Dumb Rad ? #1700444
11/18/14 06:54 PM
11/18/14 06:54 PM
E. Okla line
m88mark Offline OP
m88mark  Offline OP
E. Okla line
I need a radiator for the 66. It has a 22" hole, so any advantage to 26" rad vs 22", besides a qt of water & a cheaper shroud? 1966 belvedere 440 400hp 727 323 gears. Thanks mark
Re: Dumb Rad ? [Re: m88mark] #1700445
11/18/14 07:04 PM
11/18/14 07:04 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
When it hits 100 degrees, that extra quart of water, and the extra open air surface amounts to a lot of extra cooling. Open up the rad surround and mount up that 26" rad, or stuff a thick aluminum rad in the 22" opening. Gene
Re: Dumb Rad ? [Re: poorboy] #1700446
11/18/14 07:23 PM
11/18/14 07:23 PM
E. Okla line
m88mark Offline OP
m88mark  Offline OP
E. Okla line
Well it dam gets 100 hear. Don't want to cut my core support, so looking at Mark 7 rads, alum, large tubes & offers black anodize. Thanks Mark
Re: Dumb Rad ? [Re: m88mark] #1700447
11/18/14 07:31 PM
11/18/14 07:31 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I've done 2 cars with 22 inch rads/openings to 26 and no cutting involved. I bought champion rads and they have the mounts already on it so all's I did was mount the rad on the existing driver's side bolts,level the rad and drill holes where needed on the passenger side. The entire opening is exposed for air and a 1970 26 inch shroud for Roadrunner,bought at a local chrysler dealer, mounted perfectly to the mounting holes on the rad. This was done on a 67 r/t and a 67 GTX. The tranny lines are extremely close but I used different fittings.
Re: Dumb Rad ? [Re: terzmo] #1700448
11/18/14 07:56 PM
11/18/14 07:56 PM
E. Okla line
m88mark Offline OP
m88mark  Offline OP
E. Okla line
My core support hole is 22 1/2" by 18 1/2". I just wondered if the 4" that's covered on a 26" would still cool better than a 22". Thanks Mark
Re: Dumb Rad ? [Re: terzmo] #1700449
11/18/14 08:01 PM
11/18/14 08:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
There are ZERO factory '67 440 b-bodies with 22" radiators. Clones?
Re: Dumb Rad ? [Re: 6bblgt] #1700450
11/18/14 09:27 PM
11/18/14 09:27 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
he has a transplanted motor as My original 383 cars had....not original motors..doesn't matter for changing from a 22 to 26 rad
Re: Dumb Rad ? [Re: terzmo] #1700451
11/18/14 10:54 PM
11/18/14 10:54 PM
E. Okla line
m88mark Offline OP
m88mark  Offline OP
E. Okla line
Thanks Terzmo. Anybody know if a 65 22" rad will fit a 66? Thanks Mark
Re: Dumb Rad ? [Re: terzmo] #1700452
11/19/14 02:53 AM
11/19/14 02:53 AM
gr mich
loren kraker Offline
gr mich
he has a transplanted motor as My original 383 cars had....not original motors..doesn't matter for changing from a 22 to 26 rad [/
quote]
so he had a 383 gtx???
Re: Dumb Rad ? [Re: loren kraker] #1700453
11/19/14 10:15 AM
11/19/14 10:15 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
quote]
WOW......66 car...GTX not available that year
Re: Dumb Rad ? [Re: terzmo] #1700454
11/19/14 11:01 AM
11/19/14 11:01 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
quote]
No, you claimed to have had a 67 GTX with a 383 that you swapped a 440 into and that it had a 22" radiator, factory..
Don't be the exception.
Re: Dumb Rad ? [Re: Supercuda] #1700455
11/19/14 02:35 PM
11/19/14 02:35 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
quote]
GTX was a clone...as The R/T...but what is the difference when talking about a 66..that's the subject...I used examples to show it's easy to swap a 26 in and don't need to cut the opening....as a side note...the only tell on either of my cars was the vin and the rad opening...everything else was done
Re: Dumb Rad ? [Re: terzmo] #1700456
11/20/14 01:33 AM
11/20/14 01:33 AM
E. Okla line
m88mark Offline OP
m88mark  Offline OP
E. Okla line
quote]
Wow guys is it a full moon. Starting to sound like general. I just wondered if an alum big tube 22" rad would do the job? Didn't mean to Thanks Mark
Re: Dumb Rad ? [Re: m88mark] #1700457
11/20/14 02:06 AM
11/20/14 02:06 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
"Well it dam gets 100 hear."
Re: Dumb Rad ? [Re: Kern Dog] #1700458
11/20/14 10:17 PM
11/20/14 10:17 PM
E. Okla line
m88mark Offline OP
m88mark  Offline OP
E. Okla line
100 degrees
