Painting a plastic grill #1706184
12/03/14 06:28 PM
12/03/14 06:28 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well my grill repair went well on my 69 Charger so now I need to look into paint. Is there any primer needed first? What kind of paint and colors match best? I need black and the silver for the grill. What about flex agent for the paint? Thanks.
Re: Painting a plastic grill [Re: fastmark] #1706185
12/03/14 11:43 PM
12/03/14 11:43 PM
MO
cdp Offline
cdp  Offline
MO
I used argent from a Totally Auto, and Krylon/Rustoleum black. You have to find the right black. there is flat, satin, semi-gloss, etc. I think I used satin. When I restored the grille in my 71 RR, I was happy with the results.
Masking sucks though. Be patient. Clean with wax/grease remover.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Painting a plastic grill [Re: cdp] #1706186
12/04/14 01:53 AM
12/04/14 01:53 AM
Shelton ,CT
B5cudavert Offline
B5cudavert  Offline
Shelton ,CT
Use denatured alchohal to clean the plastic! Nothing else or you may have a reaction. Also after that dries ,use Bulldog adheshion promoter. Spray it on lightly covering all the areas you will paint. Let it dry a bit,mThen prime & paint away. Plastic is tricky to work with, especially if theirs old paint on the part.
good luck!
