2000 intrepid 3.5 rear main seal #1699366
11/15/14 04:14 PM
11/15/14 04:14 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
What is involved to change the rear main seal on a 3.5 L intrepid engine
Re: 2000 intrepid 3.5 rear main seal [Re: NTOLERANCE] #1699367
11/15/14 05:37 PM
11/15/14 05:37 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Remove transmission.
Re: 2000 intrepid 3.5 rear main seal [Re: teflon] #1699368
11/15/14 09:17 PM
11/15/14 09:17 PM
Madison Wi
Madison Wi
Would I be correct in assuming that it's a seal that taps into the housing similar to the front seal on a big block Mopar
Re: 2000 intrepid 3.5 rear main seal [Re: NTOLERANCE] #1699369
11/15/14 10:37 PM
11/15/14 10:37 PM
Mass. USA#1
hemi70 Offline
hemi70  Offline
Mass. USA#1
The seal is pressed into a retainer that is bolted to the block.
New seals should come in a new retainer with a sleeve to help with installation.
Had 1 early 3.5 with excess crank end play cause a leak there otherwise not too common.
Very commen for the camshaft thrust plates on the back of the heads to leak, sometimes ALOT!
Gary.
Re: 2000 intrepid 3.5 rear main seal [Re: hemi70] #1699370
11/15/14 10:40 PM
11/15/14 10:40 PM
Madison Wi
Madison Wi
Gary.
Can I see this from the top of the engine ?
Thinking about buying the car cheap.
Re: 2000 intrepid 3.5 rear main seal [Re: NTOLERANCE] #1699371
11/15/14 10:50 PM
11/15/14 10:50 PM
Mass. USA#1
hemi70 Offline
hemi70  Offline
Mass. USA#1
May need a light and a mirror to get a good look.
I think one side is abit hidden by some coolant tubes.
Gary.
Re: 2000 intrepid 3.5 rear main seal [Re: hemi70] #1699372
11/16/14 01:26 PM
11/16/14 01:26 PM
Madison Wi
Madison Wi
What is involved with changing the cam seals
Re: 2000 intrepid 3.5 rear main seal [Re: NTOLERANCE] #1699373
11/16/14 06:17 PM
11/16/14 06:17 PM
Madison Wi
Madison Wi
Thanks for the replies I passed on the car looks like it had a harmonic balancer put on shortly before oil seal took a dump motor Sounded a little funny
