Dana Power Lok clutch plates #1706122
12/03/14 09:27 AM
12/03/14 09:27 AM
WI
RestoRick Offline OP
WI
I'm assembling a Dana power lok unit for my street rod. I'm finding optional information on the order of the clutch discs.
Figure 14 on this assembly manual Dana Power Lok was what I started to do, however, after studying the order of the discs from the factory assembly I've found they were different; it was setup like Figure 16.
This is the 3 friction surface setup.
So, long story shortened.. for a street driven car, 3 or 5 friction surface setup?
Re: Dana Power Lok clutch plates [Re: RestoRick] #1706123
12/03/14 12:15 PM
12/03/14 12:15 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi, 5 friction setup. ronnie
Re: Dana Power Lok clutch plates [Re: RestoRick] #1706124
12/03/14 12:15 PM
12/03/14 12:15 PM
Polson, MT
DoctorDiff Online content
DoctorDiff  Online Content
Polson, MT
8.75" and Dana 60 do not use the same clutch sequence.
If you are building an 8.75", see the middle of this link:
http://www.moparts.org/Tech/Archive/axle/13.html
Re: Dana Power Lok clutch plates [Re: DoctorDiff] #1706125
12/03/14 05:25 PM
12/03/14 05:25 PM
WI
WI
Perfect.. yes 8 3/4" as you know..
Thanks!
