Page 3 of 20 1 2 3 4 5 19 20
Re: Demon build [Re: Stroker Scamp] #1702779
12/08/14 02:06 PM
12/08/14 02:06 PM
Indianapolis In. usa
Quickrunner Offline OP
How are you planning to attach the wheel tub to the rear quarter panel?
Keeping to stock outer tub in place with a little massaging of the lip. Adding 3 1/2 inches and moving inner tub just flush with the rail after the rail it's self was modified.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build [Re: Quickrunner] #1702780
12/08/14 02:11 PM
12/08/14 02:11 PM
More pics
Re: Demon build [Re: Quickrunner] #1702781
12/08/14 02:12 PM
12/08/14 02:12 PM
Removed tub and crawled in and out of trunk aprox 73 times to get this fit! LOL
Re: Demon build [Re: Quickrunner] #1702782
12/08/14 03:19 PM
12/08/14 03:19 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You did an outstanding job fitting that trunk hinge panel.......however, that panel is pretty darn flexible, so it sure would have been easier to cut it off square, pull it over a tick and just weld it across the top...........LOL!!!!..........May have cut that 73 times to 2 or 3..........LOL!!!
Monte
Re: Demon build [Re: Monte_Smith] #1702783
12/08/14 03:40 PM
12/08/14 03:40 PM
Monte
Would have been easier but inner tub moved over 3 1/3 inches into this panel. The trunk lid tortion bars would have had to been shortened if I moved the panel over with the tub. There were a few cold ones and a lot of staring at it before grinder went in hand LOL. I wanted it to look like it was made like that.
Re: Demon build [Re: Quickrunner] #1702784
12/08/14 03:41 PM
12/08/14 03:41 PM
Also I did not want to move trunk hinges.
Re: Demon build [Re: Quickrunner] #1702785
12/08/14 04:06 PM
12/08/14 04:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No, I wasn't suggesting moving the hinges. If you look at the very first pic you show.......the hinge panel appears to come down at a bit of an angle towards the center of the trunk. If you had cut the hinge panel straight across the bottom and then just pulled it over a little, you could have welded it directly to top of tub............I know because I have done a few of these..........LOL!!!........but again, your fitting job is outstanding
Monte
Re: Demon build [Re: Monte_Smith] #1702786
12/08/14 06:01 PM
12/08/14 06:01 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
looking good my friend. I cant wait to see this thing sitting down.
Re: Demon build [Re: rgreule] #1702787
12/08/14 06:31 PM
12/08/14 06:31 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Darts are definitely easier at the trunk support! You did a great very seamless tub job doing it how you did.
Mopar to the bone!!!
Re: Demon build [Re: Quickrunner] #1702788
12/08/14 11:29 PM
12/08/14 11:29 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Can you measure from the frame rail to the wheel lip and tell us the dimension you now have?
Re: Demon build [Re: RV2] #1702789
12/09/14 03:49 AM
12/09/14 03:49 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
This is how mine was done.
Re: Demon build [Re: Quickrunner] #1702790
12/12/14 01:22 AM
12/12/14 01:22 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
Gotcha for some reason I thought you were doing full tubs
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Demon build [Re: Stroker Scamp] #1702791
12/13/14 04:11 PM
12/13/14 04:11 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
your doing a awesome job Dave
Re: Demon build [Re: 340RICK] #1702792
12/17/14 01:37 PM
12/17/14 01:37 PM
Got the passenger side quarter almost finished last night. Will be able to get the wheels and tires up in there tonight to get the measurement for the new Strange S60! Going all out 40 spline, 5/8 drive studs, 3.70 gear, spool, strange dual rear caliper setup.
Re: Demon build [Re: Quickrunner] #1702793
12/17/14 01:39 PM
12/17/14 01:39 PM
Tank for the go juice
Re: Demon build [Re: Quickrunner] #1702794
12/17/14 01:44 PM
12/17/14 01:44 PM
25inch front segment -1 inch Calvert split mono's. Smith assassin bars. Sliders at the rear. Reaserching a good arb settup. Cant wait to get this all under it!
Re: Demon build [Re: Quickrunner] #1702795
01/23/15 11:45 AM
01/23/15 11:45 AM
Took a little break, back on it now. Found nice little mouse nest in frame rail! LOL
Re: Demon build [Re: Quickrunner] #1702796
01/23/15 11:47 AM
01/23/15 11:47 AM
These 315's will really fill up the tub.
Re: Demon build [Re: Quickrunner] #1702797
01/23/15 11:49 AM
01/23/15 11:49 AM
Probably going to have to mod the tunnel a bit to get ride height I want.
Re: Demon build [Re: Quickrunner] #1702798
01/23/15 11:50 AM
01/23/15 11:50 AM
This thing is going to look killer when it finally gets back on the ground!
