Just wondering, this "is" where I can get answers?!
#1705399
12/01/14 11:26 AM
12/01/14 11:26 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
No matter how opinionated they may be. When I got my 416 stroker back from the machine shop, it had ARP main bolts in it. This would have been fine, but I distinctly remember telling the builder I wanted ARP studs in there. Long story short: I had a set (ARP studs,new) laying around the shop. So I flipped the short block over, removed the bolts, and installed the studs (as per ARPs specs). My question: will the builder get peed off (I know, you don't know him, but if it were you?), have I disrupted the integrity of the build? Any other stuff you kings of engine building can come up with pertaining to this question? Oh, by the way, the builder had to take the short block back 'cause he put the wrong rings in too. He tore down the short block, built it back up using my per-installed studs, and never said a word. I guess I'm just wondering what your thoughts on my bolt/stud swap are if he didn't have to put the new rings in? The engine's been running great for months now. Thanks, M
Re: Just wondering, this "is" where I can get answers?!
[Re: ScottSmith_Harms]
#1705401
12/01/14 12:48 PM
12/01/14 12:48 PM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
I would agree with Scott unless he had the crank out when replacing the rings. Then I would say he reassembled it with the studs in place therefore his problem. And yes find another shop 2 errors on 1 build ???? I do know of a long established shop in Walnut Creek
[Re: TJP]
#1705402
12/01/14 12:51 PM
12/01/14 12:51 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pretty sure main studs are NOT a drop in replacement for main bolts.
[Re: Supercuda]
#1705404
12/01/14 01:18 PM
12/01/14 01:18 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
ARP is a top tier company - if they weren't a "drop in" they'd have included instructions.
Why should end play change? The studs use the same holes as bolts.
I suspect when the OP installed the studs he did not remove the caps. When the bozo swapped the rings, he probably didn't either - that would have been unnecessary and more work on his dime.
Checking end play is easy enough - I just don't see the point.
[Re: Stanton]
#1705405
12/01/14 01:58 PM
12/01/14 01:58 PM
Posts: 3,916 usa
lewtot184
usa
arp does give instructions specific to studs. studs are slightly larger in diameter vs bolts plus they wobble. a couple thousands here a couple there and the caps have moved. been thru this!
[Re: lewtot184]
#1705406
12/01/14 02:01 PM
12/01/14 02:01 PM
Posts: 15,871 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Interesting he didn't mention it. Admission he didn't do the right thing?
Facts are stubborn things.
