be a couple hundred grams, [each], heavier. You could spend $5000+ and get a set of Crower titanium rods and have the strength of steel and the weight of aluminum.
Re: New rods for my 572? [Re: qwkmopardan] #1707674
12/07/14 04:28 PM
12/07/14 04:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
GRP or MGP are the best options IMO. We just recently pulled the engine in the Cuda to freshen it. The GRP rods in it had 404 passes on them. The engine makes just under 1100hp and this is typical. We pull them at 400 laps no failures.
Re: New rods for my 572? [Re: Al_Alguire] #1707675
12/08/14 12:12 PM
12/08/14 12:12 PM
Sterling Heights, MI
John_T_Brown Offline
MGP if you want to spin it HIGH and HARD!
If it ain't broke fix it anyway!
Re: New rods for my 572? [Re: John_T_Brown] #1707676
12/08/14 12:17 PM
12/08/14 12:17 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
My 505/B1/Megablock took three pieces of Mallory going from GRP to top of the line Manley steels. Mine's mostly a street motor on E85. A solid hit on N2O plus decent heads makes me think aluminum rods are safer just for soaking up some stress. A refresh is way cheaper than driving over the crank. S/F....Ken M
Re: New rods for my 572? [Re: EchoSixMike] #1707677
12/08/14 05:34 PM
12/08/14 05:34 PM
Penna
Penna
I do not spin the motor very high. With 4:10's it traps around 6500 on motor and just at 7000 on juice which we only use a few times a year on heads up events. I am tempted to run them another year(339 on them now) but I am not a gambler even though I don't know anyone who has broken an Aluminum rod.
Mike
Re: New rods for my 572? [Re: 70satelliteguy] #1707678
12/08/14 05:39 PM
12/08/14 05:39 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Mike
Wow, I do...me. And lot's of other people too. You got good use out of those and I would replace them....JMO.
Re: New rods for my 572? [Re: camastomcat] #1707679
12/08/14 07:17 PM
12/08/14 07:17 PM
Queensland
N
NOM36 Offline
NOM36  Offline
N
Queensland
I am currently putting together a 572 with GRP rods.
Do you guys let the engine brake in shutdown area or shift to neutral?
I am using a reverse pattern shifter so not much of an option.
Re: New rods for my 572? [Re: NOM36] #1707680
12/08/14 07:39 PM
12/08/14 07:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you spin it high RPM it is advised to use the clean
neutral... I didnt have it in my trans and I was gonna
spin mine to 9000+... but it was a smaller cube engine..
the clean neutral just gives more life to the rods
Re: New rods for my 572? [Re: MR_P_BODY] #1707681
12/08/14 07:50 PM
12/08/14 07:50 PM
Queensland
N
NOM36 Offline
NOM36  Offline
N
Queensland
Ok, I only plan on running 7000rpm.
Heard similar about high rpm. I'll be lucky to put 60+ passes a year down anyway. Replacing every few years won't hurt the pocket too much.
Re: New rods for my 572? [Re: NOM36] #1707682
12/08/14 08:02 PM
12/08/14 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
GRP told me you can get WAY more than the old 300 runs
on them... if I have the clean neutral and werent spraying
I could think of 600 passes... but I dont know about
that number... and I was gonna use LIGHT pistons
Re: New rods for my 572? [Re: MR_P_BODY] #1707683
12/09/14 11:41 AM
12/09/14 11:41 AM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
Taking mine out this weekend ... They only have 617 passes on them in 3 years. They are GRP standard series 6.950 long.2.200 big end and .990 pin.. Trap at 6900 and shift at 6800.
I think if the oil system is up to par the bearings stay good in turn helps the rod live.. Rods usually don't break just because they do..There is normally another malfunction that helps the rod break.
Re: New rods for my 572? [Re: camastomcat] #1707684
12/09/14 01:29 PM
12/09/14 01:29 PM
Penna
Penna
"Wow, I do...me. And lot's of other people too. You got good use out of those and I would replace them....JMO."
camastomcat Could you elaborate about your rod breaking
Thanks Mike?
