Page 1 of 3 1 2 3
aluminum sealing washers 4 external oil pan lines? #1707521
12/07/14 08:46 AM
12/07/14 08:46 AM
Chesterfield Twp. Mi.
John Burdine Online work OP
John Burdine  Online Work OP
does anyone know who makes the aluminum sealing washers for oil pan external lines? thought it was AR Engineering, just don't see them on the website.
Re: aluminum sealing washers 4 external oil pan lines? [Re: John Burdine] #1707522
12/07/14 08:53 AM
12/07/14 08:53 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: aluminum sealing washers 4 external oil pan lines? [Re: astjp2] #1707523
12/07/14 08:58 AM
12/07/14 08:58 AM
nope, somebody machines solid aluminum washers with O-rings that seal the fittins for external oil lines with swinging or static pick ups.
Re: aluminum sealing washers 4 external oil pan lines? [Re: John Burdine] #1707524
12/07/14 09:02 AM
12/07/14 09:02 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That is the bottom link. I used the -12 for my 3/4" lines...
I have a bunch if I can find them......and drop them into an envelope for you.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: aluminum sealing washers 4 external oil pan lines? [Re: astjp2] #1707525
12/07/14 11:13 AM
12/07/14 11:13 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Doty washers. I bought several sets years ago so I didn't have to search for them every time I needed a set.
https://board.moparts.org/ubbthreads/show...amp;Search=true
http://www.google.com/cse?cx=partner-pub...&gsc.page=1
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707526
12/07/14 01:10 PM
12/07/14 01:10 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Kind of funny - same question from the same person 4 years ago. Tough getting old I do that same stuff all the time!!!
Re: aluminum sealing washers 4 external oil pan lines? [Re: max_maniac] #1707527
12/07/14 01:22 PM
12/07/14 01:22 PM
PA.
"Little"John
"Little"John
PA.
Ya I got a kick out of that too.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707528
12/07/14 05:22 PM
12/07/14 05:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Are they better then the white nylon ones??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: aluminum sealing washers 4 external oil pan lines? [Re: hemi-itis] #1707529
12/07/14 05:35 PM
12/07/14 05:35 PM
yes that was me, and yes I'm getting older-ish. were can you buy the dang things?
Re: aluminum sealing washers 4 external oil pan lines? [Re: hemi-itis] #1707530
12/07/14 05:38 PM
12/07/14 05:38 PM
PA.
"Little"John
"Little"John
PA.
YES.!!!!!!!!!!!!!
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707531
12/07/14 07:18 PM
12/07/14 07:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Earls "stato-seals" work well too
Monte
Re: aluminum sealing washers 4 external oil pan lines? [Re: Monte_Smith] #1707532
12/07/14 10:24 PM
12/07/14 10:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Monte
Yes, all or most of the AN fittings company's offers them. I'm pretty summit and those places sell them.
Then there's a cool racing hardware store right near the Raceway Park in Indy, on the corner almost. Just down the street from Bruce Litton trailers. I always made a point to stop there and stock up on hard to find hardware like these.
Re: aluminum sealing washers 4 external oil pan lines? [Re: John Burdine] #1707533
12/07/14 10:54 PM
12/07/14 10:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I cannot find the ones I use....They are a big aluminum washer with a groove for an o-ring and it came with them...Put that washer with o-ring under the bulkhead nut and snug it...Totally leak free....Can't find them though...Mayb e I will draw one up in Solid Works tomorrow if I have time...
Re: aluminum sealing washers 4 external oil pan lines? [Re: Dragula] #1707534
12/07/14 11:23 PM
12/07/14 11:23 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Sorry this is the best picture I have.
I used some large metal washers and cut a piece of our gasket material to fit and seal.
Been that way 7 years? So I guess it's working
Re: aluminum sealing washers 4 external oil pan lines? [Re: roadhazard] #1707535
12/07/14 11:54 PM
12/07/14 11:54 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
guys i'll make a bunch of these tomorrow. just tell me what id hole is needed for the fittings your running. I've got plenty of material on the shelf and lots of o rings in stock. I'm sure I can piece something together to get you going. aluminum disc with o ring groove and o ring. no problem.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: aluminum sealing washers 4 external oil pan lines? [Re: John Burdine] #1707536
12/08/14 02:22 AM
12/08/14 02:22 AM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: aluminum sealing washers 4 external oil pan lines? [Re: pittsburghracer] #1707537
12/08/14 02:34 AM
12/08/14 02:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
And if you don't use thread sealant on the pickup fittings, all the fancy washers in the world won't seal the leaks.
Re: aluminum sealing washers 4 external oil pan lines? [Re: Stanton] #1707538
12/08/14 05:55 AM
12/08/14 05:55 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Why buy them when we can have someone spend a few hours building them.....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: aluminum sealing washers 4 external oil pan lines? [Re: astjp2] #1707539
12/08/14 12:38 PM
12/08/14 12:38 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I know not all have access to a lathe but, I machine a receiver groove for an o ring in the face of -12 coupler or bulkhead fitting. Then use the appropriate size O-ring from the 8 dollar Harbor Freight o-ring kit. Seals against outside of pan. No leaks ever...You may be able to buy like this but, the only ones I see have the o-ring recessed into the threads where it wouldn't seem to be as effective for this.
Re: aluminum sealing washers 4 external oil pan lines? [Re: MoParFish] #1707540
12/08/14 12:40 PM
12/08/14 12:40 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
that fitting is already designed with an o ring groove. you need a special o ring to seal it. the washers that I'm making will have the pocket to use this o ring on one side and a groove for an o ring on the other. i'll post a pic after lunch so everyone gets it.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Page 1 of 3 1 2 3
