Dana Power Lok clutch plates #1706122
12/03/14 10:27 AM
12/03/14 10:27 AM
WI
RestoRick Offline OP
WI
I'm assembling a Dana power lok unit for my street rod. I'm finding optional information on the order of the clutch discs.
Figure 14 on this assembly manual Dana Power Lok was what I started to do, however, after studying the order of the discs from the factory assembly I've found they were different; it was setup like Figure 16.
This is the 3 friction surface setup.
So, long story shortened.. for a street driven car, 3 or 5 friction surface setup?
Re: Dana Power Lok clutch plates [Re: RestoRick] #1706123
12/03/14 01:15 PM
12/03/14 01:15 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi, 5 friction setup. ronnie
Re: Dana Power Lok clutch plates [Re: RestoRick] #1706124
12/03/14 01:15 PM
12/03/14 01:15 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
8.75" and Dana 60 do not use the same clutch sequence.
If you are building an 8.75", see the middle of this link:
http://www.moparts.org/Tech/Archive/axle/13.html
Re: Dana Power Lok clutch plates [Re: DoctorDiff] #1706125
12/03/14 06:25 PM
12/03/14 06:25 PM
WI
WI
Perfect.. yes 8 3/4" as you know..
Thanks!
