Fresh air induction/air grabber/ramcharger
#1706871
12/05/14 12:59 PM
12/05/14 12:59 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Need some help here on getting my data straight. If you can let me know if the following is true or not I would appreciate it.
1. Before 1968 on Plymouth and Dodge B-bodies the hood scoops were just for looks and there wasn't any fresh air induction. This is just normal production cars not light weights, max wedge etc. 2. In 1968 and 1969 the air grabber for Plymouth and the ramcharger for Dodge were both black. 3. In 1969 1/2 the fresh air fiberglass hood came only on A12 cars. 4. In 1970 The Plymouth air grabber became vacume operated changed air boxes and was black and the Dodge ramcharger became orange and remained cable operated. 5. In 1968 the breather for the 4 bbl was large simular to the 1969 1/2 six pack breather. 6. In 1969 the four barrel breather had a large base but a small round filter and lid. 7. In 1970 the four barrel breather remained the same and the six pack breather was used with an addition of a front air dam?
What breathers and when was the air dam added?
Did the Hemi breather always have the air dam from 1968 - 1970?
Did the 66-67 Hemis use the chrome round breather?
Please document your answers whenever possible.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: Fresh air induction/air grabber/ramcharger
[Re: DPelletier]
#1706876
12/05/14 02:05 PM
12/05/14 02:05 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
'70 440-6 with Ramcharger (hemi used same lid)
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1706877
12/05/14 02:09 PM
12/05/14 02:09 PM
DPelletier
'70 440-6 without N96 (this is the only application for the air dam air cleaner as all hemis had the N96 standard)
1974 'Cuda
[Re: DPelletier]
#1706878
12/05/14 04:18 PM
12/05/14 04:18 PM
DPelletier
So Jim pretty much had it nailed other than AFAIK, all '69 Hemi B bodies had N96 standard (except the Charger, of course). Only other note; some early 1970 B bodies are said to have used the black Ramcharger duct....though all survivors I've seen had the orange. Dave
1974 'Cuda
[Re: DPelletier]
#1706879
12/05/14 05:04 PM
12/05/14 05:04 PM
MOPARMIKE69
Nashville, TN
So let's try this again. 1. Before 1969 on Plymouth and Dodge B-bodies the hood scoops were just for looks and there wasn't any fresh air induction. This is just normal production cars not light weights, max wedge etc. 2. In 1969 the air grabber for Plymouth and the ramcharger for Dodge were both black. 3. In 1969 1/2 the fresh air fiberglass hood came only on A12 cars. 4. In 1970 The Plymouth air grabber became vacume operated changed air boxes and was black and the Dodge ramcharger became orange and remained cable operated. 5. In 1969 the breather for the 4 bbl was large simular to the 1969 1/2 six pack breather. 6. In 1970 the four barrel breather had a large base but a small round filter and lid. 7. In 1970 larger breather was used on the six packs. 8. The air dam is only on 1970 six pack cars with out fresh air. 9. Beginning in 1969 all Hemi's had fresh air induction. (except for weird Ma Mopar never say never exceptions that are rare and are almost never documented ) Correct?
[Re: MOPARMIKE69]
#1706880
12/05/14 05:14 PM
12/05/14 05:14 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
1. Before 1969 on Plymouth and Dodge B-bodies the hood scoops were just for looks and there wasn't any fresh air induction. This is just normal production cars not light weights, max wedge etc. 2. In 1969 the air grabber for Plymouth and the ramcharger for Dodge were both black. 3. In 1969 1/2 the fresh air fiberglass hood came only on A12 cars. 4. In 1970 The Plymouth air grabber became vacume operated changed air boxes and was black and the Dodge ramcharger became orange and remained cable operated. 5. In 1968 the breather for the 4 bbl was large simular to the 1969 1/2 six pack breather. negative 6. In 1969 the four barrel breather had a large base but a small round filter and lid.negative answered by Jim 7. In 1970 the four barrel breather remained the same and the larger six pack breather was used. 8. The air dam is only on 1970 six pack cars with out fresh air.
Correct?
Look on nicks garage, most if not all your air cleaner questions can be answered.
http://www.nicksgarage.com/aircleaner.htm
[Re: RobX4406]
#1706881
12/05/14 05:22 PM
12/05/14 05:22 PM
MOPARMIKE69
Nashville, TN
Yes Rob X thanks for correcting my typos. I have since your post edited and corrected the dates.
Re:'68-'70 Fresh air induction/air grabber/ramcharger
[Re: MOPARMIKE69]
#1706882
12/05/14 06:12 PM
12/05/14 06:12 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
1. Before 1969 on Plymouth and Dodge B-bodies the hood scoops were just for looks and there wasn't any fresh air induction. This is just normal production cars not light weights, max wedge etc. 2. In 1969 the air grabber for Plymouth and the ramcharger for Coronet were both black. 3. In 1969 1/2 the fresh air fiberglass hood came only on A12 cars. 4. In 1970 The Plymouth air grabber became vacuum operated changed air boxes and was black and the Coronet ramcharger became orange and remained cable operated. 5. In 1969 the AIR GRABBER/RAMCHARGER breather LID for the 4bbl & HEMI was the same large OVAL similar to the 1969 1/2 six pack breather LID (bases are obviously different). 6. In 1970 the N96 four barrel breather had a large OVAL base but a small round filter and lid. 7. In 1970 A NEW larger breather LID w/o "RAIN GUTTER" was used on the six pack & HEMIS USED THE SAME LID FROM '69. 8. The air dam is only on 1970 six pack & HEMI cars with out fresh air OR CALIFORNIA "NOISE REDUCTION" N97. 9. Beginning in 1969 all Hemis (EXCEPT '69-'70 non-CHARGER or WING CAR) had fresh air induction. then there's the '71-'72 N96 b-body cars
[Re: DPelletier]
#1706883
12/05/14 06:18 PM
12/05/14 06:18 PM
6bblgt
Las Vegas, NV
Orange '69-'71 HEMI w/N96 oval lid is the same as '69 b-body w/N96. Orange '69-1/2 440+6 (A12) oval lid is the same as '70 340+6 (A53) Orange '70-'72 440+6 oval lid is the same
[Re: DPelletier]
#1706885
12/08/14 11:13 AM
12/08/14 11:13 AM
MOPARMIKE69
Nashville, TN
Hey DPelletier, do you remember where you got that picture of the six bbl road runner engine? The reason I ask is because that is the engine compartment of my 69 1/2 road runner that I showed at the Nats in the O.E level back in 1993. It looks like the same shot that Tom Shaw took and was in the 1994 edition of Mopar Muscle. I would love to know man.
