426 hemi rocker arms #1698872
11/14/14 10:52 AM
11/14/14 10:52 AM
England
cownurse Offline OP
cownurse  Offline OP
England
Hi all,
Can anyone tell me how much spring pressure, the mopar performance non roller rocker arms can handle.
Re: 426 hemi rocker arms [Re: cownurse] #1698873
11/14/14 04:06 PM
11/14/14 04:06 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The rocker arm itself can handle a lot of spring pressure (I have seen 750 lbs). It's just a maintenance matter of wear on the valve tip end. You need lash caps and they wear the rocker ends.
Back in the day, racers ran these pressures all the time.
Re: 426 hemi rocker arms [Re: Mopar_Rich] #1698874
11/14/14 04:32 PM
11/14/14 04:32 PM
England
cownurse Offline OP
cownurse  Offline OP
England
Thanks Rich, is it you who wrote the book.
Re: 426 hemi rocker arms [Re: cownurse] #1698875
11/14/14 04:38 PM
11/14/14 04:38 PM
an8sec70cuda Offline
I don't know what spring pressures, but I remember HemiFred saying he ran the factory wide pad rockers for years and years on some pretty nasty roller cams.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 426 hemi rocker arms [Re: cownurse] #1698876
11/14/14 08:19 PM
11/14/14 08:19 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yep.
Re: 426 hemi rocker arms [Re: Mopar_Rich] #1698877
11/14/14 10:20 PM
11/14/14 10:20 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've been running 740#'s over the nose with stock wide pad rockers for 4 years on the street. So far I've had one pushrod split a cup. Everything is coming apart again this winter for inspection though.Dave
Re: 426 hemi rocker arms [Re: quickd100] #1698878
11/15/14 05:48 AM
11/15/14 05:48 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The problem is not strength, its consistency of the ratios. You can pick 100 rocker arms and be lucky to find a match set of 8, not the right ratio mind you but at least they would be the same ratio....Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 426 hemi rocker arms [Re: astjp2] #1698879
11/15/14 06:54 AM
11/15/14 06:54 AM
England
cownurse Offline OP
cownurse  Offline OP
England
Thanks for the replies, seems to be a vast amount of knowledge in this forum.
Re: 426 hemi rocker arms [Re: astjp2] #1698880
11/15/14 08:46 AM
11/15/14 08:46 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Very True!!! It's one of the hair pulling, cussing and screaming aspects of building a Hemi. I've got 2 sets of stock rockers one of which was a set of old superstock rockers. My intakes go from 1.63 to 1.69 ratio. The exhausts go from 1.49 to 1.53. Dave
Re: 426 hemi rocker arms [Re: quickd100] #1698881
11/15/14 11:24 AM
11/15/14 11:24 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Save up and just get these ........................
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: 426 hemi rocker arms [Re: chryco] #1698882
11/18/14 09:35 AM
11/18/14 09:35 AM
pa
572charger Offline
572charger  Offline
pa
agreed with chryco !!!! ive had them for over 10 yrs on my 700+ lift roller cammed hemi still look new no wear in 8000 + miles and many 9 sec passes and some 8 sec no2 passes !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 426 hemi rocker arms [Re: quickd100] #1698883
11/18/14 01:55 PM
11/18/14 01:55 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If my math is correct, then the variation between the rockers is less than 1%. How large of an impact could that realistically have for most of us? Is that range typical of OE style rockers?
It would seem to me that the head ports would not be that consistent.(even after porting) Or the intake runners. Or the cam lobes. Etc, etc. And I doubt that many of us could set the lash within 1%. A .001" variation on a .020" lash is 5%.
The OE style rockers have proven themselves to be very durable over the decades for most of what we do with these engines. So, how much real world impact does the infamous variation have on our combos. Could it be noted on a time slip or dyno sheet? Let alone seat of the pants?
Opinions please.
Master, again and still
Re: 426 hemi rocker arms [Re: DaveRS23] #1698884
11/18/14 03:48 PM
11/18/14 03:48 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
That's my 'Good' set. the other set isn't worth talking about. Dave
Re: 426 hemi rocker arms [Re: DaveRS23] #1698885
11/18/14 03:59 PM
11/18/14 03:59 PM
I use to race(1974 to 1976) a 1970 426 hemi Cuda 4 speed car in NHRA stock, I ended up buying all the spare parts I could I ended up finding out later that the rocker arms on my motor had .100 net lift difference(.430 to .530) on the exhaust side and .080 (.460 to .520) on the intakes I went though five sets of rocker to get my motor legal with the stock cam specs, the ratio are horrible on the stock stuff I like to get all things equal as far as compression ratio, storke, intake and exhaust port volume, combustion chamber volume, rocker ratio, net lift at the retainers and so on
Re: 426 hemi rocker arms [Re: Cab_Burge] #1698886
11/18/14 09:31 PM
11/18/14 09:31 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The interesting part of it is that after 40 + years the stock Hemi rocker arm set up is still selling for a average of $1500. bucks. :
Re: 426 hemi rocker arms [Re: rowin4] #1698887
11/18/14 09:42 PM
11/18/14 09:42 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That is due to lack of knowledge and 4 important letters: HEMI
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 426 hemi rocker arms [Re: rowin4] #1698888
11/18/14 09:45 PM
11/18/14 09:45 PM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
Same here
Ain't nuthin like a HEMI !
Re: 426 hemi rocker arms [Re: Cab_Burge] #1698889
11/18/14 09:58 PM
11/18/14 09:58 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Holy crap!
So, is it worth it to have some of the rocker guys to square up the ratios on the stock rockers? I think it is like $500 or so to do it. If, like me, you already have a good set of stock rockers, would getting them trued for that kind of coin be worth it versus $2,500 or more for aftermarket ones?
This would be for a street/strip car.
Between this and the threads on addressing the intake sealing issues, I am learning a ton here.
