removing a stuck oil filter - my solution #1699341
11/15/14 02:56 PM
11/15/14 02:56 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Hi There,
Just wanting to share my solution for a really stuck oil filter - small block - PH8 - oops XG16 not that it matters.
Since access to the filter is really good with wheel and access panel removed in my 69 B - I came up with this...
Take a parts store good for nutin filter end cap wrench and modify it.
I drilled 4 holes through the back of the wrench. I used self taping screws to screw the wrench to the oil filter. Big A$$ breaker bar on extensions connected to the wrench and blamo...off she came no muss no fuss and no mess.....
Hope this helps someone.
Plaz
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699342
11/15/14 03:05 PM
11/15/14 03:05 PM
I've driven a long screw driver through one years ago when I worked in a service station near a U.S. Marine base, some dumb jarhead must have tighten that rascal up with a long lever on it We ended uo resorting to that after a lot of other trys on using other methods If you have to do that, anyone, drive it in up as close to the engine as possible, avoid the threaded nipple though
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699343
11/15/14 03:06 PM
11/15/14 03:06 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Hope you didn't put another PH8 back on.
Re: removing a stuck oil filter - my solution [Re: Dcuda69] #1699344
11/15/14 03:53 PM
11/15/14 03:53 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I've found that the nylon strap one will just about remove any of them that are not welded on.
Re: removing a stuck oil filter - my solution [Re: Cudajon] #1699345
11/15/14 03:59 PM
11/15/14 03:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes, usually the strap works, after crushing the &$%*% out of it.
Re: removing a stuck oil filter - my solution [Re: buildanother] #1699346
11/15/14 04:33 PM
11/15/14 04:33 PM
ky.
K
kenworth_goose Offline
K
ky.
Don't put them on so tight
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699347
11/15/14 06:28 PM
11/15/14 06:28 PM
Plaz
Plaz it will cuz sometimes there ain't room enough to get a drive extension/ratchet on the strap (which is my fav)
Re: removing a stuck oil filter - my solution [Re: Dcuda69] #1699348
11/15/14 06:50 PM
11/15/14 06:50 PM
plazomat Offline OP
plazomat  Offline OP
Um yes I did its for my pre-winter storage oil change...why?
PLAZ
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699349
11/15/14 07:30 PM
11/15/14 07:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I resorted to the screwdriver trick back in my younger years many moons ago. I have found out if you can get the filter wrench as close to the block as possible it helps to get it off easier. Those cap wrenches suck for a really tight filter.
Re: removing a stuck oil filter - my solution [Re: mopars4ever] #1699350
11/15/14 07:41 PM
11/15/14 07:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Most of the time they will come off if you use two filter wrenches at the same time. I've had to cut them off with and air chisel, then walk the filter base around with an air chisel 1 1/2 turns before it would come off.
Doug
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699351
11/15/14 08:49 PM
11/15/14 08:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
PLAZ
Because PH8 is a Fram number. Fram = junk to many gearheads.
- Stu Harmon
Re: removing a stuck oil filter - my solution [Re: Cab_Burge] #1699352
11/15/14 09:24 PM
11/15/14 09:24 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Yes, because Jarheads are the only ones dumb enough to over-tighten an oil filter
Semper Fi, anyway
Scott
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699353
11/16/14 06:57 AM
11/16/14 06:57 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
A reason that I have always liked KN filter with 6 sided nut.. Also a bit longer than Wix so that can easily get strap on it if ever need be to help remove from 440 Challenger. . Some reason, I must cinch down quite securely to prevent seepage.
Re: removing a stuck oil filter - my solution [Re: plazomat] #1699354
11/16/14 10:43 AM
11/16/14 10:43 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I had one when I worked at the local G.M. dealership in the mid 80's.It was so tight that the can turned on the base after progressing from filter wrench to screwdriver through can. Ended up hammering it off and using a chisel to remoce the base. Lost money on that one.
