72 Dart Rear Glass into 67 Dart #1702362
11/23/14 08:15 PM
11/23/14 08:15 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
I got a rear glass from a 72 Dart donor and attempted to install it into my 67 Dart.
It basically falls through the opening. It appears to be at least 1/2" too short.
I had purchased the butyl tape sealant and was ready to go but discovered this when I dry fit the glass. I guess I should have done that before I purchased the sealant. At least I had not laid down the butyl yet. It appears the glass was installed with butyl tape in the donor. I spent an hour cleaning sealant off the outer 1/2" of the glass mostly on the inside.
Are 67 and 72 Dart rear glass openings different sizes or am I missing something? Would it work if I used a gasket instead of buytl?
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702363
11/23/14 08:20 PM
11/23/14 08:20 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Are the two cars 4dr sedans or 2 dr hts . if you have a 2 dr ht and the donor is a 4 dr ........ no fit. Both cars have to be same model .
Re: 72 Dart Rear Glass into 67 Dart [Re: mopar_man] #1702364
11/23/14 08:23 PM
11/23/14 08:23 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
what did the 72 glass come from?
is the 67 a post car or hardtop?
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: 72 Dart Rear Glass into 67 Dart [Re: azmopar] #1702365
11/23/14 08:23 PM
11/23/14 08:23 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
Both Hardtops.
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702366
11/23/14 08:27 PM
11/23/14 08:27 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
Both Hardtops.
both 2 dr hardtops?
#NONIKESEVER
Re: 72 Dart Rear Glass into 67 Dart [Re: azmopar] #1702367
11/23/14 08:35 PM
11/23/14 08:35 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
"Are 67 and 72 Dart rear glass openings different sizes or am I missing something? Would it work if I used a gasket instead of buytl?"
You have to use gasket , both cars are designed for the rubber seal . I can see now why its 1/2 inch too short. Glass will basically fall through.
Re: 72 Dart Rear Glass into 67 Dart [Re: azmopar] #1702368
11/23/14 08:35 PM
11/23/14 08:35 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
Both 2 door hardtops.
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702369
11/23/14 08:40 PM
11/23/14 08:40 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
That is strange, because the glass that was in the 67, which I really wish I had not broken, was installed with buytl tape. No gasket. 1/2" overlap on the pinch weld all the way around.
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702370
11/23/14 08:45 PM
11/23/14 08:45 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
Ummm, are you trying to install this without a rubber gasket? If so, then yes the glass is going to fall right through the opening.
You have to use an original type rubber gasket. They buytl strip is used to make sure the gasket seals well to the opening and the glass. It's not meant to replace the actual gasket
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702371
11/23/14 08:48 PM
11/23/14 08:48 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
if the glass was/is as you say , its the wrong glass.
The same glass fits from 67 to 76. Only difference is the 67 car did not have chrome trim around the glass but a plastic insert in the rubber . But the glass is the same .
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702372
11/23/14 08:53 PM
11/23/14 08:53 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
Anybody know if the gasket can be purchased locally or do I have to go online?
I have to get this thing buttoned up in a week. Loading it on a trailer and hauling it through 5 states.
Re: 72 Dart Rear Glass into 67 Dart [Re: mopar_man] #1702373
11/23/14 08:54 PM
11/23/14 08:54 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
#NONIKESEVER
Re: 72 Dart Rear Glass into 67 Dart [Re: azmopar] #1702374
11/23/14 08:58 PM
11/23/14 08:58 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Re: 72 Dart Rear Glass into 67 Dart [Re: azmopar] #1702375
11/23/14 09:08 PM
11/23/14 09:08 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
if you need a used rubber seal for a 2 dr lmk
#NONIKESEVER
Re: 72 Dart Rear Glass into 67 Dart [Re: azmopar] #1702376
11/23/14 09:28 PM
11/23/14 09:28 PM
Detroit, MI
GetAwayDriver Offline
Detroit, MI
For what it's worth, I have heard (but never tried) that soaking those seals in vinegar makes them soft and pliable like new.
Re: 72 Dart Rear Glass into 67 Dart [Re: GetAwayDriver] #1702377
11/23/14 09:40 PM
11/23/14 09:40 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
If I can get hold of a gasket, I have aninstall question.
Because of the pointy corners and pinch weld around the entire opening, I assume it installs a little differently than the front windshield.
Would one try to install one or both lower corners and pull the rope toward the bottom center and then up the sides and across top or just like a rectangular one, pull from the bottom center, out and around the sides to the top center.
Re: 72 Dart Rear Glass into 67 Dart [Re: AZ67Dart] #1702378
11/23/14 09:51 PM
11/23/14 09:51 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
widest area first according to my glass guy
#NONIKESEVER
