Page 3 of 5 1 2 3 4 5
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705495
12/03/14 05:54 PM
12/03/14 05:54 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Hey Steff, just curious because I know basically nothing about those motors....What are the advantages to building one of those versus a big block?? Is it cheaper??
Hey Wayne, Big Block power in a lighter, smaller package? I dunno, I just love these motors and I'll never build anything else. Stock blocks holding up to good power....stock heads, cnc ported flowing 360+ cfm. Cost wise, good parts cost what they do regardless of platform. To me, it's build what makes you happy. These make me happy.
Thanx Guys!
Cool...How much power will that block safely handle? How many cubes can you get out of one? Are you running a stock oil pan? Can you buy headers and mounts that fit your car? 727 with adapter??
If you can't handle the truth, you're living a lie.......
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Big Squeeze] #1705496
12/03/14 06:15 PM
12/03/14 06:15 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Thanx Guys!
your asking the wrong guy. Steff made almost everything. But to answer your question, you can buy almost everything you need to do a swap. 727/904 bolts right up just need a flexplate. Blocks are good past 1000
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: sixpackgut] #1705497
12/03/14 07:49 PM
12/03/14 07:49 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Looks good Steff. First chance I have had to look at video. Looks too loose in the front to me. I know you said you were putting a better shock on the front. I believe that will help it
Monte
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Monte_Smith] #1705498
12/03/14 08:31 PM
12/03/14 08:31 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I saw a filled stock 6.1 block in Tim Barth's challenger make just shy of 1700whp. And that was before an after market head casting, was still on stock rockers and lifters. Impressive stuff no doubt
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Big Squeeze] #1705499
12/03/14 09:31 PM
12/03/14 09:31 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Hey Wayne, I made my headers and oil pan as I love making stuff, but like Gut mentioned, there's plenty of stuff available to put one in darn near anything. As for max cubes, I know a few companies make a 4.25 stroke crank and the largest bore in a stock block is in a 6.4 block...4.095. Mines at 4.100. I think the MP 6.1 Aluminum Block can go to 4.188 bore. A 727 or 904 Small BLock trans bolts right up. I'm using a Turbo 400 with a JW Ultrabell.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Monte_Smith] #1705500
12/03/14 09:37 PM
12/03/14 09:37 PM
STEFF Offline OP
STEFF  Offline OP
Monte
Thanx Monte! If I make it out again this year, I'm going to tighten up the extension on the shock and sneak up on it, to where it effects the 60'. And yes, I'm going to get some new DA front shocks. I notice the front end bounces on the landing and I cannot adjust the compression as my Afco's are single adjustable.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705501
12/03/14 10:13 PM
12/03/14 10:13 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
It is projects like this that me consider building a gen 3 at some point. Looks and runs great. 70 Runners are the meanest looking cars in black.
Thanx Guys!
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Bigbeep] #1705502
12/03/14 11:33 PM
12/03/14 11:33 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Thanks, Steff and Ray...
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: Big Squeeze] #1705503
12/12/14 03:21 PM
12/12/14 03:21 PM
STEFF Offline OP
STEFF  Offline OP
Heading out tomorrow for the last time of the year. Going to Darlington Dragway. Made a rear gear change from 4.57 to 4.86. May retard the cam timing a few degrees, to see what it does.
Also, Darlington is a 1/4 mile track, where all my previous testing was on an 1/8 mile track.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705504
12/12/14 03:33 PM
12/12/14 03:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good luck Steff... get some good runs in
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705505
12/12/14 04:50 PM
12/12/14 04:50 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Ought to be some really good air tomorrow.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: an8sec70cuda] #1705506
12/12/14 05:05 PM
12/12/14 05:05 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Good luck Steff!
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: TheOtherDodge] #1705507
12/13/14 10:45 PM
12/13/14 10:45 PM
STEFF Offline OP
STEFF  Offline OP
Managed to get one good pass out of 5 attempts today. Track prep at Darlington blows! First attempt blew the tires off. Loosened up the shocks 2 clicks and took 500 out of the t-brake launch. Worked for that pass. Ran 9.90 @ 133.3, 1.31 60ft. After that something changed. Tried a couple more times with few different shock settings and launch rpms and couldn't get it to repeat. I don't care. I got what I needed, which was where it traps in the 1/4, and to see if it liked the change from 4.57 to 4.86 gear. I think it did. The weather today was darn near identical to when I went out 2 weeks ago. I'll post video later.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705508
12/13/14 11:08 PM
12/13/14 11:08 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Your one good pass got me tortured all the way home. Great meeting you today
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: sixpackgut] #1705509
12/14/14 12:11 PM
12/14/14 12:11 PM
STEFF Offline OP
STEFF  Offline OP
Ray,
It was great to meet you and hang out for the afternoon. My Son got a kick out of your Buddies. They like to have alot of fun at your expense....LOL!!
Here's the video from yesterday.
https://www.youtube.com/watch?v=TCLSt5e12mQ
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705510
12/14/14 01:25 PM
12/14/14 01:25 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Love how that thing leaves Steff.
Mopar to the bone!!!
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705511
12/14/14 01:59 PM
12/14/14 01:59 PM
gregsdart Offline
gregsdart  Offline
Steff, congrats on putting together a great ride I wish I had your fabricating talents. The performance is great, and I am betting there is more in it, based on comparing the 9.90 ET to the mph. The computec predicts a mph of 137.63 for a 9.90. I don't know how much a full sized B body effects mph, but I doubt it is 4+ mph?
Agsin,
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: gregsdart] #1705512
12/14/14 02:15 PM
12/14/14 02:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
wow very nice Steff, makes me want a gen3
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: gregsdart] #1705513
12/14/14 02:24 PM
12/14/14 02:24 PM
STEFF Offline OP
STEFF  Offline OP
Agsin,
Thanx Greg! I really appreciate the compliment. I was talking to HardcoreB yesterday. He said the same thing. I'm not sure where it's hiding.
Re: Fun Summer with my Road Runner and Gen 3 Hemi [Re: STEFF] #1705514
12/14/14 03:26 PM
12/14/14 03:26 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Good work! What was your 1/8 mile on that pass compared to previous. Man that's a lot of gear, cool that the motor likes it
