Re: Truck V-10 bellhousing pattern
[Re: Robbins]
#1699875
11/17/14 03:17 PM
11/17/14 03:17 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
The Viper V10 also has the same bell pattern.
[Re: RTSrunner]
#1699876
11/17/14 03:29 PM
11/17/14 03:29 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I've seen v10 engines for sale from trucks converted to diesels that's why I was wondering about the bell pattern.The diesels apparently use a SAE bolt pattern,#3 or 4 I guess years may be different.I did find some bell adapters from SAE to small block Mopar.A flywheel spacer may be different for the v10 vs diesel though. http://www.phxgrp.com/transChrysler.htm Thank for the replies,RT
[Re: blown340]
#1699878
11/17/14 07:40 PM
11/17/14 07:40 PM
Guitar Jones
That is incorrect. The aluminum viper V10 uses the normal small block bellhousing pattern. The iron block truck V10 does use the cummins SAE bellhousing.
-Jon
The ones I worked on didn't have a SB block pattern, they look more like the V10 and Cummins although I never measured or tried to bolt one up.
[Re: blown340]
#1699879
11/18/14 05:38 PM
11/18/14 05:38 PM
Guitar Jones
Well after further research I've found that both of us are wrong. The Viper V10 uses a pattern similar to the small block but the bolt holes do not line up, apparently it's one all it's own, why they did that I have no idea. I put a clutch in a '92 a long time ago and it didn't look like a SB pattern to me but I guess it's similar.
