Just wondering, this "is" where I can get answers?! #1705399
12/01/14 11:26 AM
12/01/14 11:26 AM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
No matter how opinionated they may be.
When I got my 416 stroker back from the machine shop, it had ARP main bolts in it. This would have been fine, but I distinctly remember telling the builder I wanted ARP studs in there. Long story short: I had a set (ARP studs,new) laying around the shop. So I flipped the short block over, removed the bolts, and installed the studs (as per ARPs specs). My question: will the builder get peed off (I know, you don't know him, but if it were you?), have I disrupted the integrity of the build? Any other stuff you kings of engine building can come up with pertaining to this question?
Oh, by the way, the builder had to take the short block back 'cause he put the wrong rings in too. He tore down the short block, built it back up using my per-installed studs, and never said a word.
I guess I'm just wondering what your thoughts on my bolt/stud swap are if he didn't have to put the new rings in? The engine's been running great for months now.
Thanks,
Re: Just wondering, this "is" where I can get answers?! [Re: bigblock340power] #1705400
12/01/14 12:00 PM
12/01/14 12:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
It seems that he isn't a good communicator or a good listener. etc. If you (the customer) asked for something specific you should have gotten it, or he should have given reasons for not wanting to do it the way you wanted and settled that with you before moving forward. In short? I'd have looked for a different engine builder.
If you are asking if changing something he did without his input or approval voids your warranty with him? I'd say yes, it does. That would be chalked up to a mistake on your part although what you did is probably just fine, it leaves the excuse door wide open to blame any future failure on you.
Re: Just wondering, this "is" where I can get answers?! [Re: ScottSmith_Harms] #1705401
12/01/14 12:48 PM
12/01/14 12:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would agree with Scott unless he had the crank out when replacing the rings. Then I would say he reassembled it with the studs in place therefore his problem.
And yes find another shop 2 errors on 1 build ????
I do know of a long established shop in Walnut Creek
Re: Just wondering, this "is" where I can get answers?! [Re: TJP] #1705402
12/01/14 12:51 PM
12/01/14 12:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure main studs are NOT a drop in replacement for main bolts.
Don't be the exception.
Re: Just wondering, this "is" where I can get answers?! [Re: Supercuda] #1705403
12/01/14 12:57 PM
12/01/14 12:57 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
going from bolts to studs; be sure and check the end play in the crank!
Re: Just wondering, this "is" where I can get answers?! [Re: Supercuda] #1705404
12/01/14 01:18 PM
12/01/14 01:18 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
ARP is a top tier company - if they weren't a "drop in" they'd have included instructions.
Why should end play change? The studs use the same holes as bolts.
I suspect when the OP installed the studs he did not remove the caps. When the bozo swapped the rings, he probably didn't either - that would have been unnecessary and more work on his dime.
Checking end play is easy enough - I just don't see the point.
Re: Just wondering, this "is" where I can get answers?! [Re: Stanton] #1705405
12/01/14 01:58 PM
12/01/14 01:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
arp does give instructions specific to studs. studs are slightly larger in diameter vs bolts plus they wobble. a couple thousands here a couple there and the caps have moved. been thru this!
Re: Just wondering, this "is" where I can get answers?! [Re: lewtot184] #1705406
12/01/14 02:01 PM
12/01/14 02:01 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Interesting he didn't mention it. Admission he didn't do the right thing?
Facts are stubborn things.
Re: Just wondering, this "is" where I can get answers?! [Re: larrymopar360] #1705407
12/01/14 02:09 PM
12/01/14 02:09 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
what did you torque the studs too? what did he torque the caps to when he line bored it? arp has specific torqueing instructions included with their bolts and studs and they are higher than factory torque ratings. time to recheck and get some answers at a minimum.
for him not remembering what he put in your engine, not a big deal. for him using the wrong parts? that is a big deal.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Just wondering, this "is" where I can get answers?! [Re: Stanton] #1705408
12/01/14 02:26 PM
12/01/14 02:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They do, here's the link http://arpinstructions.com/instructions/240-5501.pdf
Just in case you miss it here's the relevant instruction
"FOOTNOTE:
When changing from factory fasteners to high strength fasteners, clamping force and tolerances will change, therefore it will be necessary to check the main bearing bores for proper size and out of round condition after installation of the studs and align hone the cylinder block if necessary. The main bores should always be align honed using the same fasteners and lubricant which will be installed during final engine assembly at the recommended preload. "
Re: Just wondering, this "is" where I can get answers?! [Re: bigblock340power] #1705409
12/01/14 03:57 PM
12/01/14 03:57 PM
I've swap main bolts for studs after having new main caps installed on my first 400 stroker motor, not the same motor but both yours and mine have two main bolts and both had ARP fasteners like yours. I did measure the main bore before and after and saw right at .0002 differences, not enough for me to worry about when I had over .0035 clearances to start with I think the last perfect man on earth is not here anymore, he is sitting beside his father in heaven, according to the bible I believe. My message is you should have discuss this with your engine builder when you discovered the error, he may or may not have fixed it or told you why, if he diecided to ignore youur desires and put the bolts in instead of doing what you wanted. I'm a firm believer in when a shop makes one mistake give them a chance to fix it, when they make two or more it is time to find a better shop BTW, good shops are a lot harder to find than the not so good ones out there Good luck
Re: Just wondering, this "is" where I can get answers?! [Re: bigblock340power] #1705410
12/01/14 07:26 PM
12/01/14 07:26 PM
the builder had to take the short block back 'cause he put the wrong rings in too. The engine's been running great for months now.
Is the power/compression/leakdown/oil consumption good/acceptable right now?
