Air Grabber Hood - Vacuum Line routing & #1707298
12/06/14 04:00 PM
12/06/14 04:00 PM
Tennessee
WyleECoyote Offline OP
Tennessee
1971 Dodge Charger Air Grabber Hood -
Question 1: How are the two lines hooked up, where do they go? What is the vacuum circuit to open it?
Question 2: How can I rig up the air grabber to open when not installed on a car?
I have three 71 Charger Hoods (Air Grabber RT hood, RT Louvered black-on-black hood, and a standard bulge Super Bee hood) that I'm mounting on the wall as art in my garage.
I think it would be cool to be able to hit a switch and watch the air grabber door open!
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Air Grabber Hood - Vacuum Line routing & [Re: WyleECoyote] #1707299
12/06/14 07:43 PM
12/06/14 07:43 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
LOOKIE
Re: Air Grabber Hood - Vacuum Line routing & [Re: RJS] #1707300
12/06/14 07:45 PM
12/06/14 07:45 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
more
Re: Air Grabber Hood - Vacuum Line routing & [Re: WyleECoyote] #1707301
12/06/14 07:56 PM
12/06/14 07:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What part of Tn are you located?
Re: Air Grabber Hood - Vacuum Line routing & [Re: 71birdJ68] #1707302
12/06/14 08:11 PM
12/06/14 08:11 PM
Tennessee
Tennessee
RJS - Thank you!
I searched the internet first before asking and I couldn't find these! Much appreciated.
What is "Z"? (see below)
Wile E. Coyote
Re: Air Grabber Hood - Vacuum Line routing & [Re: 71birdJ68] #1707303
12/06/14 08:13 PM
12/06/14 08:13 PM
Tennessee
Tennessee
I'm in Friendsville; basically Maryville. 8 minutes from the Knoxville Airport.
Wile E. Coyote
Re: Air Grabber Hood - Vacuum Line routing & [Re: WyleECoyote] #1707304
12/06/14 09:20 PM
12/06/14 09:20 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
"Z" is the solenoid mounted at the dash switch. It is electrical so when car is turned off the airgrabber will automatically close regardless of switch position.
If the switch was left in open position the next time the car was started the grabber would automatically open for you.
Ron
Re: Air Grabber Hood - Vacuum Line routing & [Re: RJS] #1707305
12/06/14 09:22 PM
12/06/14 09:22 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
additional
Re: Air Grabber Hood - Vacuum Line routing & [Re: RJS] #1707306
12/06/14 09:23 PM
12/06/14 09:23 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
last
Re: Air Grabber Hood - Vacuum Line routing & [Re: RJS] #1707307
12/06/14 09:49 PM
12/06/14 09:49 PM
Tennessee
Tennessee
Ron
Ah haaaaaaa.....! Now I'm getting. Actually, thanks to you and your schematics, pictures and descriptions, I think I totally get it!
Thanks Ron,
Ron
Wile E. Coyote
Re: Air Grabber Hood - Vacuum Line routing & [Re: WyleECoyote] #1707308
12/07/14 01:10 AM
12/07/14 01:10 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
There's also an adjustment on how fast the door opens and closes. The problem with Air Grabber is the door opens in the off position and closes in the on. Still trying to figure out the problem. Maybe it's a Canadian option
Re: Air Grabber Hood - Vacuum Line routing & [Re: dart4forte] #1707309
12/07/14 03:54 PM
12/07/14 03:54 PM
Oviedo, Florida
wanna72rr Offline
wanna72rr  Offline
Oviedo, Florida
My Air Grabber does the same thing.
I've disconnected all the tubes. Put them back together according to the book and it doesn't function. Yet it does function (opposite) they way I have it connected.
I've run they lines every way possible and it only works (closed) as open and (open) as closed???
Re: Air Grabber Hood - Vacuum Line routing & [Re: wanna72rr] #1707310
12/07/14 09:07 PM
12/07/14 09:07 PM
Mesa, Arizona
Mesa, Arizona
Same here, switched the lines, changed the vacume canister and nothing works. I just live with it. I had everything apart last winter to paint the bubble so everything went back together the way it was. Still the door opens in reverse. It sometimes stays open and gradually closes. That has to do with the door adjustment.
Re: Air Grabber Hood - Vacuum Line routing & [Re: dart4forte] #1707311
12/08/14 12:28 AM
12/08/14 12:28 AM
Shoreline, Washington
72roadrunnergtx Offline
Something has to be amiss, mine is assembled correctly, hoses in the correct positions, works as designed. Switch position open, door up, closed, door down, ignition off, door closes. Will cycle about 3-4 times after engine shut down, key on, from vacuum reservoir. I would be checking for leaks in the actuator and switch, cracked switch hose nipples, and check hose routing again. Be sure the “assist” spring is in place and installed correctly and the solenoid valve hose connections are correct. The actuator bracket adjustment will not cause operational problems as described above.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Air Grabber Hood - Vacuum Line routing & [Re: 72roadrunnergtx] #1707312
12/08/14 12:36 AM
12/08/14 12:36 AM
Mesa, Arizona
Mesa, Arizona
We'll the hose is new, the hoses are connected to the correct nipples so the actuator may be the culprit. I still need to make some adjustments but that will have to wait until spring when the roads get better and the GTS is finished.
