ABS Brake Light Help #1701247
11/20/14 08:03 PM
11/20/14 08:03 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
My 97 Ram 1550 4WD with 252000 miles had the ABS/Brake light recently come on. I've troubleshooted it to the sensor on the rear axle. I don't have ABS, just the rear wheel. At this stage, I don't want to replace the sensor. How can I bypass the sensor to get the light to go out? Thanks
Re: ABS Brake Light Help [Re: 70VERT] #1701248
11/20/14 08:51 PM
11/20/14 08:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not replace the sensor? They are pretty cheap.
Re: ABS Brake Light Help [Re: 70VERT] #1701249
11/20/14 11:16 PM
11/20/14 11:16 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Can't "bypass" the sensor...buy a new one....they are NOT expensive.
Re: ABS Brake Light Help [Re: superwrench] #1701250
11/21/14 12:34 AM
11/21/14 12:34 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
for around $30 at the local parts store it don't make sense to rig it so light goes out. They are easy to change as well.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: ABS Brake Light Help [Re: 71yelladustr] #1701251
11/21/14 09:09 PM
11/21/14 09:09 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
rock auto has one for nine bucks.
Re: ABS Brake Light Help [Re: Golden-Arm] #1701252
11/22/14 10:19 PM
11/22/14 10:19 PM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Its "bypassed" right now....system throws code, system is disabled by presence of code. If you want lamp off..... Fix it.
Re: ABS Brake Light Help [Re: 70VERT] #1701253
11/23/14 06:32 PM
11/23/14 06:32 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
only way to make the light go out is take it out other then fixing the problem
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
