Page 2 of 20 1 2 3 4 19 20
Re: Demon build [Re: demon440] #1702759
11/25/14 11:07 AM
11/25/14 11:07 AM
Indianapolis In. usa
Quickrunner Offline OP
Moved the front half of the quarter opening 1 1/4 inch. Looks like just a slight massage on the rear of the opening will be in order. Going to notch the rear rail and box it back in to give me another inch to the inside and the 315 will slide way up in there where it belongs!
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build [Re: Quickrunner] #1702760
11/25/14 11:08 AM
11/25/14 11:08 AM
Another pic
Re: Demon build [Re: Quickrunner] #1702761
11/25/14 11:09 AM
11/25/14 11:09 AM
Another shot
Re: Demon build [Re: 383man] #1702762
11/25/14 11:13 AM
11/25/14 11:13 AM
Nice work. I will watch you built this also as I love the Demon cars. How tall are those tires ? Ron
315/60-15 drag radial on a 12 inch Champion beadlock rim. They are 30 inch tall.
Re: Demon build [Re: Quickrunner] #1702763
11/25/14 12:28 PM
11/25/14 12:28 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
That's the same tire/wheel size I have on my Demon. The frame rails are in the stock location, wheel well and fender opening was opened up and a new bead rolled around the fender lip.
Re: Demon build [Re: Airwoofer] #1702764
11/25/14 01:07 PM
11/25/14 01:07 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
cool build. gonna look awesome when you have it sitting down.. whats the rear suspension plans?
Re: Demon build [Re: rgreule] #1702765
11/25/14 01:42 PM
11/25/14 01:42 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
also if you planning on making it sit low id put a standard tub in there.. and cut out the outer wheel house.. the outer curve in so soon that you can get much tire tucked up in there..
here is mine with a 325/50/15
i had to do a normal tub to get mine to sit low..
Re: Demon build [Re: rgreule] #1702766
11/25/14 02:00 PM
11/25/14 02:00 PM
Calvert split mono leaf long front segment(24-26inch not decided yet) moved inside rails with sliders. Smith assasin bars (similar to caltrac but lots more adjustment). Anti-roll device. Virtical mount da Afco's custom valved.
Re: Demon build [Re: rgreule] #1702767
11/25/14 02:11 PM
11/25/14 02:11 PM
I thought about that but decided to spend way to much time sectioning and moving metal around to make it look like a stock tub. Didnt want to loose the structure support that goes from top of the outer wheelhouse to package tray/quarter area as this is not going to be a full tube car. I will be doing some mod to outer in the curve as well. Tons more work but it will be slick when I get it done. Also it wont be quite as low as yours but close.
Re: Demon build [Re: Quickrunner] #1702768
11/25/14 03:14 PM
11/25/14 03:14 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
i know alot of people that dont have anything going to they're package tray support and havent had anything weird happen.. i was a little sceptical at first when i cut mine.
also digby's dart is cutting 1.12 60' with the stock 20 inch segments. on a 275. . with basically with the same stuff you have.. srd bars, arb, springs on the rails with sliders..
i would call mencer for your shocks he revalves afco DA's for leaf spring setups..
love the build man.. im in for more pictures..
Re: Demon build [Re: Quickrunner] #1702769
11/28/14 12:29 PM
11/28/14 12:29 PM
Got a little sheet metal work done last night.
Re: Demon build [Re: Quickrunner] #1702770
11/28/14 12:31 PM
11/28/14 12:31 PM
Slid quarter opening forward.
Re: Demon build [Re: Quickrunner] #1702771
11/28/14 12:37 PM
11/28/14 12:37 PM
All welded up, wont take much body work
Re: Demon build [Re: Quickrunner] #1702772
11/28/14 01:35 PM
11/28/14 01:35 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
You have skills
Re: Demon build [Re: racerx] #1702773
11/29/14 12:36 AM
11/29/14 12:36 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very nice
Re: Demon build [Re: ProSport] #1702774
12/02/14 02:40 PM
12/02/14 02:40 PM
Lip cut off frame rail and ground flush. Rail squeezed parallel, roughly these rails are over 3/4 inch wider at top than at the bottom, bent floor over edge of rail now they were parallel and welding it back up. Gained a little more room and will be able to set the inner tub in a bit further now. These 315's will be tucked up nicley inside what will look like a facroty tub, just wider
Re: Demon build [Re: Quickrunner] #1702775
12/02/14 02:47 PM
12/02/14 02:47 PM
Calvert split mono's ordered this morning to my specs and Smith Assassin bars on the way as well. Now to finish up the tub on this side, duplicate quarter pannel and tub mods on passenger side then fab up custom cross member with adjustable front spring pocket and rear adjustable slider mounts.
Re: Demon build [Re: 1967dartgt] #1702776
12/02/14 04:08 PM
12/02/14 04:08 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Yeah I know but I just like the look of the bigger tire, and not really building for a tire size limited class.
Yes agree with you on the looks department, but my car is a lot faster on the 275 then the big tires.
Think thats due to gearing or rotating mass/weight?
The pro is just that much better of a tire, newer design and compound then the orginal tire. I switched gears between the tires 4.30 with 30" tall radials and 3.91 with 28" tall pros. It's better all over 60' and et and mph.
The 275 Pro is a bad biotch, no doubt..........but BETTER than the 315?...highly unlikely. If it was, RvW and ODR cars would be using them......they don't if given a choice.
Monte
Re: Demon build [Re: Monte_Smith] #1702777
12/07/14 04:19 PM
12/07/14 04:19 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
How are you planning to attach the wheel tub to the rear quarter panel?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Demon build [Re: Stroker Scamp] #1702778
12/07/14 04:43 PM
12/07/14 04:43 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Another sweet build.
I need to open up my front wheel wells???? because the AlterKtion moving the wheels outward put the pass. side into the front of the opening on full lock right turns.
I kept the stock rear wells , but added 3 " and moved them to the rails in my '65.
It looks pretty close to factory.
No where near as ambitious tire wise , but 295-55's fit in there with change.
